HIFI-FORUM » Stereo » Elektronik » Röhrengeräte » Unbekannt Grundig Ausgangsübertrager (Ref. 9060-10... | |
Unbekannt Grundig Ausgangsübertrager (Ref. 9060-100.02)+A -A |
rlourenc
#1 erstellt: 04. Feb 2016, 15:34 | |
Hallo! Leider muss Ich weiter auf English weil meine Deutsch Sprachkenntnisse mir nicht reichen (obwohl Ich es gut verstehen kann; so können die eventuelle Antworten auf Deutsch sein!)... Meine entschuldigung! I recently bought a pair of output transformers from the firma Grundig (probably from the sixties) which someone took out from an old radio whose reference he lost (so, no starting point to look for schematics). What I have is the transformer's reference - 9060-100.02 (no Google results to be found) and the measured characteristics (on the attached file). I've used several old Grundig transformers in my amplifier projects but I never encountered one like this before. The turn ratio is abnormally low (around 1:4) unlike the usual 1:40 for EL84 single-ended output transformers. The other puzzling fact is the existence of not one but two secondary coils, almost similar but independent and wound with double wire. The primary is of rather standard aspect and follows the usual colour code (blue-red-yellow). As usual I applied some AC voltage to the primary coil and took the readings from the secondaries in order to calculate the turn ratio (N) and the impedance ratio (Z) but the results are far from 'standard' to me. Here are the calculations: Apply 230VAC to primary (red-blue wires) Read 61V from sec1 (black-green1 wires) and 64V from sec2 (brown-green2 wires) Turn ratio for secondary 1 (black-green1 wires) N=230/61=3,8; Z1 = N2 = 3,9x3,9 = 14,2 Turn ratio for secondary 2 (brown-green2 wires) N=230/64=3,6; Z2 = N2 = 3,6x3,6 = 12,9 Any ideas of what this is all about? Am I thinking straight or am I missing something? Are these really output transformers or some sort of interstage ones? Any help would be greatly appreciated! Thanks to all, Renato |
pragmatiker
Administrator |
#2 erstellt: 06. Feb 2016, 08:45 | |
Hello rlourenc, interstage may be a possible, yet unlikely (for an ordinary radio) explanation. I do knot know, if Grundig also manufactured these OTL Philips concepts (2 * EL86 in series push pull) with 800[Ohm] speakers - but an investigation in that direction may help to set things straight. The second secondary winding may have been used for some type of high-voltage piezo-tweeter. Yes, both estimates are a very "may"..... Another possible explanation may be: The xfmer was part of the record amplifier of a Grundig tape recorder. One or more meaningful picture(s) of this xfmer may be extremely helpful in further adressing this issue. Regards Herbert [Beitrag von pragmatiker am 06. Feb 2016, 08:58 bearbeitet] |
mk0403069
#3 erstellt: 07. Feb 2016, 00:02 | |
Hallo, Viewlleicht hilft das: Zwar scheinbar nicht genau der Übertrager, aber sinngemäß das Gleiche. Gruß, Matthias Edit: Uuuups, falscher Schaltplan: [Beitrag von mk0403069 am 07. Feb 2016, 00:42 bearbeitet] |
grundig-ausgangsübertrager el70 am 07.10.2011 – Letzte Antwort am 07.10.2011 – 3 Beiträge |
Saba Ausgangsübertrager Thompa am 04.04.2005 – Letzte Antwort am 12.04.2005 – 8 Beiträge |
Ausgangsübertrager/Gegenkopplung chris2178 am 21.07.2006 – Letzte Antwort am 31.07.2006 – 21 Beiträge |
Ausgangsübertrager Theorie sidolf am 08.05.2012 – Letzte Antwort am 29.05.2012 – 25 Beiträge |
Ausgangsübertrager ändern Phuli am 26.03.2015 – Letzte Antwort am 28.03.2015 – 9 Beiträge |
Ausgangsübertrager Wahl D1675 am 13.01.2020 – Letzte Antwort am 23.01.2020 – 15 Beiträge |
Ausgangsübertrager preiswert gebraucht bukongahelas am 02.12.2004 – Letzte Antwort am 05.12.2004 – 6 Beiträge |
Ausgangsübertrager bei Dynavox tauschen Heinzel33 am 06.05.2005 – Letzte Antwort am 16.01.2006 – 28 Beiträge |
Selbstbau Gegentakt Ausgangsübertrager? musculitohifi am 23.08.2006 – Letzte Antwort am 10.01.2007 – 3 Beiträge |
selbst gewickelte ausgangsübertrager cascote am 06.01.2007 – Letzte Antwort am 09.01.2007 – 7 Beiträge |
2016
- Lua 4040 c Klang?
- Masse, aber richtig !
- Lua 4040 c Klang?
- Registrierte Mitglieder927.551 ( Heute: 16 )
- Neuestes MitgliedVitol
- Gesamtzahl an Themen1.555.926
- Gesamtzahl an Beiträgen21.648.573
