HIFI-FORUM » Reparatur & Wartung » Elektronik (Stereo&Surround) » Wer kann mir weiterhelfen? | |
Wer kann mir weiterhelfen?+A -A |
Molly593
#1 erstellt: 26. Jun 2010, 12:12 | |
Pioneer CD Wechsler CDXP620S kann Box nicht mehr öffnen Fehlermeldung ERROR 60 wer kennt sich aus bitte HILFE |
tri-comp
#2 erstellt: 27. Jun 2010, 23:02 | |
Hi, Error 60 means simply that the 6-CD Tray is not seated correctly. It is caught in an in-correct position when inserted. What is causing this may simply be a defective Tray; I have seen it happen. More likely it is the mechanism being out of alignment. This may happen due to several causes. The 4 rubber bearings/shock-absorbers that holds the mechanism-unit and shields it from vibrations may be deformed over time. The rubber hardens and looses its shape. This may be enough off-set to catch the tray being loaded in an in-correct lock. The 4 shock-absorbers are called 'Dampers' and are Pioneer partno.: CNV4501 Of course the problem may be caused by a defective loading-motor (Tray-Motor CXA9139) or the elevation-motor (CXA9146) or just wear & tear. The unit is close to 15 years old after all. If you need to re-align the entire mechanism I suggest to get in touch with someone who knows a lot about mechanics & electronics. This re-alignment is a very complicated process ! mfg, /tri-comp Oh, please tell me why you didn't post this request for help in the Car Hi-Fi sub-section? A Pioneer CDX-P620S is for Car-use only. [Beitrag von tri-comp am 27. Jun 2010, 23:07 bearbeitet] |
Yamaha CRX 300 defekt wer kann helfen. H.Mac am 20.02.2010 – Letzte Antwort am 24.11.2018 – 4 Beiträge |
Wer kann helfen? KoRnfan am 03.02.2013 – Letzte Antwort am 05.02.2013 – 5 Beiträge |
NA7004 tot, Wer kann helfen? Amundsen am 11.11.2018 – Letzte Antwort am 21.12.2020 – 4 Beiträge |
Wer kann mir günstig eine Platine ätzen? tomek_m am 21.04.2011 – Letzte Antwort am 27.04.2011 – 8 Beiträge |
Aloia Vorstufen reparieren ? Wer platinum1913 am 04.03.2021 – Letzte Antwort am 04.03.2021 – 2 Beiträge |
Röhren Verstärker kapput, wer kann helfen Brees am 23.11.2012 – Letzte Antwort am 23.11.2012 – 5 Beiträge |
Wer kann Technics Endstufe reparieren SE-A5MK2 ? onkeljoe65 am 02.11.2009 – Letzte Antwort am 01.12.2009 – 3 Beiträge |
Yamaha RX-V450 => Defekt, wer kann helfen? greetzz am 23.12.2008 – Letzte Antwort am 20.11.2013 – 4 Beiträge |
Sharp RP 117 - Wer kann helfen? mallindor am 25.06.2012 – Letzte Antwort am 31.10.2014 – 5 Beiträge |
Wer kann mir helfen? Sony Amp TA-F417R zickt... jeano30 am 24.03.2006 – Letzte Antwort am 17.06.2009 – 6 Beiträge |
- PV Anlage stört auf UKW
- Verstärker rauscht
- Registrierte Mitglieder926.351 ( Heute: 14 )
- Neuestes Mitgliedmihed97174
- Gesamtzahl an Themen1.552.686
- Gesamtzahl an Beiträgen21.575.083
