Klipsch Reference IV technische Daten
Sp1rit
#1 erstellt: 03. Feb 2006, 14:53
die Technischen Daten der Reference IV Serie sind seid ein paar Tagen auf der Hompage von Klipsch.
Mich wundert, dass der neue Center RC 64 eine sehr hoch untere Gerenzfrequenz gegenüber dem RC 62 und dem RC 7 hat. Wisst ihr vielleicht warum das so ist?
Hier nochmal die Daten:
RC 64
FREQUENCY RESPONSE:
62Hz-21kHz +/-3dB
POWER HANDLING:
200W RMS / 800W Peak
SENSITIVITY:
99dB @ 2.83V / 1m
NOMINAL IMPEDANCE:
8 ohms compatible
HIGH FREQUENCY DRIVERS:
1.25" (3.2cm) Titanium diaphragm compression driver mated to 90x60 square Tractrix® Horn
HIGH FREQ CROSSOVER:
1150Hz, 1800Hz
LOW FREQUENCY DRIVERS:
Quad 6.5" (16.5cm) High-output Cerametallic™ cone woofers
ENCLOSURE TYPE:
Sealed
HEIGHT:
8" (20.3cm)
WIDTH:
33" (83.8cm)
DEPTH:
13.5" (34.3cm)
MOUNTING:
Uptilt and Downtilt feet
WEIGHT:
61 lbs (27.7kg)
FINISHES:
Cherry or Black Ash wood veneer
BUILT FROM:
2006
RC 62
FREQUENCY RESPONSE:
57Hz-23kHz +/-3dB
POWER HANDLING:
150W RMS / 600W Peak
SENSITIVITY:
98dB @ 2.83V / 1m
NOMINAL IMPEDANCE:
8 ohms compatible
1" (2.54cm) Titanium diaphragm compression driver mated to 90x60 square Tractrix® Horn
1150Hz, 1650Hz
Dual 6.5" (16.5cm) Cerametallic™ cone woofers
ENCLOSURE TYPE:
Bass-reflex via dual front-firing ports
HEIGHT:
8" (20.3cm)
WIDTH:
23.5" (59.7cm)
DEPTH:
12.5" (31.8cm)
MOUNTING:
WEIGHT:
32lbs (14.5kg)
FINISHES:
Cherry or Black Ash woodgrain vinyl
BUILT FROM:
2006
RC 7
FREQUENCY RESPONSE:
45Hz-20kHz ±3dB
POWER HANDLING:
200 w max continuous (800 w peak)
SENSITIVITY:
98dB @ 2.83 volts/1 meter
NOMINAL IMPEDANCE:
8 ohms
CROSSOVER FREQUENCY:
HF: 1950Hz
MF: 550Hz
TWEETER:
K-67-KV 1.75" (4.45cm) Titanium dome compression driver
HIGH FREQUENCY HORN:
8" square 90°x60° Tractrix® Horn
WOOFER:
Two K-1083-SB 8" (20.32cm) Cerametallic® cone / cast polymer frame
ENCLOSURE MATERIAL:
MDF
ENCLOSURE TYPE:
Bass reflex via dual rear-firing ports
INPUT CONNECTIONS:
2 sets of binding post speaker terminals
DIMENSIONS:
9" (23cm) x 26" (66.5cm) x 12" (30.7cm)
MOUNTING:
Dual Downtilt feet
WEIGHT:
42 lbs. (19kg)
FINISHES:
Cherry or Black wood veneer
BUILT FROM:
2001
BUILT UNTIL:
2006
Sp1rit
[Beitrag von Sp1rit am 03. Feb 2006, 17:34 bearbeitet]
bulla
#2 erstellt: 04. Feb 2006, 16:44
Hoher Wirkungsgrad, geschlossenes Gehäuse, kleiner Tieftöner... da kommt eins zum anderen..
Klipsch ist glaub ich ohnehin ein Verfechter der 80hz-Trennungs-Theorie, ähnlich Teufel. Da der Center unterhalb 80hz dann eh nix mehr zu tun hat, braucht er auch nicht auf Tiefgang getrimmt zu werden...
Dirkxxx
#3 erstellt: 05. Jul 2010, 21:22
kann jemand was dazu sagen, worin die sich klanglich unterscheiden? interessant wäre, wenn jemand beide center kennt und beurteilen kann. wenn möglich im selben hörraum mit den selben komponenten.
Klipsch Reference IV und MKII kombinieren
Franky-LH am 20.01.2013  –  Letzte Antwort am 28.01.2013  –  20 Beiträge
Klipsch Reference und Reference Premiere mischbar?
Nemesis200SX am 02.04.2017  –  Letzte Antwort am 08.01.2019  –  6 Beiträge
Infinity Beta vs Klipsch Reference
Powerheart am 08.03.2011  –  Letzte Antwort am 12.03.2011  –  8 Beiträge
informationen zu infinity reference 31i
enom am 20.05.2003  –  Letzte Antwort am 03.06.2005  –  3 Beiträge
Technische Daten Bose companion 3
Stoki1 am 21.09.2007  –  Letzte Antwort am 22.09.2007  –  3 Beiträge
Klipsch REFERENCE PREMIERE HD WIRELESS Erfahrungen
__jackersoul__ am 15.05.2016  –  Letzte Antwort am 11.01.2018  –  2 Beiträge
Vergleich Klipsch Reference vs. XTZ Cinema
Niiggii am 11.09.2016  –  Letzte Antwort am 15.02.2020  –  29 Beiträge
Neuling Klipsch Reference Premiere Serie perfekt einstellen
Diamond_72 am 21.10.2019  –  Letzte Antwort am 10.11.2019  –  2 Beiträge
Klipsch Reference R-51M / Focal Chorus 706
*soundOFmusic* am 28.01.2020  –  Letzte Antwort am 06.02.2020  –  2 Beiträge
rp oder reference serie
Indiziert_Zero am 28.11.2023  –  Letzte Antwort am 25.12.2023  –  3 Beiträge
  • Registrierte Mitglieder929.070 ( Heute: 2 )
  • Neuestes MitgliedWalterGeer
  • Gesamtzahl an Themen1.559.600
  • Gesamtzahl an Beiträgen21.730.362
