Needing some vinyl advice and help.
Savyasaachi
#1 erstellt: 04. Nov 2010, 11:00
Am at those croossroads again where am looking into getting a vinyl rig.
What is a good beginner turtable? I was planning on DIying a phono preamp..possibly the aikido or the pass pearl.
For the table i am at a loss...is the Linn LP12 any good..I doon't know if i can buy it just yet, but a used onee turned up for about 1000USD with a valhalls PSu ( no idea what this is),, RB300 arm and an ortofon Om30 cartridge..
High possibility that I might be able to buy it soon enough for aomeone else to snap this up.
Nevertheless I would like to learn about vinyl rigs and how to go about getting/setting one up..and importantly the costs involved and the essential must haves for a vinyl rig.so let us have it you geniuses.
[Beitrag von Savyasaachi am 04. Nov 2010, 11:05 bearbeitet]
Arj
#2 erstellt: 04. Nov 2010, 16:31
i am a novice too and had considered turning over to the dar side (or bright side..whatever). basically there are 2 views from how I have been adviced from quite a few folks.
i. Majority of the LPs you play to spin are the oldies and used: dont buy any of the newer TT/Carts as they are very detailed and may be an overkill for it. so the Linn/Rega/Garard etc etc would be really cool.
ii. Majority are the newer pressings which you have/plan to buy: while the Linns and the Regas would still be good, you can do a lot more with the newer Rigs like Clearaudio/ VPI/ Scheu...and other brands.
I am still confused whether i can manage a TT as
1. Isolation: 10 times more important than for a CD transport..$$$
2. TT consists pf the TT, Tonearm, Cartridge and Phono Pre...and all permutation combinations and tweaks can impact the sound and drain you of $$$
3. Maintainance of LPs :to get the best sound you need to clean ti before use, cannot replay too many times as it would damage the LP and cannot choose individual tracks
4. I cannot stand the hiss/crackle and Pops
But in spite of the the sound is supposed to be worth it...
Since I dont have any old LPs and for the money i would need to spend on the newer ones i could really get myself a Super HDD based setup..so I am not progressing although still harbor the secret desire that an old relative will leave me with lots of Old LPs and one of the above TTs
[Beitrag von Arj am 04. Nov 2010, 16:31 bearbeitet]
abhi.pani
#3 erstellt: 04. Nov 2010, 20:18
Sachi, my experience with TTs have been just on and off. I cannot say I have listened to many TTs or have a lot of experience, far from it, at least compared to CDPs.
All I can say that the best sound I ever heard from a TT was a Linn LP12, the Tonearm and Cartridge was some average Rega stuff.
Other than the Linn I have heard an SME, SOTA, Clearaudio and few more in Spore (the brands I dont remember). But nothing sounded as musical as the Linn.
bombaywalla
#4 erstellt: 05. Nov 2010, 21:11
Nevertheless I would like to learn about vinyl rigs and how to go about getting/setting one up..and importantly the costs involved and the essential must haves for a vinyl rig.so let us have it you geniuses. 8)
Savya, there's a lot to spinning vinyl than what meets the eyes. Arjun has referred to the "obstacles" that would need to be surrmounted & it can get very hairy indeed. It's tweakers heaven, if I may say so.
The best starter TT I think is the Music Hall MMF2 or MMF5. It's as plug & play as they get. I used to own an MMF5 so I should know. The default Goldring MM cartridges it used to come w/ are pretty darn good. The cousin to the MMF series are the Pro-ject TTs.
The Linn Sondek is a very good SUSPENDED TT. If you know how to setup a suspended TT, go for it. OR, suffer the losses as you learn how to set it up correctly. The Linn tonearms themselves are very good matches for their TT & so are the Rega tonearms.
I'm not crazy about those series of Ortofon cartridges (the more recent ones are way better but also -w-a-y- more expensive) but if the Linn TT is coming w/ the Ortofon as a package deal, it will do just fine.
I won't even try to get into phono preamps......
abhi.pani
#5 erstellt: 06. Nov 2010, 05:27
Bombaywalla, what would be a good starter phono preamp in your opinion. Something that does justice the MMF5 and overall plays well compared to a good digital rig.
Arj
#6 erstellt: 06. Nov 2010, 08:12
way to go abhi....
abhi.pani
#7 erstellt: 06. Nov 2010, 08:20
Arj schrieb:
way to go abhi.... :KR
just increasing my knowledge base arj..
bombaywalla
#8 erstellt: 08. Nov 2010, 03:35
hmmmmmmmmm..............
Abhi, there might be a contradiction in your question: a good starter phono preamp and plays well compared to a good digital rig. A good digital rig can play quite well if setup correctly hence one would have to spend quite a bit to surpass such a rig.
From whatever little I know about phono preamps some of my (personal) recommendations are
* the venerable Creek OBH-15 & OBH-18 units.
* the Music Hall PA 1.2
* the well regarded NAD PP-2i & PP-3i unit
* if you feel that your pocketbook can sustain it then the Goldenote (used to be called Bluenote) Pamphili unit is very analog-y sounding: musical yet detailed. If the cost is too much then their next lower phono preamp - the Phono2 is also very good. NOTE that both the Phono2 & Pamphili use a heavily choke-regulated supply which is a very good thing to supress power supply ripple for the circuitry processing the low amplitude phono signal.
<<< don't know why this got posted twicee??? Disregard this post & read the next one. Thanx. >>>>
[Beitrag von bombaywalla am 08. Nov 2010, 03:42 bearbeitet]
bombaywalla
#9 erstellt: 08. Nov 2010, 03:40
Abhi, there might be a contradiction in your question: a good starter phono preamp and plays well compared to a good digital rig. A good digital rig can play quite well if setup correctly hence one would have to spend quite a bit to surpass such a rig. So, I do not know if such a unit exists or not.
* the venerable Creek OBH-15 & OBH-18 units. The OBH-8 is the older model which is still very well regarded & the main-stay of many a starter vinyl rig.
* the Music Hall PA 1.2, which should be a very good match for a MMF TT.
* the well regarded NAD PP-2i & PP-3i unit, which have been around a -l-o-n-g- time.
hope that this answers your question, Abhi.
(stop snickering in the background, Arj! )
Arj
#10 erstellt: 08. Nov 2010, 05:30
I see Shelf Space also increasing.... ..its called new relationship on the rebound (Since you have just sold off your dac)
BTW Viren makes a very good Tube based Phonostage..so that is too a good option
did not realize i was being so loud
[Beitrag von Arj am 08. Nov 2010, 06:58 bearbeitet]
Shahrukh
#11 erstellt: 08. Nov 2010, 09:05
Abhi, please don't disregard the ProJect phono pre. Their tube based Tube Box is a decent starter phono pre.
Amp_Nut
#12 erstellt: 08. Nov 2010, 16:49
I fully agree with Shahrukh, .....and its available here in India....and... its decently priced....
Project even has a Phono Pre with a USB output, for direct recording from the TT to HDD...
[Beitrag von Amp_Nut am 08. Nov 2010, 16:51 bearbeitet]
bombaywalla
#13 erstellt: 09. Nov 2010, 04:41
yes, the Pro-Ject phono pre should also be a very good starter unit. I have no inside knowledge of this unit hence I did not put it down in my list in my earlier post. Looks like Shahrukh & Amp_Nut know a lot more about it & endorse it so that's a good sign.
Pro-ject TTs are very highly regarded (made in the same factory as Music Halls - atleast used to be) so, as an extension, their phono stage should also be a good starter unit (tho' this is not always the case).
hopefully Abhi's knowledge base has increased a little more now....
[Beitrag von bombaywalla am 09. Nov 2010, 04:42 bearbeitet]
ani
#14 erstellt: 10. Nov 2010, 06:42
I would like to bring to notice few points regarding TT isolations. In Indian conditions turntable isolation takes different perspective due to nature of our basic building construction.
Most of us have solid concerete floor to start with. Those on ground floor will find it easy.
A stable table to support your table can be placed sufficiently away from the speakers to reduce direct excitation by them.
A Non suspended player placed on such a table can perform far better than most of the inferior suspended designs.
Project do have a wide range of TT and Phonostages to start the spiralling journey on Vinyl disc.
I have used their Phono Box SE as well as Tube Box SE. Both are very good starting blocks, Tube box can be exteneded little futher up.
The Speed Box is another one that will open up a new area to TT users. It will sure change your listening pleasure to new heights exp. if you are in area fed by poor quality power.
Now all that is left are the collection of black discs.
Shahrukh
#15 erstellt: 10. Nov 2010, 09:44
By this, do you mean rolling the tubes?
ani
#16 erstellt: 11. Nov 2010, 05:40
Tube box can be used in midfi level too.
bombaywalla
#17 erstellt: 11. Nov 2010, 18:58
Ach, I *think* that I understand what Anil meant to write in the 1st place - I *think* that he meant that the Pro-Ject Tube box is good enough for one to carry forward in one's rig even as the other components are upgrded because the Tube Box itself will (according to him) hold its ground.
Shahrukh, yes, I would imagine that you could tweak its sonics by tube rolling the 12AX7 tubes. So, tube rolling in addition to potential having this unit long-term (per Anil).
Shahrukh
#18 erstellt: 12. Nov 2010, 10:49
Well that's good news to me cos I sold off my entire vinyl rig but kept the Tube Box 2.
Savyasaachi
#19 erstellt: 16. Nov 2010, 09:33
Thank you all for the answers so far. I am torn between buying a Stax O2 MK1 headphones and the Linn LP12 that's on sale locally. Apparently another one popped up on the same website., comes with a lustre arm which looks gorgeous.
Anyways, I am reading this thread just not been able to respond since i've been away in San Francisco this past weekend and just got on the second week on my new job.
I might put away the purchase till i move to a new place, preferably closer to work, no room mates and most importantly NOT an apartment so i can finally get back to speakers and have a garage to park my motorcycle and car in.
Bombaywalla, how is the Pass pearl phono in the world of preamps?
Amp_Nut
#20 erstellt: 16. Nov 2010, 09:51
Have you HEARD the STAX 'EarSpeakers' ?
The sound is Very different - Rather 'Light' and not to everyone's taste... even though that is not what the reviewers will say
Savyasaachi
#21 erstellt: 16. Nov 2010, 10:05
yes i have on multiple occasions. i have the 404s on extended loan from a local friend and the SR-003s from another friend in Denver. I do agree that they do feel light in comparison. The O2 however gets closest to the ortho sound that i like while bringing the lightnness and airiness ot the table as well.
But the older Mk1 SR-007 still cost about 1.4k USD.
Amp_Nut
#22 erstellt: 16. Nov 2010, 15:16
FWIW,,,, I still have my STAX SRS-2020 Basic System II for sale, at a VERY attractive price. Auditions welcome ..
[Beitrag von Amp_Nut am 16. Nov 2010, 15:20 bearbeitet]
bombaywalla
#23 erstellt: 17. Nov 2010, 02:49
Savya,
The Pass Pearl is supposed to be a very good phono stage per what I have read but I have no personal experience with it so I cannot comment in more details.
Savyasaachi
#24 erstellt: 19. Nov 2010, 01:43
ok..i'll just go ahead and build one then. ALso looking at the Aikido phono stage as another option. I am quite close to makiung an impulse purchase on the rega RB300 arm based Linn LP12
Arj
#25 erstellt: 19. Nov 2010, 02:47
are you sure you want an LP 12..that along with the Garrad are overpriced in the market today ?
try to get used Thorens 124/ Lenco L75/78 and tweak the hell out of it.. just google for more info.
really interesting read here
http://www.high-endaudio.com/RC-Tables.html
Savyasaachi
#26 erstellt: 19. Nov 2010, 04:56
Well, I can get this LP12 for about 900$.
There is this THorens TD125 Mk1 avilable locally as well for 450. I have met this person before and he is a serious audiophile, lots of nice equipment and he knows his stuff.
What do you guys suggest?
oops..here are the links
LP12..its there under current inventory -> turntables ..listed at 975 but i know i can talk him down to 900.
http://www.echohifi.com/
Thorens
http://portland.craigslist.org/mlt/ele/2064024070.html
[Beitrag von Savyasaachi am 19. Nov 2010, 05:01 bearbeitet]
Arj
#27 erstellt: 19. Nov 2010, 08:33
My view, Go for the Thoren and if possible the DL103 cartridge as well !
for some additional money later you can put together a great plinth, although the current one is also good.
the RB300 on the Linn is what is really good.(dont know too much about tonearms)
you can google on TD 124 tweaks for loads of info.
[Beitrag von Arj am 20. Nov 2010, 19:05 bearbeitet]
Arj
#28 erstellt: 20. Nov 2010, 08:47
BTW I got myself a Lenco L75 .
Savyasaachi
#29 erstellt: 24. Nov 2010, 04:58
Nice!!..well am going to go audition both the thorens and the linn this saturday..assuming it doesn't snow or ice up. Its a balmy -8/9 deg C here tonight
Amp_Nut
#30 erstellt: 30. Nov 2010, 09:27
A friend-of-a-friend has a Thorens TD 166 Mk II TurnTable for sale.
Its a suspended Sub-chassis design, in good condition, though the Plastic Cover / lid needs to be buffed.
It has recently been fitted with an Ortofon Om 5e MM cartridge.
Expected Price with the (almost new ) Otofon cartridge is well below Rs 20K.
Anyone interested, please PM me for Contact details.
Arj
#31 erstellt: 30. Nov 2010, 15:40
nice buy above...
BTW is anyone interested in a steam powered TT
http://blog.makezine...d_record_player.html
Amp_Nut
#32 erstellt: 01. Dez 2010, 03:24
The Steam TT is REALLY neat... I WANT ONE ... even though the Signal To Noise Ratio is less than ideal
But look at the bright side... the steam could clean records of all the grunge settled in the grooves...
Savyasaachi
#33 erstellt: 13. Dez 2010, 03:42
gah..life has a way of butting in ..moving closer to work. Renting out a all for myself end of this month, now need to furnish up the place soooo.. bought some new toys in the guise of a ps3 and 46" LCD..
Also lately,.have put on less than 2 hours on my rig for the whole month. most of my listening has been during commute listening to classical music!! haha..I might just pass on the vinyl stuff for a bit as I am just not feeling it on the audio front. i am feeling somewhat burned out about the whole thing..
[Beitrag von Savyasaachi am 13. Dez 2010, 03:45 bearbeitet]
Arj
#34 erstellt: 13. Dez 2010, 06:00
you have to take audio abstainance once in a while...Pure music with no equipment thoughts often helps
bombaywalla
#35 erstellt: 17. Dez 2010, 02:29
like they say ----- too much of anything is bad!
advice needed
sammygeorge am 11.09.2005  –  Letzte Antwort am 14.09.2005  –  29 Beiträge
Need some advice concerning loudspeakers
Jonny22 am 03.04.2005  –  Letzte Antwort am 05.04.2005  –  30 Beiträge
advice
sammygeorge am 18.10.2005  –  Letzte Antwort am 20.10.2005  –  9 Beiträge
Turntable advice needed
Savyasaachi am 07.04.2007  –  Letzte Antwort am 08.04.2007  –  3 Beiträge
Help! I need some components.
benkenobi am 28.06.2005  –  Letzte Antwort am 01.07.2005  –  11 Beiträge
New System advice
soonbaboon am 04.01.2004  –  Letzte Antwort am 05.01.2004  –  2 Beiträge
Speaker cable and Interconnects advice needed
Ronnie22 am 14.04.2005  –  Letzte Antwort am 21.04.2005  –  5 Beiträge
Some knowledge
SUB_BOSS am 13.06.2005  –  Letzte Antwort am 13.06.2005  –  9 Beiträge
Help / Advice for building a new system
kaliste am 03.01.2005  –  Letzte Antwort am 07.01.2005  –  10 Beiträge
Need info & advice
vinodt am 29.12.2004  –  Letzte Antwort am 29.12.2004  –  5 Beiträge
  • Registrierte Mitglieder928.479 ( Heute: 7 )
  • Neuestes Mitgliedeunicen907643281
  • Gesamtzahl an Themen1.558.305
  • Gesamtzahl an Beiträgen21.699.358
