HIFI-FORUM » English » Stereo (Engl.) » Need some advice concerning loudspeakers | |
Need some advice concerning loudspeakers+A -A |
Jonny22
20:05
erstellt: 03. Apr 2005, |
Hello I have to buy some new speakers for my Technics SU-8055 Amp. They shouldn`t be to expensive because I`ve only got a limited budget.(student) My room has got 23 sqm and is 3 m high. What kind of speakers would you recommend for a low budget. Thanks Jonny |
Manek
06:34
erstellt: 04. Apr 2005, |
Entry level speakers could be wharfedale diamond, athena. Bookshelves would be ideal but what music do you listen to ? How much is your budget ? approx 200 US ? |
SUB_BOSS
Gesperrt |
06:43
Manek how do you rate Athena's and heybrooks to other brands priced similiarly?? |
Manek
07:15
SUB BOSS, To be honest..I did like the heybrook as an entry level speaker..they went out of the market here in bombay and I believe have re-surfaced. They are made by peerless audio india now. Anthena's, heybrook, wharfedale etc are kind of similar in the basics but are voiced a bit differently. So depending on the music you listen to, the choice is made. Athena are popular in US/canada for entry level speakers and are really good for their pricing(my brother started out with the athena's and still maintains they are one of the best entry level speakers around). So are the polks and wharfedales. BTW wern't you the guy who heard polks and like them ? I heard the RTI10 floorstander yesterday costing 46k....not bad at all but with a hot tweeter....I also heard the higher end LSI8 bookshelf, I quite liked the sound of them....liked them very much infact. I thought they were a bit over priced at 48k(some may pay the asking price) but their soundstaging ability was quite good, far beyond the speaker boundary. Its the only other speaker other than the cadence diva/arita I have heard under 50K which quite disappear and throw such a nice wide soundstage with decent height. The depth was missing but the speakers needed to be set up better in a better room. Imaging was decent too. Tonally I liked them...there were a few piano notes which did not sound too believable but that I am sure was due to the room as it had a lot of glass so that might be ringing. Over all I quite liked the polk LSI8. Need to hear them some more of the same. Manek. |
Jonny22
08:33
Mostly guitar music but some classic too. (depends on the mood) 200 US would be fine with me as long as they are worth the money. I never heard of Athena before.I`m going to check them out right now. |
SUB_BOSS
Gesperrt |
08:40
Manek, Listened to the Moitor 60's and very impresed at 24k.i woul strongly recommend some one who will spend 20-25 for a Flrs.BTW got to check out RTI10 as there were not in tock when i visited Profx....You know I really liked the set up at Profx where you get to compare KEF's and polk's in the same room surroundings with same sources...gotto check out wharfs.....ben and others seem to be giving rave reviews abt them........ |
Jonny22
08:43
I had a look at the wharfedale`s. I like them but they all seem to have 6 ohm. I need 4 for my amp if I use 2 ohm speakers and 8 ohm if I use 4 speakers.(I can`t afford 4) Is it nevertheless possible to use them? |
Manek
09:39
johnny, I take it you are looking for a stereo setup right ? then why more than 2 speakers ? manek. |
SUB_BOSS
Gesperrt |
10:25
Johhny Even i outgrew this phase of having speakers around for stereo as few members might remember........but didn't do it..........HT phase...didn't get into it.............now I'm dyin to have a good stereo set up.coz you listen to music 100 times repetetively.but how many times will u watch the same scene with xplosions and car chases. etc.......oops I know there are going to be contradictions now. ![]() ![]() cheers.... ![]() |
big-ears
10:33
Sub, Don't ![]() ![]() ![]() |
SUB_BOSS
Gesperrt |
10:34
every now and then you are the one who would bring some humuor into our forum.......keep it coming sir ![]() |
Jonny22
12:40
Yes i`m just looking for a stereo setup. But the question was if my amp has got an impedance of 4 ohm can I then use speakers with 6 ohm? If not wharfedale is out of the race. |
Manek
12:42
if your amp has a power rating at 4 ohms then a 6 ohm speaker will do nicely. manek |
SUB_BOSS
Gesperrt |
12:44
Normally there is no harm in going for higher impedance,,,,,,but going in for lower impedance than specified strains or might be damages your amp. |
Jonny22
12:49
Ah ok. Didn`t know that. So higher Impedances generally work fine? Or is there a limit? Or is the sound getting worse? Would 8 ohm be possible too? |
SUB_BOSS
Gesperrt |
12:56
ideally 8 ohm speaker will not harm your amp man go thru this and you'll know what impedance is.. ![]() |
ravi
12:59
you would keep getting lower and lower max power output as you go higher in speaker impedance. So an 8 ohm speaker would give half the power output of a 4 ohm speaker, at the same amp level setting. I would suggest to stick closer to the amp rating, such as 4 or 6 ohms to get the max power output - other than that, safety and sound quality are not affected as you go higher. |
Jonny22
13:03
Thanks for the link. I understood that point. Shuld`ve thought about that point earlier. Now I can have a look at the Wharfedales. I thought about Diamond 8.1 or if I can get them 8.4 |
SUB_BOSS
Gesperrt |
13:04
yup if your amp is 4 ohsm you can safely use 6 ohms and as ravi mentioned the higher you go the lower the max power .there are many brands with 6 ohm speakers.... |
Manek
13:05
actually 8.2 are worth auditioning if you can, more bass, bigger sound. manek. |
big-ears
16:15
Hi Jonny, If your amp is rated at 4 ohms, it should very easily drive 6 and 8 ohms speakers. The problem arises when you do things the other way. A 4 ohm speaker places a significantly higher load on an amp rated at say 8 ohms and if the amp cannot meet this load, it results in distortion and clipping, thereby damaging the speakers. [Beitrag von big-ears am 04. Apr 2005, 16:17 bearbeitet] |
Jonny22
16:31
How is the magnat vintage 120 by the way. Is it worth 200 Euros. Or should I keep away of Magnat? |
Jonny22
18:57
Hello again. I found Wharfedale diamond 8.2 for 64,99 Euros each. That means a pair of them would cost me 129,98 Euros. If you say the price is fair and those are good speakers I think I`m going to buy them tomorrow. |
Manek
05:40
erstellt: 05. Apr 2005, |
did you hear the 8.2 or are you buying them blind ? |
Jonny22
07:35
#25
As most people say they are worth their money I planed to buy them blind. |
Manek
07:43
#26
is there no way you can hear them or any other similarly priced speaker ? |
Jonny22
07:50
#27
Unfortunally there is no way to hear those. If I don`t like them I^m going to send them back. Have you ever listened to them? |
abhi.pani
07:59
#28
can try Polk Audio... |
Manek
08:19
#29
I have heard the 8.2 many times and it really is hard to find a speaker that sounds like it for that price. so its definately a value for money deal. If you have the option of sending them back and not paying for them then I guess you could give them a shot. manek. |
Jonny22
08:23
#30
I think I will give them a chance. I will tell you if I`m satisfied with them. Thanks a lot for the help. Jonny |
Need info & advice vinodt am 29.12.2004 – Letzte Antwort am 29.12.2004 – 5 Beiträge |
advice needed sammygeorge am 11.09.2005 – Letzte Antwort am 14.09.2005 – 29 Beiträge |
advice sammygeorge am 18.10.2005 – Letzte Antwort am 20.10.2005 – 9 Beiträge |
Need advice on really cheap amps sandipb am 23.11.2007 – Letzte Antwort am 26.11.2007 – 5 Beiträge |
Help! I need some components. benkenobi am 28.06.2005 – Letzte Antwort am 01.07.2005 – 11 Beiträge |
Needing some vinyl advice and help. Savyasaachi am 04.11.2010 – Letzte Antwort am 17.12.2010 – 35 Beiträge |
Turntable advice needed Savyasaachi am 07.04.2007 – Letzte Antwort am 08.04.2007 – 3 Beiträge |
New System advice soonbaboon am 04.01.2004 – Letzte Antwort am 05.01.2004 – 2 Beiträge |
SOME SERIOUSNESS NEED BADLY ON THIS FORUM Prithvi am 04.04.2005 – Letzte Antwort am 08.04.2005 – 29 Beiträge |
Some knowledge SUB_BOSS am 13.06.2005 – Letzte Antwort am 13.06.2005 – 9 Beiträge |
2005
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder928.479 ( Heute: 12 )
- Neuestes Mitgliedclaribelrimmer
- Gesamtzahl an Themen1.558.307
- Gesamtzahl an Beiträgen21.699.415
