What is the best way to clean your woofer cones ?
square_wave
#1 erstellt: 27. Sep 2006, 08:21
I never have the grilles on so a thin film of dust has settled on them.
Arj
#2 erstellt: 27. Sep 2006, 10:39
depends on what the composition of the cone is..most do not take kindly to water and definitely not ot any solvents.
Dry soft cloth usually works used lightly..but better speak to Siva on his recommendation as it can be very Woofer specific !
SUNILYO
#3 erstellt: 27. Sep 2006, 11:53
What about a small/mini blower (something used to clean electronics). I think that should do the trick
or what about using a soft brush.
purnendu
#4 erstellt: 27. Sep 2006, 11:54
I wonder if playing them loudly would not get the dust off!
Purnendu
Amp_Nut
#5 erstellt: 27. Sep 2006, 12:15
Use a paint brush ... about 2 inches wide, as used for painting walls.
I prefer to select a stiff brush, or trim the bristle lemght, to make it more stiff.
The white Nylon bristle Paint brush is pretty stiff and nice.
The brush is a Wonderful cleaner not only for Speaker cones, but also inside amplifiers, CD players etc.
For Crevices, use a soft tooth brush. GREAT to dig dust out from Grooves in the front or side panels, or around Knobs and buttons....
SDhawan
#6 erstellt: 27. Sep 2006, 12:15
Hi !
Try using a blower brush. You could buy one from a camera shop - one used to clean lenses.
I like Purnendu's idea - play it loud to scare the dust away
I have a question too - I'm always scared of the occasional rats in the house. My down -firing Sub seems precariously within the reach of the mighty mouse. So far so good but how to prevent the rats from feasting on the Low Cal (read frequency) diet?
Regards
Sanjay
square_wave
#7 erstellt: 27. Sep 2006, 13:20
I was thinking a softer brush would make it more safe than a stiff one....basically to avoid scratches on the cone...
Amp_Nut
#8 erstellt: 27. Sep 2006, 14:57
Sorry, I was Assume ing ( Ass-u-me ing ) a paper cone.
A Non wire brush would be OK for a paper cone....
soulforged
#9 erstellt: 27. Sep 2006, 16:33
I use a make-up brush, they have very soft bristles so you don't run the risk of damaging the cone. You can also use a piece of velvet or a soft hair shaving brush.
Blowing out the dust using a small blower is a good idea too. You just need to be careful that you don't blow them into the crevices.
[Beitrag von soulforged am 27. Sep 2006, 16:34 bearbeitet]
Arj
#10 erstellt: 27. Sep 2006, 19:28
if its dust i dont do anything to it..unless you got something other than dust !
SUNILYO
#11 erstellt: 28. Sep 2006, 05:11
any idea how can i clean the drivers with fixed grilles (metal). should i use a blower ???
the actual color has changed from red to brown!!!
square_wave
#12 erstellt: 28. Sep 2006, 05:58
What can’t harm the delicate female skin can’t harm the woofer right ?? Good logic..……..I can’t wait to see the look on my girlfriend’s face when I am confronting those woofers with a L’Oreal brush !
[Beitrag von square_wave am 28. Sep 2006, 05:59 bearbeitet]
soulforged
#13 erstellt: 28. Sep 2006, 16:47
square_wave schrieb:
What can’t harm the delicate female skin can’t harm the woofer right ?? Good logic..……..I can’t wait to see the look on my girlfriend’s face when I am confronting those woofers with a L’Oreal brush ! ;)
If you really wanna play with fire, take her to the beauty shop and pick up the most expensive brush...then tell her that its actually for your speakers...
SDhawan
#14 erstellt: 28. Sep 2006, 16:51
Hi !
In any case these for our "loudspeakers" - some producing noise & some music
Good that this forum comprises of predominently the unfair sex
Regards
Sanjay
[Beitrag von SDhawan am 28. Sep 2006, 16:53 bearbeitet]
neono
#15 erstellt: 29. Sep 2006, 16:27
SDhawan schrieb:
Hi !
Regards
Sanjay
Again play it loud sir..
SUNILYO
#16 erstellt: 30. Sep 2006, 05:09
how bout a solution for this one
Kamal
#17 erstellt: 02. Okt 2006, 10:36
If the speaker has a metal grill in frint which can't be easily removed, then the best option would be a blower;if you have a vcuum cleaner, there shoud be an attachment with a small nozzle which can be used; just use the least amt of air pressure/keep the nozzle at a distance and then checking from time to time, vary the pressure/distance.
One has to do this cleaning off& on to avoid build up of hard dust deposits( it hardens post the humid season).
As for the colour change, most prob its due to direct or even indirect sunlight It happened with my woofers also till i started covering them up when not in use, and drawing curtains to make sure that sunlight direct/reflected never falls on the cones, otherwise after some time it could degrade the material of the cone & importantly, of the surround material.
If the grill can be taken off, a clean(no make up residue!) soft makeup brush is the best since it wont scratch the cone-I snitched my wifes brush and I feign innocence whenever she puzzles as to where it has gone!( women are not very sensitive to the fact that speaker cones are more important!)
Dr Sanjay, and all others too, plz make it a practice to cover up the speakers( plastic covers are best since cloth covers retain dust) when not in use;ours is a dusty climate & prevention is always good. For the down firing subwoofer,you could use something to fill the gap between the floor & the S/W cone when not in use, e.g.a peice of sponge/ foam,Inverted shallow plastic tray whivch would fill the gap yet not press against the driver etc
[Beitrag von Kamal am 02. Okt 2006, 10:41 bearbeitet]
SUNILYO
#18 erstellt: 03. Okt 2006, 05:39
Thanks Kamal,
I used a compact vaccum cleaner which had the option of attaching a nozzle to the back of it and use it as a blower.
Atleast 50% of the dust came off but the rest are still resting as you said might be due to the humid conditions and since i havent cleaned it since i bought it so it must have really hardened it.
deaf
#19 erstellt: 11. Okt 2006, 08:09
Use surf excel with lots of water,that will really clean it up .But seriously,use your own fingers very lightly on the cone,and do not touch the dust cap.
Deaf.
Kamal
#20 erstellt: 11. Okt 2006, 08:19
Deaf,he has a metal grille which he cant remove easily to get at the cones-surf would sure do the trick but we would have to run for our lives when he views the results !
Seriously, Sunil, just repeat the blower thing a few times-you could try it while playing some bass heavy stuff- the vibrations could help dislodge the stubborn stuff.
Regards,
Kamal
neono
#21 erstellt: 11. Okt 2006, 12:24
what'il happen if we attach the vaccumcleaner tube to the front..
SUNILYO
#22 erstellt: 11. Okt 2006, 12:36
It'll clean the driver completly making it invisible as it'll suck the cones from the basket
Jokes apart! i think that wont help as the metal grille cannot be removed and the distance wont allow the vaccum cleaner to remove the dust as efficently.
sunil
SDhawan
#23 erstellt: 11. Okt 2006, 14:11
Hi Sunil !
Is the dust bothering you ?
Just let it be ....
The right way to create your own audio CDs
sandipb am 22.11.2007  –  Letzte Antwort am 23.11.2007  –  20 Beiträge
interconnects
filmguy am 29.11.2004  –  Letzte Antwort am 11.12.2004  –  10 Beiträge
WORLDS BEST AUDIO SYSTEM
Sonic_Master am 26.04.2005  –  Letzte Antwort am 26.04.2005  –  30 Beiträge
Your signature
SUB_BOSS am 04.12.2006  –  Letzte Antwort am 02.01.2007  –  109 Beiträge
Which Way To Go?
kspv am 16.09.2005  –  Letzte Antwort am 24.09.2005  –  71 Beiträge
What Floats YOUR Audiophile Boat ?
Amp_Nut am 14.12.2009  –  Letzte Antwort am 13.07.2010  –  40 Beiträge
What Cables to use ??
abhi.pani am 19.01.2005  –  Letzte Antwort am 19.01.2005  –  6 Beiträge
what type of reciever would best suit my wharfedale speakers
Pvikid am 13.01.2005  –  Letzte Antwort am 14.01.2005  –  6 Beiträge
What is Wow & Flutter?
philipmorris am 24.07.2006  –  Letzte Antwort am 24.07.2006  –  2 Beiträge
What is your personal preference : Pure Stereo or HT?
Prithvi am 28.04.2005  –  Letzte Antwort am 29.04.2005  –  20 Beiträge
2006
  • Registrierte Mitglieder928.479 ( Heute: 7 )
  • Neuestes Mitgliedeunicen907643281
  • Gesamtzahl an Themen1.558.305
  • Gesamtzahl an Beiträgen21.699.377
