HIFI-FORUM » Stereo » Hifi-Klassiker » Leistungsangaben bei einen kenwood ka 3700 | |
Leistungsangaben bei einen kenwood ka 3700+A -A |
Stockwerk
10:44
erstellt: 06. Apr 2009, |
Hallo, kurze Frage auf dieser Seite ( in der listung) ist der Kenwood ka 3700 mit 2x 70 watt angegeben??? ist das Richtig so??? ist das die max angabe? weil ich kenn den nur mit 2x50 watt an 2 ohm an 4 ohm 25 watt x 2 ???? Grundsätzlich ist es mir bei dem schönen Verstärker egal aber interessieren würde es mich trotzdem ![]() |
tri-comp
20:10
I have the schematic diagram and it says: KA-3700 Type K,M,S,X: 20Watt / Channel minimum RMS at 8 Ohms from 20 to 20.000Hz with no more than 0.08% THD (Total Harmonic Distortion) KA-3700 Type W,L,T: 25Watt / Channel minimum RMS at 8 Ohms from 20 to 20.000Hz with no more than 0.1% THD (Total Harmonic Distortion) Dynamic Power Output = 100Watt / 4 Ohm !!! I suspect that is what the Americans defined as Peak Music Power Output (PMPO), i.e. totally irrelevant and just serves to show-off ...mainly because people will believe anything ...and BUY anything that on paper has impressive data. Your amp. is a nice one that sounds OK. Just not the big 'Kraftwerk' of audio ![]() ![]() /tri-comp |
Stockwerk
20:56
So what did I almost thought the happy times will benefit through increased gelabere. Ps Have also sell well and be awake more attention. No power even bother me at all, if there are not enough because what amplifiers. But anyway makes me not really hot, because I have 2 of these amps and am completely lucky.I have also been read by many users because the power is both necessary and sufficient. We are also still in the household and not in the stadium, I was only interested in what these particulars mentioned on the website should be. But a great contribution to my question, many thanks to you My english I can read, is very bad |
Stockwerk
15:28
erstellt: 07. Apr 2009, |
tri-comp
05:42
erstellt: 08. Apr 2009, |
Interesting that you have the same product with different names. TRIO & KENWOOD is the same company; they just changed the name around 1980. Look at some pages like: ![]() ![]() Please write in German. It's a lot easier to understand than your English ![]() mfg, /tri-comp |
Stockwerk
09:09
Ja ich weiß mein english ist perfect für den Mülleimer. Ja das dass das selbe Gerät ist ist mir bewusst. Mich hat es nur gewundert. Übrigens die unterscheiden sich auch auf der Gehäuserückseite. der untere trio hat hinten 190W usw drauf stehen. Der obere 185W usw und hat zusätzlich einen Kippschalter für 110/230Volt |
Stockwerk
09:58
Ach ja ich wollte noch was fragen. Der untere Trio macht langsam aber sicher etwas schwierigkeiten. Ich hab die Verstärker eigentlich erst überholen lassen. Bei dem Untere fällt mir im Wechsel wenn ich den Balanceregler ganz leicht bediene schnell mal gleich der linke oder rechte LS aus. Der Volumregler macht ebefalls kleinere zicken. Der unterstützt irgendwie durch sein leichtes Kratzen den eefekt der LS Aufälle. Die Endstufen Laufen aber dass ist schonmal vorab ausgeschlossen. Wäre da das leidige Thema Staub wieder auf dem Plan. Hat jemand nen guten Tip??? Ich habe mal was von Oszillin gelesen , könnte man das damit wieder in den Griff bekommen??? Oder gibts noch nen andern Weg vielleicht Pressluft??? wobei Pressluft, ich möchte ja eigentlich den Kontakt in den Porties gleich mitpflegen???? Ich denk Ihr könnt mir Folgen.. |
Stockwerk
17:04
Ok ich habe mich heute nochmal kurz mit den Kratzgeräuschen und Ausfällen beschäftigt, ich konnte die Potensios. ausblasen. Problem behoben alles läuft wieder problemlos. Nur alls ich das Gehäuse geöffnet hatte, ist mir beim Trafo was aufgefallen. Watch pic ![]() ![]() Rechts mittig ist eine Beschädigung sichtbar. für meine Verständnisse dürfte hier die Isolierung geschmorgelt haben. Wie sehr Ihr das??? |
HisVoice
19:03
Hallo Wenn das Bild etwas schärfer wäre könnte man sich bestimmt auch auf eine Aussage einlassen ![]() Wenn ich das aber richtig entziffere ist da nur der Schutzlack (Isolation) "ab" nichts was Kopfzerbrechen bereiten sollte Grüße Martin |
Stockwerk
19:21
Sorry ich bekomm es mit meiner Kamera nich gescheit hin. Das ist richtig das ist nur der Schutzlack der Beschädigt ist. Mhhhh... sehr hübsch sahs nicht aus, wie ne Wasserblase an der Hand die geplatz ist. Also das Kupfer selber ist unbeschädigt. Seh ich das also richtig das dass nicht wirklich was macht??? Kann man das ausbessern??? |
Stockwerk
16:34
erstellt: 09. Apr 2009, |
Schade ich dachte ich bekomm nochmal nen Tip. Ist das jetzt bedenklich??? Kann mann das ausbessern??? Gibts da nen entsprechenden Lack zum nachkaufen??? Danke im vorraus |
andisharp
16:37
Das ist unbedenklich, ein Ausbessern ist unnötig. Kiste wieder zu und gut ist. |
Stockwerk
18:21
Mir ist übrigens noch was anderes aufgefallen. Der mit dem Logo trio allso sprich der untere, hat schon bei leiseren Lautstärken ein relativ stark wahrnehmbares Netzbrummen über die Lautsprech. Der obere hat das fast garnicht, Nur bei vollem Volumen hörbar. Ich bin das eigentlich nur schwach gewöhnt, auf die dauer klingt das halt relativ lässtig.# Hat da jemand eine Idee??? |
HisVoice
19:58
Netzbrummen lässt auf Massefehler schließen ,leider nur durch entsprechendes Fachwissen und ausreichend Messequipment zu eruieren Grüße Martin |
Stockwerk
20:06
Na ja ich ahb mittlerweile einiges ausprobiert. Chinch kabel getauscht, andere Steckdose benutz und und und.. Das einzige was ich nicht weiß, betriff dir Masseschraube an der Gehäuserückseite. Könnte man vielleicht noch Versuchen den Verstärker zusätzlich zu erden??? Kömisch oder??? Erst hat der gekratz und hatte Ausfälle der LS. Jetzt ist das behoben läuft super aber ..... ![]() |
HisVoice
20:17
Nein ........dazu müsste man sich durch die Schaltung "ackern" .......wie gesagt nur was für jemand der über Manual und genügend Fach- und Sachwissen verfügt Das ist nur Messtechnisch zu eruieren |
Stockwerk
20:28
Käse... dann werd ich den wohl doch mal zum check up brinegen. Ansich stört mich das brumen nicht weil es so nicht auffällt allerdings, bei höherer Lautstärke und bei Liedern die ruhigere phasen haben fängt das brummen an dominant zu werden. Sehr lästige angelegenheit. Abr egal ein Verstärker dieser schönheit und altersklasse darf auch nach jahren mal das brummen anfangen. ich denke Die euros für den techniker sinds wert. Danke für Hilfe |
Kenwood ka 3700 Stockwerk am 04.04.2009 – Letzte Antwort am 04.04.2009 – 5 Beiträge |
Kenwood KA 3700 pakko am 17.06.2004 – Letzte Antwort am 16.12.2010 – 13 Beiträge |
Kenwood KA-3700 Boxensuche: Technics SB-EX3? jim_bocho am 06.12.2012 – Letzte Antwort am 06.12.2012 – 4 Beiträge |
Kenwood KA 8100 / Lautsprecher Teddyper am 15.04.2012 – Letzte Antwort am 16.05.2016 – 15 Beiträge |
Kenwood KA-8100 / KA-7300 Lost_in_the_seventies am 27.02.2011 – Letzte Antwort am 27.02.2011 – 2 Beiträge |
Kenwood KA-74 KA fragen TrunxX am 27.02.2008 – Letzte Antwort am 05.04.2008 – 30 Beiträge |
Kenwood KA-3300 dirk2306 am 07.02.2010 – Letzte Antwort am 08.02.2010 – 5 Beiträge |
Kenwood KA-8150 Las_Vegas am 08.03.2007 – Letzte Antwort am 02.05.2007 – 15 Beiträge |
Kenwood Ka-8150 jeremypope am 09.05.2008 – Letzte Antwort am 13.05.2008 – 5 Beiträge |
Kenwood ka-7002 Noizee1 am 16.05.2010 – Letzte Antwort am 16.05.2010 – 15 Beiträge |
- JBL LX-155
- Sony WM-6DC wirklich gut?
- JBL LX-155
- Registrierte Mitglieder928.874 ( Heute: 8 )
- Neuestes Mitgliedhonolulu1
- Gesamtzahl an Themen1.559.194
- Gesamtzahl an Beiträgen21.719.972
