How To Connect PL-3000 II and SAE 3100
LATHE
#1 erstellt: 01. Jun 2009, 03:49
ALGUIEN HABLA ESPAÑOL OR ENGLISH..
NECESITO AYUDA ...GRACIAS
SALUDOS..DESDE MAR DEL PLATA -ARGENTINA
hifibrötchen
#2 erstellt: 01. Jun 2009, 07:50
English pleace .
LATHE
#3 erstellt: 01. Jun 2009, 12:39
Hola..
Ok...thanks...my english is very bad I will do my best..
How connected to each other two excelent equipments..
1 - PHASE LINEAR MODEL 3000 SERIES TWO (PRE) (110 V)(***)
2 - SAE 3100 (POWER AMPLIFIER) (220V)
In my country (Argentina) is 220V..
Help please for:
1 - Audio connections (Pre Out - Main In..etc) by example..
2 - Electrical connections (SAE 3100 no power button)...
(***) I have the electric transformer (110 -->220) to connect to the grid...
I searched on the internet and the information is not much and that is why I seek your help..
sorry for my english...
Thank you very much for everything..
Kind regards from Mar del Plata - Argentina
Walter
Schall_und_Rauch
#4 erstellt: 01. Jun 2009, 21:19
The SAE 3100 only has two inputs (channel a, channel b), where you connect the output of your preamp. The step down transformer is only needed for the Phase Linear.
When the signal (from pre amp) is detected, the SAE 3100 will power on.
detegg
#5 erstellt: 01. Jun 2009, 23:35
Hola Walter,
for I´m a lucky owner of a PL-3000-II too, I´d try to give you some help regarding this item - hopefully it is sufficient for you
Your PL-3000-II should have a dual (primary coil) transformer for 120/240VAC mains. Please allow a profesionell to compare the following wiring diagramm with your equipment
The PL-3000-II preamp must have the NR-LOOP In/Out to be connected - with a "jumper" in original or with a short RCA chord.
The SAE 3100 is conected via RCA chord to pre amp´s output A or B (output B is switched by the headphone connector in front of the unit).
Mains are supported to the SAE via AC-OUTLET´s at the back of the pre amp.
best regards
Detlef
... please change the headline of this thread to e.g. "How To Connect PL-3000 II and SAE 3100" for better use of our internal search funktion !!
[Beitrag von detegg am 01. Jun 2009, 23:45 bearbeitet]
LATHE
#6 erstellt: 02. Jun 2009, 05:14
Hola..
First of all thank you very much for your answers..
Deteqq,I do not have the manuals and therefore some questions,
please:
One:Means that the term "NR LOOP",that the role and when they must be connected (OUT with IN) or not..
Second:The RCA "OUTPUTS" "A sw" and "B unsw" are are the audio outputs from the pre (PL 3000) to power amplifier input's (SAE 3100) is correct this..?
Which of the two should I use,is associated with the use of the headphones...
Third:What I can or I can not connect in the "SWITCHED 500W" "120 VAC 50/60 HZ" or "UNSWITCHED 1000W"..
I hope not bother with so many questions..and thanks again..
Sorry for my english type Flintstones....
Walter
detegg
#7 erstellt: 02. Jun 2009, 11:19
Hola
... your english is much better than my spanish
1. the NR-LOOP is used for looping-in an external equalizer. If you don´t use something like that, you must have the NR-LOOP In/Out be connected - with a "jumper" in original or with a short RCA chord
2. use the A sw(itched) outputs to feed the SEA with the audio signal via RCA chord. If you plug in your headphone at the frontpanel this A sw outputs will be switched OFF by an internal circuit breaker.
3. connect the power chord of the SAE to the "SWITCHED 500W" mains plug socket at the rear of the pre amp. This cause the SAE to be switched ON/OFF if you switch the PL-3000 ON or OFF.
... was this usefull?
Detlef
LATHE
#8 erstellt: 02. Jun 2009, 12:35
Hola..
Greetings to all..
Deteqq ..really thank you very much for your answers..
Today I received the the SAE 3100..
Cross my fingers...
Muchas gracias..Walter..
? SAE ?
hifibrötchen am 01.02.2006  –  Letzte Antwort am 03.02.2006  –  7 Beiträge
SAE Rack
SAE2105 am 28.12.2008  –  Letzte Antwort am 02.01.2009  –  13 Beiträge
Denon poa 3000 vs Yamaha AS 3100
Topos am 30.08.2018  –  Letzte Antwort am 01.09.2018  –  21 Beiträge
How-To: Richtiges Verpacken von Hifi-Klassikern
Rainer_dre am 21.06.2009  –  Letzte Antwort am 24.06.2009  –  17 Beiträge
How to Murder Your JBL CENTURY L100
classic.franky am 09.07.2009  –  Letzte Antwort am 04.10.2010  –  36 Beiträge
Monarch SAE 1000
Picton16ft am 21.02.2008  –  Letzte Antwort am 26.02.2008  –  3 Beiträge
SAE Two Serie
Siamac am 28.06.2009  –  Letzte Antwort am 29.06.2009  –  3 Beiträge
SAE-Geräte; wer kann weiterhelfen?
wer_kent_di? am 01.09.2007  –  Letzte Antwort am 05.09.2007  –  21 Beiträge
Service Manual SAE A 201
sanmati3 am 28.05.2016  –  Letzte Antwort am 28.05.2016  –  2 Beiträge
SAE-MK3-CM, Help needed
HpHofmann am 12.03.2024  –  Letzte Antwort am 14.03.2024  –  9 Beiträge
  • Registrierte Mitglieder928.975 ( Heute: 2 )
  • Neuestes MitgliedSonyBlack23
  • Gesamtzahl an Themen1.559.400
  • Gesamtzahl an Beiträgen21.725.853
