HIFI-FORUM » Surround & Heimkino » A/V-Receiver/-Verstärker » NR-5000 | |
NR-5000+A -A |
Asterix007
13:42
erstellt: 20. Jan 2006, |
Hello, sorry for my english, but my deutch is inexistant. I have a NR5000 and I would like to ask owner of this wonderfull receiver to test something. I use a MAIN A 7.1 config and a MAIN B Stéréo config Bi-Amp actually In the manual it is mentionned than we can configure SPEAKER A as MAIN A and SPEAKER B as MAIN A too with the SurrBack in Bi-Amp mode. But on my receiver, as soon as select Main A in Sp B, I can't select Bi-Amp in SurrBack... Thanks for checking. I use firmware 1.06, I heard that 1.09 is available... has somebody this version ? Thanks ! |
mr.pink
18:55
Hi, it's a little hard to follow your setup description. The idea of bi-amping is that you connect your front speakers to Main A and Surround Back. There are 7 amplifiers inside the receiver, so you can't have 7.1 setup running with bi-amping for the fronts without external amplifiers (as you need 4 amplifiers for the front instead of 2). Does this help you? Or did I misunderstand your question. Regarding the firmware, I have 1.08 installed and 1.09 downloaded but not installed. 1.08 was a major improvement, I personally saw no reason to upgrade to 1.09. If you want to have one of the firmwares, you can send me your e-mail address via PM. But please be careful what you do, as you know a firmware update is always a more or less high risk. Best regards, mr. pink |
Asterix007
22:21
Hi mr.Pink, Thanks for your answer, I will try to make it clearer. In the manual (English page 23) of the NR5000, you can make a configuration like this : 1-1.Speaker Config ===================== Speaker A a.Front L/R :Main A b.Center :Main A c.Surr L/R :Main A d.Surr Back :Main A 2ch e.Subwoofer :Main A Speaker B f.Front L/R :Main A g.Center :Not Used h.Surr L/R :Not Used i.Surr Back :BiAmp for Front j.Subwoofer :Not Used The advantage of select MainA for speaker B is that you can select either Speaker A or Speaker B in the Listening mode setup. So for movie in DD5.1 you select Speaker A and for a good CD Audio in Stereo mode, you select Speaker B. But the problem is that, when I select main A in the point f., I can't select Bi-Amp in i. point. I hope it's better explained now ![]() Could you check if you can please. Thanks in advance. Concerning firmware 1.08, have you the file for NR5000 ? |
mr.pink
22:33
Hi, yes, I have the firmwares 1.08 and 1.09 for the TX-NR5000E. I would recommend you to go for an update, as the 1.06 had some strange bugs. However, I don't know whether your particular problem will be solved as well, but I will check how my receiver reacts. Best regards, mr. pink |
Asterix007
23:52
OK, i'm waiting your test... I send you a MP |
denon avr 4308 jpeg jpg viewing bilddarstellung dreamfox am 22.01.2008 – Letzte Antwort am 24.01.2008 – 3 Beiträge |
Kombi-Test on Stereoplay 11.2003 redskorpion am 29.02.2004 – Letzte Antwort am 03.03.2004 – 5 Beiträge |
Yamaha RX-V740 problem redoced am 31.03.2004 – Letzte Antwort am 04.04.2004 – 8 Beiträge |
Centrum products? (English) AlexS am 13.12.2003 – Letzte Antwort am 17.12.2003 – 3 Beiträge |
Yamaha Memory Guard jdd2000 am 06.05.2004 – Letzte Antwort am 06.05.2004 – 5 Beiträge |
Bi-wiring mit A+B wiseman am 21.06.2004 – Letzte Antwort am 21.06.2004 – 7 Beiträge |
Traveling to berlin next week, Where do I buy AV Receiver? Shaked_Buktus am 14.03.2017 – Letzte Antwort am 15.03.2017 – 7 Beiträge |
Pioneer VSX 912: A+B=Bi-Amping? achduliebergott am 20.01.2005 – Letzte Antwort am 21.01.2005 – 11 Beiträge |
Which Receiver & speakers: Pioneer,Yamaha,Denon or Marantz mikehifi am 11.03.2008 – Letzte Antwort am 14.03.2008 – 9 Beiträge |
B-Speaker mit Rear kombinieren Ako84 am 03.02.2008 – Letzte Antwort am 06.02.2008 – 13 Beiträge |
2006
- LFE-Tiefpass-Filter?
- Registrierte Mitglieder928.914 ( Heute: 5 )
- Neuestes MitgliedVWT41999
- Gesamtzahl an Themen1.559.286
- Gesamtzahl an Beiträgen21.722.438
