16v
josmuck
#1 erstellt: 16. Feb 2006, 20:32
i would like raise the voltage up to 16v. i spoke today with sombody that sells the cyclone from hawker and he was not sure what would happen if i put a 2v bat together with a 12v bat. does anybody out there have any idea what i should do or how i can get to 16v?
laterz brian
Son_of_Thor
#2 erstellt: 16. Feb 2006, 22:41
Hello,
you can do this with 2 oder 4 Volt Cells, no Problem.
Fiam, Ground Zero, Hawker... some Batterie Manufactors Produce this Cells.
But you should ONLY use them for dB-Drag, for the Burp!!!!
Don`t use this for music and be sure your amps can do this Voltage.
With a normal Batterie an a 4 Volt Cell you get so 17 Volt.
Mfg Dirk
Smartmatze
#3 erstellt: 18. Feb 2006, 15:54
If you wire a 2V cell in series to a normal battery, you'll get 14 V. Of course, real voltage will be at about 15 V, but we speak about NOMINAL voltage, when a normaler car battery has 12V.
IF you want a 16 V setup, you have to use 2 V cells in series or 1 4V cell wired to the 12V. This will result in a 17,0 - 18,0 V real voltage depending on the cells you use.
IF your ampflifiers are able to work at this volage you will get about 20-40% more power - but remember this results in probably 0.5 - 1.0 dB. In my opinion, this amount of higher pressure is easier to get if you work on you box...
Üüüühh!!!
Matze
reso for a polo 6n
josmuck am 07.07.2005  –  Letzte Antwort am 13.07.2005  –  14 Beiträge
148,4
josmuck am 16.08.2005  –  Letzte Antwort am 21.08.2005  –  3 Beiträge
bat.
macneil am 02.10.2006  –  Letzte Antwort am 04.10.2006  –  7 Beiträge
16V im Auto, mit 14v + 2v AGM Batterien!
dbdrag2016 am 06.03.2018  –  Letzte Antwort am 07.03.2018  –  23 Beiträge
welche Reso im 35 i passat Limo
gsxfblau am 14.01.2005  –  Letzte Antwort am 04.02.2005  –  11 Beiträge
Bat.-größe = andere Klasse?
Algi am 08.10.2006  –  Letzte Antwort am 09.10.2006  –  5 Beiträge
bat/leistung/verhalten
macneil am 23.05.2007  –  Letzte Antwort am 28.05.2007  –  11 Beiträge
zusatz bat, frage
macneil am 14.12.2007  –  Letzte Antwort am 20.12.2007  –  11 Beiträge
B2 Audio CC15 oder GZPW12SPL
Darklegendhero123 am 03.10.2014  –  Letzte Antwort am 03.10.2014  –  4 Beiträge
Extra SPL Kiste Speaker, Volumen, more i need some Tipps
siggixxl am 01.10.2015  –  Letzte Antwort am 24.04.2016  –  31 Beiträge
2006
  • Registrierte Mitglieder928.191 ( Heute: 6 )
  • Neuestes Mitgliedageige
  • Gesamtzahl an Themen1.557.668
  • Gesamtzahl an Beiträgen21.684.127
