HIFI-FORUM » English » Stereo (Engl.) » Lyrita's Fostex based speaker | |
Lyrita's Fostex based speaker+A -A |
stevieboy
10:20
#51
erstellt: 26. Mai 2008, |
hi rajiv, is that rca metal one a tube one? never came across one before. did come across a metal rectifier but it was solid state shaped like the rca all copper body. the bel's sound the best out of the lot right? do you have any idea on what 2A3s would sound better than the shuguang? most of my ideas are unfortunately based only on net research on the options to date. regards |
sivat
11:05
#52
Manek, There was hardly any takers for the valve-preamp kit. So we have dis-continued it. Regards Siva. |
Amp_Nut
14:40
#53
Manek said:
My limited knowledge on the subject is that these are Unique. Maybe someone on the forum knows otherwise ? Do share. |
Gelscht
Gelöscht |
15:41
#54
Hi Steve, The RCA ia a tube rectifier.Instead of a glass envelope,it has a metal envelope. There are diferences in the sound using the various brands of rectifiers.The basic sound of this amp does not change,but there are slight tonal changes.It all boils down to ones preferences. I have used only NOS rectifiers so I do not know what the new production tubes sound like.The BEL is a very good rectifier. The BEL factory was set up with help from Mullard,and the tooling was suplied by them.The BEL GZ 34 was made using GE parts.Other BEL valves are as good as the vintage NOS . ![]() As far as the 2A3 tubes are concerned the tubes supplied by Viren, the Shuguang 2A3C are the best new production tubes at reasonable prices.The prices of NOS 2A3 tubes are way to high.New production 2A3 from emmision Labs are supposed to be very good ,but very expensve. Regards Rajiv |
Manek
16:15
#55
Hi siva Sorry to hear that. The preamp I heard was good. But then again you are not the one to give up are you ? You have discontinued the kit but how about a fully built one ? My post actually refered to your solid state power amp. Isn't that what was compared to the plinius ? Or am I missing something here ? Manek |
viren
04:10
#56
erstellt: 27. Mai 2008, |
Hi, Work is progressing on a more powerful SET amp, but at its own pace. Looking at another slew of transformers, from design to production, is a big enough headache, albiet a pleasant one! The 845 SET, will be operated at lower voltages, sacrificing on power, but not sound quality. Makes it a lot easier to implement. Hoping to get about 15 watts of single ended power. Also, looking at a 6C33C SET amp, operated in triode mode. Though not a DHT valve, it runs at much lower voltages, making for an easier design. Should get about 15 watts out. The Shuguang 2A3C valves are really good sounding ones. I happen to have old RCA double plate 2A3s, and the Shuguangs sound better. The single plate version is the way to go. Viren |
sivat
05:35
#57
Manek, Fully built ones are available...but are made against orders only. Specifially with power amp, we happen to carry a couple of new ones in stock..ready to go. ![]() Regards Siva. |
stevieboy
06:42
#58
thanks for the link rajiv. good to know made in bangalore rocks! re the 2A3s i figured the KR enterprises ones might be better but that's way way too expensive! there was a link on some forum a guy had compared a host of 2A3s and found the shuguang 2A3C very musical and better than some popular names. will see if i can dig that out. viren can you list out the 2A3 tubes you compared against the shuguang? so i can cross them out and make a list for whenever i can explore some options? its fun exploring tubes! cant really swap out a transistor and have fun ![]() thanks! |
Manek
16:26
#59
erstellt: 30. Mai 2008, |
Viren The valve for rectification that I use in your preamp is the bel. Unfortunately I haven't had the chance to roll rectifiier tubes in this amp.my other tube amp has solid state rectification. What kind of change can I expect from say another good nos ? Manek Manek |
Manek
07:13
#60
erstellt: 31. Mai 2008, |
And...viren what upsides and downsides did you find with valve rectifation vs solid state. |
viren
14:17
#61
Hi Manek, Your preamp uses the BEL EZ80 rectifier. I really haven't tried out any other rectifier. The current requirement is low, about 25mA, so even this rectifier is just coasting along. A friend substituted a JJ EZ81, which has a slightly higher current rating, for a BEL EZ81, in his amp, and heard a big difference. You could try out the JJ EZ81 too - it'll go into the preamp directly. Valve or solid-state rectification, again, it's a subjective thing. Both work well. But valve rectification certainly improves the sound - there's more of a sense of flow to the music, and instrument harmonics are reproduced better. With that, for me, there are no downsides. Viren |
Manek
08:31
#62
erstellt: 01. Jun 2008, |
Viren, The ez81 would you consider it a safe replacement ? Secondly, did bel make 6sn7 tubes ? If they did how do they compare to the sylvanias or the kenrads ? Btw am back to the kenrads again. Can't make up my mind yet :-) the kenrads do have solid bass, more extended than the sylvanias and more balanced in their presentation to my ears. Btw any plans to make preamp sections with the 12Ax7 or 12Au7 tubes ? Just curious. Manek |
viren
03:32
#63
erstellt: 02. Jun 2008, |
Hi Manek, The EZ81 rectifier will fit right in in the preamp. No, the 6SN7 valves were never made in India. They are still in production in Russia and China, but don't sound as good as the NOS ones from the US. Look on each brand as a different flavour, not necessary to pin one down as better than the other! I've already worked with the 12Ax series, and really don't care for them. Other valves are so much better. Though, I am forced to use them in very high gain stages, such as phono preamps, because of their lower noise specs. Viren |
Manek
03:49
#64
Viren Each are a different flavour and that's why I keep rolling and can't stop :-) Any other valve you think would do well in a preamp besides 6sn7 and 12Ax ? Manek |
bhagwan69
15:20
#65
erstellt: 02. Apr 2010, |
what a great finish !! super.. ![]() this is a great product - super value... ![]() ![]() |
Krish
13:05
#66
erstellt: 04. Apr 2010, |
Dropped into Viren's after a really long time. Sat down for a listen to his Harmony 1 and the 2A3 SET amp. If you are a fan of Jazz trios, quartets, chamber music and do not have a auditorium size living room to fill with sound, look no further than this combo. Detailed yet warm and very intimate.The bass is quite a surprise.Quite detailed and full for a single driver. Cannot be beaten at this price or perhaps even twice that. K |
10 questions on computer based audio Arj am 02.02.2009 – Letzte Antwort am 30.05.2009 – 28 Beiträge |
Need help on speakers and speaker cable Ronnie22 am 13.04.2005 – Letzte Antwort am 14.04.2005 – 8 Beiträge |
Speaker cable and Interconnects advice needed Ronnie22 am 14.04.2005 – Letzte Antwort am 21.04.2005 – 5 Beiträge |
Speaker Help txs_dude am 22.02.2004 – Letzte Antwort am 23.02.2004 – 3 Beiträge |
Speaker Cables deepug am 24.02.2005 – Letzte Antwort am 28.02.2005 – 21 Beiträge |
speaker sensitivity TROJAN_HORSE am 04.03.2005 – Letzte Antwort am 04.03.2005 – 6 Beiträge |
Speaker cables myriad am 18.04.2005 – Letzte Antwort am 21.04.2005 – 9 Beiträge |
SPEAKER HELP MetalDave am 26.06.2005 – Letzte Antwort am 26.06.2005 – 6 Beiträge |
Speaker Stands Shahrukh am 30.08.2005 – Letzte Antwort am 01.09.2005 – 9 Beiträge |
SPEAKER IDEAS purnendu am 15.02.2006 – Letzte Antwort am 22.03.2006 – 70 Beiträge |
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder928.550 ( Heute: 7 )
- Neuestes Mitgliedjojoharis92
- Gesamtzahl an Themen1.558.469
- Gesamtzahl an Beiträgen21.703.058
