HIFI-FORUM » English » Other hifi (Engl.) » Power Supplies | |
Power Supplies+A -A |
purnendu
10:43
erstellt: 15. Jul 2009, |||
Hi All, Could I get some ideas for improving the power supply to my system? To begin with I plan to get a direct line from the meter: any specifc type of wires that I would need to use. As of now I am running the system straight from two power plugs. Purnendu |
Manek
16:23
A separate line with a separate breaker system I hope. Use the good stuff like merlin gerin or schneider I always use finolex cabling in my home and have done the same for my system. Good brass power sockets. Even anchor roma works well. Legrand has some high current 25 amp 3 pin sockets that are really good, very tight grip. 4sqmm intenal wiring. Manek [Beitrag von Manek am 15. Jul 2009, 16:39 bearbeitet] |
ani
05:19
erstellt: 16. Jul 2009, |||
HI, It would help if you can twist the phase and neutral wires that feed your dedicated socket from the main distribution board. This helps in reducing induced symetrical noise pick up by the line, major sources for such noise are home appliances like vacuum cleaner, mixer etc. Route the dedicated line as far away from exixting lines, this further reduces induction from other power lines. If possible get a seperate earth line from a dedicated earth pit for audio. It is preferable to have this pit at least 3m away from general earth pits. Pay special attention to terminations, general electricians are very careless when stripping wires and damages the conductors. Use of copper ferrules helps in prevention of induvidual strands from being cut when the screws are tightened. I have found that the above make noticable changes in audio. Wishing you happy listening Anil |
Savyasaachi
09:56
When I had my audio room built, I had a separate earth ground dug up for that room , separate line from the meter and circuit breakers. I am with Manek on the Finolex cables. They work great. I had dedicated tubing laid inside the walls to route interconnects and speaker wires (surround, fronts and rear channels) and also internal tubing for the projector in the ceiling. It doesn't cost too much extra to get something like this done..just a little bit of planning. I would still want a power conditioner in the room. What i heard at Prithvi's place, the power conditioner by Murthy was like a memory burn ..believe I was with Abhi Pani when Prithvi demoed the power conditioner to us. |
purnendu
10:07
Thanks, All very do-able. Have taken a printout.Shall begin with the finolex. Purnendu |
bombaywalla
20:37
I'm sorry to say that I have a little different view of the matter merely because the listening room is in India. The suggestions made by the above respected audiophiles are very applicable but, IMHO, their effect is compromised by the quality of the AC in India. IOW, despite following their suggestions to the letter, you will need a very good, large capacity AC regenerator power supply to get the best out of your 2-ch & to prevent it from frying during AC glitches & brown-outs. My brother has struggled with this over the many years that I have personally witnessed his progression as an audiophile & the AC regenerator has been a boon in his system. Audiophiles in BOM seem to be the best off & I can see where they are coming from. If you are in BOM, your need for a AC regenerative power supply is reduced (but not eliminated). So, make all the changes that everyone has suggested here keeping in mind the overall cost. If some of the suggestions are overly expensive, implement them in a diluted manner with the understanding that you will need to spend more money on a AC regenerative power supply once all your house-wiring, AC receptacles, grounding, etc is complete & that if the power quality is good enough for the AC regenerative power supply then it'll be effective in generating a clean AC for your gear. Like I said, IMHO, FWIW, YMMV. |
Manek
03:42
erstellt: 17. Jul 2009, |||
Yup, BEST has the most stable power supply in all of india. We are blessed. Can't say the same for reliance power in the suburbs. Haven't sampled Tata power distribution yet but Tata supplies a lot to Best. Is it clean ? No. Far cleaner than the rest though. Manek |
Arj
03:52
I agree with B'Walla In my system the sound after 11:00 pm improves dramatically in soundstage and in dynamics and that has to be due to power supply in bangalore..especiallly with the huge number of new Apts have in increasing the load. A Regenerator would be the most helpful. APS 1050 is the Ideal one but $$$'s. i have heard that the APC online UPS is really good ..not as good as the APS but for 30% of the price its great. |
ani
05:36
Hi, One can only agree with what B'walla said, power conditions in India is truely Slumdog. If you are going in for regeneration system you can save a lot of trouble and money spend on dedicated wiring. I am lucky to be in a village fed by a 100kva transformer right near my house, with hardly 10 houses connected to it. My other source of power is from a trnasformer that feeds a few industries and the difference between them is as clear as day and night. |
Manek
05:45
Apc would be a good bet, I am told there is another ups company called ablerex. Taiwan stuff but excellent quality. Haven't tried either but apc would be worth a shot in mumbai. Arj, apc had a dedicated model for av applications, are you refering to that or the ones we use for our computers ? Manek |
bhagwan69
06:51
![]() The 'best' I have found so far is PP PurePower ![]() ![]() ![]() web site :- ![]() ![]() |
bhagwan69
06:57
I think KB is using PP ! It is really very nice indeed. If I did not have so many of these [ ![]() ![]() |
Arj
09:19
hey manek. it is in the Smart UPS range which is actually an Online UPS ie it conditions power online using the battery backup and gives a Sine Wave output. I think it is this.. ![]() The earlier part numbers were different. Siva had pointed it out to me once. YOu could chek with the APC agent on which online UPS does power conditioning into a pure sinewave. I believe a 1.5KVA should be around 20K including a 15 min battery backup.. [Beitrag von Arj am 17. Jul 2009, 09:26 bearbeitet] |
purnendu
09:50
Hi and Thaks for all the suggestions. So it seems that after getting a direct line to the system, and a ground earth from the plug point, the next step shold be an AC regenerator. Are these things available on a modest budget and are there Indian ones available By the way Jaipur voltahe isnt all that bad. Purnendu |
Manek
11:37
Smart ups is what one uses for computers. Have many in the office. Any online ups would do what you are saying, but apc maybe using better output stage. Manek |
Arj
11:42
Could be..only thing is you need to make sure if it is a pure sine wave or a near sine wave (usually a chopped triangle)and uses the battery to condition the input even when there is no current.. |
Manek
11:49
Yes that's one of the things online ups do, condition power via batteries, and their output is pretty much a near sine wave. Btw, nowhere do apc mention it is a online ups in the article. To know if its a near perfect sinewave, we have to connect to a scope. Manek |
Arj
13:01
Manek from what i know one of the model of APC is the pure Sine wave. the Near sinewave is not really good as it only approximates a sinewave..not audiophile grade |
Manek
15:12
Yes they do have line called smart ups online. I am hoping that's the one with the good sine wave. Need to investigate more. Btw one needs to check out emerson, another biggie. Aplab based out of thane are pretty known for their power supplies and ups for hospital icu's and operation theaters....I know breach candy hospital in mumbai has a lot of aplab. I am wondering if that is also a contender ? Manek |
Amp_Nut
04:26
erstellt: 18. Jul 2009, |||
Good thread with a lot of participation going on here ![]() My few cents ( and Anti-Views ? ![]() 1. I agree with Bombaywalla and Bhagwan69... an AC Regenerator or a PURE SINE WAVE UPS is almost essential for most places outside Mumbai. A stepped Sine wave or Quassi Sine wave is WORSE than the electric supply that you receive from the power company. The product recommended by Bhagwan69 is superb, but probably beyond your current budget ? ( Rs 1 Lakh+ depending on the capacity. Yes, available from official dealer in New Delhi ) 2. It is ESSENTIAL that you use ONLY a Sine wave UPS. The regular computer USP could overheat and DESTROY your stereo equipment. The advice here is: Do NOT connect a UPS to your stereo unless you are ABSOLUTELY SURE its sine wave. When In Doubt - Leave It Out ! 3. If you are laying separate AC lines for your stereo : a. I would recommend TWO Separate lines from your Main distributor. Use one for your CD Player and the other for your amplifier. It has improved sound in my set up... b. Do NOT use a Circuit breaker IN either of these 2 lines. They are NON LINEAR and the conductive link's resistance increases as the current drawn rises... the worst that you can do .... IMHO. c. Do NOT connect any computer or Air Con or CFLs to the 2 audio spurs that you use. d. If you are wondering iF all this is worth it, try a nice Power Cord connected to your CD player. If there is no difference to the sound, you probably wont hear a diff with the separate audio spurs either .... ![]() ![]() ![]() [Beitrag von Amp_Nut am 19. Jul 2009, 03:21 bearbeitet] |
Manek
15:02
And I have seen how a square wave or quasi sine can waste a system.... Ampnut is right. Pls confirm first. Manek |
Arj
17:03
well the one I am talking of is used by Siva on his system..so i really would not doubt that ![]() |
Manek
11:08
erstellt: 19. Jul 2009, |||
So I assume Siva has checked the output thoroughly. Yes that definately holds weight. Siva, Could you give us the exact model number ? Manek |
sivat
04:17
erstellt: 20. Jul 2009, |||
SURT2000UXI |
reignofchaos
16:37
#25
I use an APC 1500VA Smart UPS. I know for sure its a pure sine wave and having connected my setup through it, the audio quality improves dramatically. Blacker backgrounds with a lower noise floor, faster transients, better bass - the improvement is all round. abhi.pani has heard the same at my place. A good UPS is really worth it. However please make sure its a pure sinewave UPS. The best option would be an isolation transformer followed by a double conversion UPS like the APC Smart series. Avoid the cheapo backups like plague. [Beitrag von reignofchaos am 20. Jul 2009, 16:37 bearbeitet] |
sivat
19:14
#26
APC Calls most of thier UPS as smart UPS and not all of it is of similar type. So please go by the model numbers. |
Manek
03:21
#27
erstellt: 21. Jul 2009, |||
Has anyone checked the output of the sine wave ups on a scope ? Siva ? Manek |
Manek
03:24
#28
Secondly Wouldn't true online ups offer the isolation one needs ? Why use another isolation transformer ? Won't that be too many tranbsformers in the chain ? Manek |
Manek
12:52
#29
Siva, Do you mind telling us how much that piece costs with batteries of 15 mins backup ? Manek |
Arj
13:30
#30
manek, I dont think the UPS has a transformer..unless you meant that it anyway isolates from the power supply ? |
Manek
14:10
#31
Yes that's what I meant arj, so if the true online ups is isolating the load from the mains ac, would one really need a separate isolation transformer before the ups ? The spec sheet of the apc has a large ac mains voltage operation range of 160v to 280v as well hence I assume one box would serve many purposes. Manek |
Arj
14:31
#32
True. I would also guess the same same. Hey ROC was there a reason you suggested this ? Also what is the Battery backup capacity you are using with yours. Also I see that the APCs power sockets are not for regular power chords...did you re terminate your power chord ? |
reignofchaos
16:06
#33
erstellt: 22. Jul 2009, |||
I have a power distribution unit that plugs into the back of the UPS. From there, its normal plugs. I'm not sure why but I was suggested an isolation transformer by the APC guy and also one of my more experienced Audiophile friends here. I've never tested the battery backup but I guess it should do an hour pretty easy since it takes my SLI'ed computer system with a quad core and 6 hard drives for 20 mins without much trouble. [Beitrag von reignofchaos am 22. Jul 2009, 16:08 bearbeitet] |
sivat
05:55
#34
erstellt: 23. Jul 2009, |||
2KV with 15 will cost around Rs.42k/- ...that was two years ago. |
stevieboy
14:22
#35
hi reign, was recommended to me too by viren and mr murthy as its better than a servo stabilizer. one question how does the apc work? does it provide a sine wave even when the power from the main outlet is on or sine wave only when power goes off and the apc kicks into action? thanks [Beitrag von stevieboy am 23. Jul 2009, 14:40 bearbeitet] |
Manek
15:55
#36
Online ups would typically do two conversions, ac to dc and charge the batteries, the battery output dc to ac which would be a sine wave output. The sine wave output would be irrespective of mains on or off. Manek |
reignofchaos
16:19
#37
There are two versions - line interactive and online. The online ones are always off battery. The line interactives run off battery when needed. Depends upon your budget :). |
stevieboy
08:18
#38
erstellt: 24. Jul 2009, |||
thanks guys will look out for the online one. will have to decide between that and an isolation transformer. was aiming for an ac regenerator though... |
Manek
10:27
#39
The online ups is doing the job of regenerating ac from dc. Manek |
stevieboy
12:56
#40
erstellt: 26. Jul 2009, |||
hi manek, but will it be the same as a dedicated ac regenerator like ps audio or pure power ones? regards |
Manek
17:27
#41
If hey both give clean sine waves output, are good with generating the current needed, how does it matter ? How do ps audio or pure power generate ac ? Curious. Manek |
Arj
18:05
#42
PS audio is an amplifier based regenerator ie it behaves as a power amplifier and amplifies a sine wave to the required voltage. Purepower regenerates from DC using an inbuilt battery to augment and create a pure sinewave. the latter is more efficint..PS audio wastes close to 50% of power. APC is also very similiar to Purepower..although apparently i very loud. but if you can keep it in a different room maybe it will work well ![]() |
reignofchaos
18:45
#43
The online version is super loud. The line interactive isn't since the fan comes on only when on battery. I tried both at my place and there wasn't a noticeably difference or maybe my equipment isn't resolving enough. So I got the line interactive. Both sounded significantly better than direct wall power. YMMV. [Beitrag von reignofchaos am 26. Jul 2009, 18:46 bearbeitet] |
sivat
04:11
#44
erstellt: 27. Jul 2009, |||
My APS UPS makes a lot less noise that what i have heard from a PS Audio. |
Best Speakers to get within my range? Archangelx99x am 07.04.2004 – Letzte Antwort am 23.05.2005 – 11 Beiträge |
DVD player power supplies Manek am 31.07.2006 – Letzte Antwort am 04.08.2006 – 14 Beiträge |
Help in Selection Of the Right System Menon am 10.09.2005 – Letzte Antwort am 03.10.2005 – 3 Beiträge |
Need suggestions for Tuner/CD system SUNILYO am 15.04.2008 – Letzte Antwort am 23.04.2008 – 21 Beiträge |
Mid-fi Car Audio: Where to start, how to go about? abhi.pani am 24.10.2006 – Letzte Antwort am 30.04.2007 – 2 Beiträge |
connecting the ipod anirvan am 11.07.2006 – Letzte Antwort am 16.08.2006 – 25 Beiträge |
Any free to air channels in Worldspace? kvish am 29.12.2006 – Letzte Antwort am 05.01.2007 – 3 Beiträge |
CAS or DTH? What to choose? zhopudey am 22.12.2006 – Letzte Antwort am 30.12.2006 – 14 Beiträge |
Need Suggestions For Car Hi Fi Amp_Nut am 09.01.2008 – Letzte Antwort am 14.01.2008 – 46 Beiträge |
Some help with iTunes Krish am 18.06.2008 – Letzte Antwort am 19.06.2008 – 11 Beiträge |
- Registrierte Mitglieder928.473 ( Heute: 1 )
- Neuestes MitgliedIngerlise_Spoor
- Gesamtzahl an Themen1.558.296
- Gesamtzahl an Beiträgen21.699.175
