advice needed
sammygeorge
#1 erstellt: 11. Sep 2005, 13:33
Dear friends,
Just joined the group and am in need of some suggestions.
I have a Wharfedale 9.1 (a gift!) and am looking for anappropriate amp and deck to build a decent (not too costly) system based on it.
Would greatly value your suggestions/tips/help.
Sammy
Edges
#2 erstellt: 12. Sep 2005, 07:47
hey sam....
try out the marantz with the diamonds...i heard they are good for the diamonds but havnt experienced them yet.....give it a try.....
edges
abhi.pani
#3 erstellt: 12. Sep 2005, 07:56
Whats the amount are you willing to spend ?
sammygeorge
#4 erstellt: 12. Sep 2005, 13:18
say around 20 or 25K? The rest i will save for a good deck!
Thanks
Sammy
square_wave
#5 erstellt: 12. Sep 2005, 13:23
For that money..one choice...NAD C320bee.........You should get it around 19k.This will outperform most amps around 30k.
sammygeorge
#6 erstellt: 12. Sep 2005, 13:27
Thanks...is it available in bangalore and if so where? Any suggestions on a good cd deck to pair up with this combo?
square_wave
#7 erstellt: 12. Sep 2005, 13:43
I guess it is available with music ranch in Jayanagar.I don’t know their contact details. Someone on the forum might be able to help out. If you have the budget, get the C521bee cd player and you have a deadly combo. I guess the cd player sells for around 16k. I am not sure………..Even a marantz entry level player would match quite well. Keep aside some cash for the interconnect and decent speaker cables also…You need good stands also for the speakers for them to perform to their optimal level.
Dragonsage
#8 erstellt: 12. Sep 2005, 13:51
An amplifier for the same price will be the Cambridge Azur A 540. I heard it together with these Wharfedale 9.1 and it was a perfect combination. Just listen to it!
BR DA
diskspinner
#9 erstellt: 12. Sep 2005, 13:57
Right, you can get NAD from Music Ranch, Jayanagar 3rd Block (very near to Jayanagar 4th Block Market complex)...but it is (21k as quoted) and you may not get to audition it there. The guy at the store promised me he will be able to get it if I order.
NAD CD player is 17k (quote from same shop). But if you take 'em together you may burgain...
square_wave
#10 erstellt: 12. Sep 2005, 14:00
Yes, Cambridge audio is also a good option. In fact the NAD and CA are the best budget amps out there…….both are voiced differently though. I find the CA to be a bit laid back in its presentation while the NAD is a bit more punchy. Listen to both and decide for yourself…..
abhi.pani
#11 erstellt: 12. Sep 2005, 14:01
[quote="diskspinner"]NAD CD player is 17k (quote from same shop). But if you take 'em together you may burgain...images/smilies/insane.gif[/quote]
Sonodyne listening room at "The Forum" also stocks this CDP, they quote around 16k. You can audition them also as they use it as their standard cdp for demo.
[Beitrag von abhi.pani am 12. Sep 2005, 14:03 bearbeitet]
Dragonsage
#12 erstellt: 12. Sep 2005, 14:14
IMHO the cambridge well-balanced regarding tonality. It is easier to locate instruments with the cambridge. I prefer this kind of performance. Therefore I recommend to listen to both amps. Everbody must make his onw decision, because listing is a subjective perception.
BR DA
sammygeorge
#13 erstellt: 12. Sep 2005, 14:28
thanks for all the suggestions...very empowering for a newbie!
Just a small clarification...heard that NAD 320BEE doesnt have an input socket for phono. Is that true? Have a huge collection of lovely lps and it would be a pity if I cant listen to them! Any suggestions about amps that do have a phono input?
Manek
#14 erstellt: 12. Sep 2005, 14:34
nad does have a separate phone stage for tt's.
Dragonsage
#15 erstellt: 12. Sep 2005, 14:43
Optional MM phono available. Pls. have a look here:
http://www.audioplusservices.com/campbridge/540A.htm
Or on the cambridge page:
http://www.cambridge...tegrated%20amplifier
BR DA
square_wave
#16 erstellt: 12. Sep 2005, 14:57
None of the budget audiophile grade amps like NAD and Cambridge audio will come with an inbuilt phono stage. To give you a phono stage of equal caliber as the amp, they will need to increase the price quite a bit. So it is an option. Do not confuse this with cheap/useless phono stages which comes bundled with Japanese mass-market amps. There is no cheap way out for good phono sound. You will need a dedicated phono stage or you need to pick up expensive amps with good phono stages.
sammygeorge
#17 erstellt: 13. Sep 2005, 13:44
welcomesuggestions for cabling the wharfedale 9.1 and NAD 320 BEE...thanks
Manek
#18 erstellt: 13. Sep 2005, 13:54
I would suggest you try out qed from profx....nice interconnects at decent prices. monster is always there. then there is Mr murthy who is pretty well known in bangalore and then there is vdh, vivanco, and many more....
manek.
SNV
#19 erstellt: 13. Sep 2005, 15:45
Dear Sammy,
Well, if you are looking for an decent amp to drive the 9.1
with a phono input, then take a look at the Marantz PM4400.
Although it is rated at 30 watts, believe me its a very
conservative rating. The Marantz can easily drive the 9.1.
The other options would be Nad and Cambridge Audio.
These are one of the finest amps available at this price.
Nad has a seperate phono pre amp available.
On the cambridge audio, a phono stage can be fitted in the amp.
On the cables and interconnects you could opt for qed or vdh.
Do let us know what is it you opt for.
Regards
Jay
benkenobi
#20 erstellt: 13. Sep 2005, 22:49
Go for ordinary cables with more numbner of strands. u get wires with 180 strands for 30 bucks a meter..give it a try before spending a shitload on some fancy speaker wire.
regarding the interconnects, don't go overboard on those either. always remmeber that cables and all otehr snake oil items are secondary to your speakers and source and room.
Shahrukh
#21 erstellt: 14. Sep 2005, 08:41
My setup:
Wharfedale Diamond 8.1
Marantz SR4400
QED cabling
It's fantastic. What detail. I imagine it'll be a tad better with the 9.1s
benkenobi
#22 erstellt: 14. Sep 2005, 09:05
The 9.1 has better detail and lowend, but found the imaging to be better in the 8.1.
[Beitrag von benkenobi am 14. Sep 2005, 09:07 bearbeitet]
Shahrukh
#23 erstellt: 14. Sep 2005, 09:21
Really? I heard the 9.1 was better overall. Imaging and soundstage included. While I have demo'd the 9.1 at Designer Audio, I couldn't quite tell the difference 'cos I'm so used to listening to my 8.1s in the home environment. Guess I'll be able to if I did an AB of both in the same room.
benkenobi
#24 erstellt: 14. Sep 2005, 09:29
doesn't mean that what i say is a postulate.
see and judge for urself...just gave my view on this ..that's all..
Btw, are u the same sharukh from ecoustics?
sammygeorge
#25 erstellt: 14. Sep 2005, 09:49
Sorry to sound so naive...whats the difference between cables and interconnectors? I thought that cables are for connecting the amp to the speaker and to deck. Then what are interconnectors for? Are these cables cheap in UAE? I have a close friend there and can ask him to pick up.
kspv
#26 erstellt: 14. Sep 2005, 10:33
Cables are the wires that connect amplifier to the speakers. Interconnects are wires that connect source (a CD player, a tuner, a cassette deck, a record player, the pre-out of another amplifier etc.,) to the amplifier. Cables carry higher-voltage "speaker-level" output. Interconnects carry low-voltage "line-level" output. If your speakers are located far from your source, and if you have to choose between long cables and long interconnects, the norm in high-end audio is to use long interconnects and short cables.
Interconnects have leads (usually RCA males) on both ends, and to prevent oxidation of the metal surface and the consequent deterioration of sound, they are either nickel or gold plated. There is no qualitative difference acoustically between nickel plated and gold plated leads. Gold-plated leads just look better. Interconnects are available from the fairly cheap Korean & Japanese (Jacob, Sony) ones to the outrageously expensive ones. Sony actually makes fairly decent interconnects of solid construction. The risk of short-circuiting is less with factory-moulded interconnects, than with interconnects having separate wires and leads soldered together.
Cables in high-end audio are usually oxygen-free-copper wires of 12' guage (thickness of the skinned wire, and not with the plastic covering around) or less (lesser the guage, higher the thickness). Some audiophiles use 14' guage also. Cables usually do not contain leads, and are just slipped into the binding posts at the back of the amplifier. Cables should never be short-circuited, or else there will be a KABOOOOMMM...!!!
There is a lot of discussion on whether or not different types of cables and interconnects have a qualitative effect on the sound. Rod Elliot, a well known Australian hi-fi expert and designer, after a lot of study, has concluded that they do not make a difference. But certain other distinguished audiophiles believe they do!
[Beitrag von kspv am 14. Sep 2005, 10:47 bearbeitet]
Shahrukh
#27 erstellt: 14. Sep 2005, 10:55
Yes, benekobi, the very same.
sammygeorge
#28 erstellt: 14. Sep 2005, 12:24
Thanks ksvp! So informative and usefull...Now that my doubts are clarified, any suggestions on the cables and the interconnects...which brands? The earlier suggestion was for qed or vdh. Do they hold good for both? Any idea what the cost might be? Sorry to keep pestering...but I am on an upward learnig curve about hifis in the past two days (thanks to this forum and its helpful members)!!
kspv
#29 erstellt: 14. Sep 2005, 18:18
Interconnects:
Go to any major shop selling car accessories. Ask for Sony interconnects. These are factory-moulded and come in 1/2/3 meter lengths. Choose the length as per your requirement. They should be costing about Rs.250/-. They do not contain a joint between the RCA lead and the wire, and it is all in a single, thick, flexible plastic encasing. Thus, there is no chance of soldering coming off and resulting in a short-circuit (I blew up an amp once!) even if you use them very roughly. The contact portion of the RCA leads itself is gold-plated, and does not easily get oxidized. The wiring is made up of fairly thick oxygen free copper. I do not know how to post a picture in this forum, and so unable to post the photograph of the Sony interconnects. But do search on Google, and you will have an idea how they look like.
Cables:
As somebody on this forum suggested, normal copper wiring of 12' guage or less used for domestic wiring from Finolex is the cheapest option. If you think this is too unglamorous, and does not reveal your audiophile credentials, buy the unbranded 12' guage audio cabling available in almost all major showrooms selling audio separates. This cabling is mostly Taiwanese or Korean in origin, is of good quality, and looks good too! Never, ever buy audio cabling on Baazee (from personal experience). Some audiophiles also use the so called "Litz" wire (a wire containing multiple copper strands, each in its own isolated encasing, and interwoven with the other strands in a spiral, recurring pattern like the hair of a south-Indian woman). But there is no scientific proof that "Litz" wire will improve sound.
Read Rod Elliott's articles on audio. They will open your sonic third-eye. His article on interconnects & cables is here.
http://sound.westhost.com/cables-p3.htm#interconnects
If you are too keen on branded products, they would be available in most of the uptown audio showrooms.
[Beitrag von kspv am 14. Sep 2005, 18:29 bearbeitet]
Need your help, folks !
sandeep am 23.06.2005  –  Letzte Antwort am 24.06.2005  –  13 Beiträge
Biwiring - experiences and suggestions
raftuq am 09.06.2006  –  Letzte Antwort am 16.06.2006  –  7 Beiträge
Needing some vinyl advice and help.
Savyasaachi am 04.11.2010  –  Letzte Antwort am 17.12.2010  –  35 Beiträge
Suggestions Speaker stands and Subwoofer
kvish am 09.09.2006  –  Letzte Antwort am 20.09.2006  –  21 Beiträge
Turntable advice needed
Savyasaachi am 07.04.2007  –  Letzte Antwort am 08.04.2007  –  3 Beiträge
Budget amp and speakers. Help!!
Psycholic am 30.06.2005  –  Letzte Antwort am 30.06.2005  –  8 Beiträge
Suggestions for player
raj am 29.11.2004  –  Letzte Antwort am 03.12.2004  –  8 Beiträge
Hi-Fi suggestions
sanathan am 28.03.2005  –  Letzte Antwort am 29.03.2005  –  14 Beiträge
Headphone Cans Suggestions.
herculepirate am 31.05.2009  –  Letzte Antwort am 01.06.2009  –  3 Beiträge
Need advice for a friend in the U.S.
zhopudey am 01.07.2007  –  Letzte Antwort am 04.07.2007  –  17 Beiträge
2005
  • Registrierte Mitglieder929.118 ( Heute: 2 )
  • Neuestes MitgliedDavid2101
  • Gesamtzahl an Themen1.559.733
  • Gesamtzahl an Beiträgen21.733.687
