HDMI out am Receicer
Heiron
#1 erstellt: 10. Dez 2009, 14:39
ich hab' mal eine FRage zu dem Ausgang am Receiver.
Wird das Bildsignal im Receiver lediglich durchgeschleift und an den Fernseher weiter gegben oder hat es noch einen andern Nutzen.
Ich kann ja den BD Player auch gleich direkt mit dem TV verbinden.
Die Antwort hier habe ich über google gefunden, ist aber auch nicht sehr fruchtbar:
http://answers.yahoo.com/question/index?qid=20080520131230AA09lMC
"...Receivers act as switching devices. You connect source devices (like a DVD player, cablebox, satellite receiver or VCR) to the "in" ports and display devices (like a TV, HDTV, projector) to the "out" ports. The receiver input selector then switches between inputs and sends the video from the selected input to the output video device and the audio is amplified and sent to the speakers connected to the receiver. That way the TV is left on one input setting and the receiver is used to select sources that are heard from the speakers and seen on the display (if appropriate. e.g. a CD doesn't have video, while a DVD does).
There are usually several types of inputs that can be used for most sources, in some cases all are live simultaneously, while in others the input type must be selected via a menu available in the receiver (This explains why sometimes cables are connected but no signal is heard).
If the receiver simply "passes through" the signal you can only get output from the same type of input (e.g. HDMI out will only connect to the HDMI "in" ports (e.g. it won't take a signal from a composite (yellow RCA jack) or component video (red/blue/green RCA jacks) input and output on HDMI). Some receivers "transcode" inputs to different types of outputs. In this case, for example, a composite or component input signal would be available on the HDMI output.
Finally, HDMI can carry both video and audio, but not all HDMI outputs pass both. This can be an issue on, for example, a satellite receiver (since you would need an additional connector to get audio to the receiver). The HDMI output from a receiver however is usually only required to connect video to a display (e.g. HDTV or projector) since the audio is processed by the receiver and output to the speakers connected to the receiver (not the speakers in the TV)..."
Danke
Iceman_SVW
#2 erstellt: 10. Dez 2009, 14:51
Fürs Erste wär's mal wichtig zu wissen, von welchem Receiver du sprichst.....
Es gibt AVR, die lediglich Videosignale "durchleiten" (ohne sie zu bearbeiten) und solche, die sie annehmen, skalieren/de-interlacen und dann erst weitergeben.....
Heiron
#3 erstellt: 10. Dez 2009, 15:34
War eigentlich nur eine grundsätzliche Frage, aber Deiner Antwort kann ich ja entnehmen, dass -je nach Gerät- dsa Signal verarbeitet oder auch nur durchgeschleift wird.
Danke.
Welcher receicer hat eine Funkfernbedienung?
denon4711 am 27.04.2010  –  Letzte Antwort am 06.05.2010  –  9 Beiträge
Optical Out gegen hdmi
skratter am 21.06.2008  –  Letzte Antwort am 21.06.2008  –  5 Beiträge
HDMI-OUT am Denon 4306 zu HDMI am LCD-IN
Bech-Tech am 05.02.2008  –  Letzte Antwort am 08.02.2008  –  6 Beiträge
Gleichzeitige Tonausgabe über HDMI out am AVR?
Teupu am 14.06.2016  –  Letzte Antwort am 19.11.2016  –  4 Beiträge
Yamaha 2600 kein HDMI Out
Earphone am 21.04.2006  –  Letzte Antwort am 22.04.2006  –  10 Beiträge
HDMI in - Anlaog out ?
mralchemy am 05.06.2008  –  Letzte Antwort am 05.06.2008  –  4 Beiträge
2 x HDMI out
Marcel780 am 03.12.2010  –  Letzte Antwort am 03.12.2010  –  2 Beiträge
2 hdmi out
theart am 11.09.2013  –  Letzte Antwort am 12.09.2013  –  3 Beiträge
Yamaha RX-V463 HDMI out
adrianomartins am 25.10.2008  –  Letzte Antwort am 25.10.2008  –  6 Beiträge
Beratung Receiver 1 HDMI Out oder 2 HDMI Out!
Sven38 am 03.05.2017  –  Letzte Antwort am 04.05.2017  –  6 Beiträge
  • Gesamtzahl an Themen1.559.688
  • Gesamtzahl an Beiträgen21.732.470
Top Hersteller in A/V-Receiver/-Verstärker Widget schließen
