Yamaha RX-V740 problem
redoced
#1 erstellt: 31. Mrz 2004, 11:15
Hello
i have a problem with the yamaha RX-V740 and i hope
somebody here can help me.
I have a yamaha RX-V740 A/V receiver with two B&W 602 S3
speakers and some monster cable.
The problem i have is this. Sometimes when i power up
the yamaha, the system plays music only on the right
speaker. There is no sound coming out of the left speaker.
This doesn't happen very often, it happens about once a day.
If i switch off the speakers by pressing "speakers A"
button and i switch them back on a couple of times, then
the problem goes away and both speakers output sound.
This problem shows up with tv sound/tuner etc.
Has anybody noticed anything similar? Does anyone have
any idea what might be causing this? I would like to
factory reset the A/V receiver. Can somebody tell me how
to reset the receiver?
Please write if you know anything about this!!!!
PIWI
#2 erstellt: 31. Mrz 2004, 12:54
Hi redoced !
My best wishes for you to solve the problem.
But I don't think a factory reset would help.
Did you already check the connections at the receiver and the speakers ?
How about changing the speakers ?
(Left to Right)
Additional maybe using other cables ?
First you should know, if the problem is really related to the receiver.
Best regards
PIWI
[Beitrag von PIWI am 31. Mrz 2004, 12:59 bearbeitet]
lucasleister
Gesperrt
#3 erstellt: 31. Mrz 2004, 13:01
Hy,
that´s my opinion, too! Please check the cable and the connections, change the speakers.
redoced
#4 erstellt: 31. Mrz 2004, 13:04
Thanks for your reply.
Just yesterday i swapped the cables left/right
to find out if it is a problem with the cables.
When the problem shows up again and i know if it
is the cables, i will swap speakers left/right so
i can find out if it is the speakers.
It will be very interesting to see what is causing this.
I am not 100% sure it is the receiver but i am
afraid this is causing it....
drachenbremser
#5 erstellt: 31. Mrz 2004, 15:15
Hi redoced,
did you check your impedance input selector on the back side of your Yamaha? As far as I know Yamaha is a brand that requires a speaker adjustment depending on the different impedance of connected speakers. If you are driving speakers with less than 8 Ohm, you should set the impedance input selector in left position. This could be causing your problem with the malfunctionality of the left speaker. Give it a try and good luck!
Best regards
drachenbremser
redoced
#6 erstellt: 01. Apr 2004, 06:15
i am using 8 Ohm speakers and i have the switch set to
the right position as you view the unit from the back.
Yesterday i saw the problem again when i powered up the
unit and i was still having a problem with the left speaker
even though i had switched the cables. So this rules the
cables out. I switched the left/right speakers and i want
to see what happens now. If the problem switches sides
then it might be the speakers to blame and not the receiver.
Another thing that i noticed yesterday, is that the left
speaker became alive about 20 seconds after the right one.
This happened the same time i pressed the TUNER button on
the remote control. Could these two events be related? Is
it justified that one of the speakers comes alive after
the other one?
Any thoughts welcome!!
PIWI
#7 erstellt: 02. Apr 2004, 13:09
Hello redoced !
This is the prefered position for 8 Ohm speakers.
But this should have nothing to with your problem.
8 Ohm speakers normally work with 4 Ohm position too.
(The volume might be a little lower)
We and you just must wait for the results of switching your speakers.
the other one?
A Receiver is just an amp with an integrated Tuner.
Normally there should be no relation.
I think, it just happened at the same time.
Do you have the problems only with analog sources ?
How does it work with digital connected devices like DVD or CD ?
At least :
If it is not the speaker, you should bring the 740 to the customer service.
Perhaps it is "only" a connection problem inside the 740.
Best regards
PIWI
redoced
#8 erstellt: 04. Apr 2004, 10:09
Hi PIWI,
most of the times that i power up the receiver i have
it in either TV or TUNER so i can't really say if the
problem would show up with a DVD or a CD.
Finally after switching speakers, the problem remains
on the left side speaker so at least i know that my
cables and speakers are OK!!
This seems more and more to be a yamaha problem. Last
night when i powered up the system i noticed that the left
speaker was giving a lot less volume than the volume of
the right speaker even though i have them balanced in the
setup. After switching off and on the system
the problem went away!!!!! I am thinking something has
gone bad inside the receiver and i've only had this for 5-6
months now and i must say i have been very respectfull to
the volume control, never more that -30db.
I think the only thing to do now is to send it to be
repaired, i hope it doesn't cost me anything.
Way to go yamaha!!
Yamaha Memory Guard
jdd2000 am 06.05.2004  –  Letzte Antwort am 06.05.2004  –  5 Beiträge
NR-5000
Asterix007 am 20.01.2006  –  Letzte Antwort am 20.01.2006  –  5 Beiträge
Which Receiver & speakers: Pioneer,Yamaha,Denon or Marantz
mikehifi am 11.03.2008  –  Letzte Antwort am 14.03.2008  –  9 Beiträge
denon avr 4308 jpeg jpg viewing bilddarstellung
dreamfox am 22.01.2008  –  Letzte Antwort am 24.01.2008  –  3 Beiträge
Kombi-Test on Stereoplay 11.2003
redskorpion am 29.02.2004  –  Letzte Antwort am 03.03.2004  –  5 Beiträge
Titan 500, worth money?
AlexS am 22.12.2003  –  Letzte Antwort am 22.12.2003  –  4 Beiträge
Centrum products? (English)
AlexS am 13.12.2003  –  Letzte Antwort am 17.12.2003  –  3 Beiträge
Yamaha RX-V740 Probleme!!
coolfire am 06.02.2004  –  Letzte Antwort am 10.02.2004  –  4 Beiträge
Yamaha RX-V740 RDS
Hotzi1 am 25.04.2004  –  Letzte Antwort am 27.04.2004  –  12 Beiträge
Probleme Yamaha RX - V740
Derrek_Fish am 18.03.2004  –  Letzte Antwort am 19.03.2004  –  6 Beiträge
  • Registrierte Mitglieder928.419 ( Heute: 3 )
  • Neuestes MitgliedBettina_Lindner-Dietze
  • Gesamtzahl an Themen1.558.161
  • Gesamtzahl an Beiträgen21.695.435
Top Hersteller in A/V-Receiver/-Verstärker Widget schließen
