HIFI-FORUM » English » Stereo (Engl.) » Advice for CD player upgrade | |
Advice for CD player upgrade+A -A |
panditr
18:54
erstellt: 20. Jan 2006, |
Hi I would like to change my CD player cause I have been bitten by the bug. I have a Rotel Integrated Amp RA-1070 along with Quad 11Ls. I am currently using a NAD 521 BEE CD player as a source which is a year old. My budget is approx $400 as I would be going to the US. Please suggest options within the price range and compatibility with my present setup.the reason I want to change is because like Sanathan I find something missing. Also Please advise if changing the source can resolve the problem or is there something which I can do to the room acoustics to make my setup better? my room is 14x17 feet and has 2 wall and 2 floor carpets along with furniture and curtains. I would be grateful for your thoughts and suggestions. Rahul |
Arj
04:41
erstellt: 21. Jan 2006, |
if it is the bass you are missing, you could do better by upgrading your speaker ![]() if it is the source you are not happy with get a DAC in the US. try out audiogon which is great for the used market. for the budget, an MSB, Meredian, Monarchy or even a Sonic frontiers would be great options and the sound equivalent would be better than a 1500 CDP ;)/ a stepup transformer has a smaller impact on DACs..in fact if you chose any of the above their PSUs are very well designed and hence you would not notice any degradation in most setups. (I think Meredians have a 120/240 swith behind them) YOur amp is pretty good and for your mentioned budget you cannot do better than that. ut why dont you get a Sonic Impact T amp from there ? its just around 30 USD and is worht the surprise in clarity it provides.. You can also look at used speakers and you might get a good deal on something About the room treatment, it is pointless to mention anything unless you are able to mention as to What you are missing... ![]() [Beitrag von Arj am 21. Jan 2006, 05:01 bearbeitet] |
panditr
11:32
Thanks for the advice Arj. I am not missing the bass at all. In fact my room acoustics add to the bass which is muddy. hence my decision to go in for the smaller Quad bookshelves. What I am missing is the clarity since I would like to hear every little sound there is on a CD. I bought the speaker just 2 months back and because of the room acoustics a floor stander was out of the question. I have heard from some people that the 521BEE is bass heavy and that I should upgrade the CDP with respect to the amp and the speakers. What I am looking at is to improve the clarity of my setup whichever way possible. I thought changing the CDp would be it. I will not change the CDp if there are better and cheaper ways to improve sound. I think it is the muddy bass which does not give me the desired sound. What do you think? |
Arj
11:58
lack clarity could be caused by any component, but the Quad and the Rotel are both above reproach hence the CDP is a possible culprit. (I hope you have been thru all articles on the web on speaker placements etc;;) I own a 521BEE myself and its definitely not the best thing which has happenned in cdps unlike the Int Amp. I would recommend going the DAC way. if you can plonk in the 900 USD for a Benchmark OR a lavry you would have the best ^possible midfy source which could be part of you setup even if you upgrade your speakers and your amp. Although from your room size , even floorstanders would be quite possible. could you post a diagram of your setup ? |
sanathan
19:59
cdp to dac is good option but a little costly but are we sure if adding the dac improves your bass muddiness if the bass muddiness is caused by the room? Also i found out quads are VERY sensitive as regards room placement, you could try a thinner sounding speaker ? I had a PSB earlier and i like its voicing (articulate and upto the point) ..anycase NEVER buy a new system without listening to all your components at TOGETHER!! |
sanathan
19:59
cdp to dac is good option but a little costly but are we sure if adding the dac improves your bass muddiness if the bass muddiness is caused by the room? Also i found out quads are VERY sensitive as regards room placement, you could try a thinner sounding speaker ? I had a PSB earlier and i like its voicing (articulate and upto the point) ..anycase NEVER buy a new system without listening to all your components TOGETHER!! |
Amp_Nut
20:37
Get a friend's CDP and substitute in your system. Worst case, even replace it with a vanila DVD player and see if there is a Change in the sound.. ( probably should be ) It will give you some handle on whether your set up is resolving the music from the source, and therefore whether a new source will amke any difference. Once you are Convinced that the CDP needs an upgrade... for the money you have in mind, look around for an unused ( new but now a discontinued model ) Denon 2900. I am told they are sporadically available in Mumbai for approx Rs 29 K. This is a Great Universal player ( IMHO ) even at its original asking price of Rs 50K. At 29K its a Steal. Very nice, detailed, and still well balanced sound. The icing .... its a Universal player ( CDs, SACD, DVD, DVD-A, mp-3 ) No HDCD though or DiVx movies. Incidentally, I discovered that the retail price of a cheap DVD chinese player, at Lamington Road, Mumbai starts at Rs 1300 though Rs 1,500 will yield a wider choice. And these play DiVX movies too ( sorry no SACDs or DVD-As ![]() |
Arj
06:43
erstellt: 22. Jan 2006, |
I doubt if Muddyness in bass is by the room. A room can cause Suckouts at certain frequencies and Boominess in certain others and these are usually a peak at around 50-70 depending on the room dimentsions. Muddy bass is usually due to the speaker when the driver is unable to reproduce lower frequencies well enough. and from my experience Quad has quite a poor bass reproduction although its highs and mids are good. in the current system, the weak link clearly is the cdp (The roltel 1070 is an outperformer in its price range with enough power reserves) and if you have an option and budget for an upgrade and you do not want to improve the bass further, the DAC option is IMHO the best way as any of the above DACs is definitely better than the NAD which is not the best designed output stages. and for that price you will not get a CDP which outperforms the NAD.. if the problem was with the bass the cost effective upgrade would have been a decent subwoofer.. |
sanathan
07:01
yes arj is right, muddiness is only caused in some frequency points not the entire bass line. Anyway if boominess is caused yu can adjust the speaker placment reasonably and you will be able to make out differences between positions. If your cdp is detailed, it will show up even if there is muddiness... Denon is a good bet since it is universal and it has relatively thinner sound which i have a feeling you will like. I have a quad 12L and the bass is ok but not heavy sort of bass ... its very articulate ...what i am saying is that quad intrinsically (atleast the 12L) produces precise bass but its not bass heavy .... |
ckn
07:03
Hi, Forgive me for sounding ignorant and less tech savvy than others in this forum. Could someone explain in some more detail about what the DAC does and how it will improve the overall listening experience? I have information but not sufficient understanding. Is the DAC advised for all mid-fi systems? How do you connect it up in the set up? Thanks in advance. ckn |
advice sammygeorge am 18.10.2005 – Letzte Antwort am 20.10.2005 – 9 Beiträge |
Advice needed for bass echoing panditr am 27.03.2005 – Letzte Antwort am 31.03.2005 – 22 Beiträge |
advice needed sammygeorge am 11.09.2005 – Letzte Antwort am 14.09.2005 – 29 Beiträge |
Need info & advice vinodt am 29.12.2004 – Letzte Antwort am 29.12.2004 – 5 Beiträge |
Help / Advice for building a new system kaliste am 03.01.2005 – Letzte Antwort am 07.01.2005 – 10 Beiträge |
Advice on stereo system Doc_hi_fi_novice am 07.04.2005 – Letzte Antwort am 07.04.2005 – 4 Beiträge |
Turntable advice needed Savyasaachi am 07.04.2007 – Letzte Antwort am 08.04.2007 – 3 Beiträge |
Advice Needed: Scalable/Futureproof Speakers particleman am 12.04.2006 – Letzte Antwort am 15.09.2007 – 43 Beiträge |
Need some advice concerning loudspeakers Jonny22 am 03.04.2005 – Letzte Antwort am 05.04.2005 – 30 Beiträge |
Advice on speakers Krish am 11.01.2005 – Letzte Antwort am 12.01.2005 – 15 Beiträge |
2006
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder928.513 ( Heute: 5 )
- Neuestes Mitgliedkaiserstuhlbruno
- Gesamtzahl an Themen1.558.357
- Gesamtzahl an Beiträgen21.700.600
