HIFI-FORUM » Fernseher & Beamer » Plasma-Fernseher » Panasonic » Senderliste für DVB-S bearbeiten jetzt möglich!!!! | |
Senderliste für DVB-S bearbeiten jetzt möglich!!!!+A -A |
Matze_BT
09:35
#101
erstellt: 08. Jun 2012, |
Hallo Leute, hat das Tool schon jemand mit einem **STW50 ausprobiert? Funktioniert das? Oder kann ich mir den Download sparen? Vielen Dank im voraus! |
ei6dt
15:28
#102
erstellt: 09. Jun 2012, |
Hi, Please could you let me know where I can get the channel editor for svi_file for the Panasonnic Viera TX-32LZD81series of recievers. We have a problem with these TV's in Ireland as the DVB standards have not been properly implemented in firmware causing problems when scanning for channels. If we can look at the svi_file perhaps we can overcome some of our problems. Panasonic UK will not assist users here in any way to solve our problems. Many Thanks. |
Welle72
20:07
#103
Hello Is it possibly to receive FreeSat? |
ei6dt
10:03
#104
erstellt: 10. Jun 2012, |
Hi Welle72, Freesat is fine our problems are with DVB-T (terrestrial Digi TV) "When RTE changed its Service type from 0x01 to 0x16 for DVB-T TV the receiver only finds Radio Channels so unless you have an early back up on an SD card all TV channels are missing and consequently you can't rescan for new channels." Have a look at this section of boards.ie:- ![]() Well done last night by the way ![]() Cheers |
Welle72
20:33
#105
Will possibly be sent to Ireland in DVB-T2, that is in HD? If this is the case is sent in MPEG 4 and is not supported by the device. Since it does not help to turn to the options. Best regards |
ei6dt
23:19
#106
The TV is Mpeg4 compliant and receives all mpeg 4 signals including HD on DVB-T. It looks like the technical team from Panasonic mixed up the planed UK freeview HD in DVB-T2 with the irish DTT project. Nobody in Ireland is planing to introduce DVB-T2 as modulation method. Mpeg compression and modulation are two pairs of shoes. RTE is using MPEG4 with bog standard DVB-T as modulation method since july 2008. Beside that the Panasonic team didn't understand that only a simple value is missing in 1 or 2 selection tables to make the new service type valid for the dvb-t part of the TV. The service type 0x16 which is now in use is definded in the DVB specs and Panasonic promised to follow the DVB specs at the last page of the owners manual but the value 0x16 for the service type is missing in the firmware. Hope this explains the problem. Tony EI6DT |
ei6dt
16:15
#107
erstellt: 03. Jul 2012, |
I see that the latest version of SetEdit Panasonic V1.05 now reads svl_file from the early Freesat Viera TV's, Will the program allow me to edit and save an svl_file, I do not seem to be able to save modified files with the Demo version? Many Thanks ei6dt |
Gorcon
10:20
#108
erstellt: 16. Aug 2012, |
Hallo Welle72, wird es auch noch mal eine Version für DVB-C geben. Leider speist mein Kabelanbieter einige Sender mit einer Senderkennung ein die ich ändern muss damit ich dessen HbbTV nutzen kann. (zB- WDR HD - CV in WDR HD). Gruß Gorcon |
Welle72
19:56
#109
Kann ich leider nicht sagen da die Soft nicht von mir ist. Es soll aber eine kostenpflichtige im Netz geben wo es geht. Glaube wurde hier im Thread auch mal verlinkt. |
Gorcon
09:24
#110
erstellt: 17. Aug 2012, |
Danke, die andere Software habe ich schon gefunden. (SeteditPanasonic). Gruß Gorcon |
Passwort_ändern
13:33
#111
erstellt: 30. Sep 2012, |
Hab das Tool entpackt und ich kann es problemlos starten. Brauche ich dafür jetzt eine SD Karte oder geht auch SDHC? Denn ich habe nur eine 8 GB SDHC Kartte, nix SD. Ich habe einen Panasonic 50gt50, der kann eigentlich auch SDHC lesen. Habe ich es richtig verstanden? Nur einen leeren Ordner "hotel.pwd" erstellen und in den TV stecken? |
bowieh
16:47
#112
Wenn du einen GT50 hast nicht. Da gehst du ins Menü->Setup->Andere EInstellungen->Senderliste austauschen. Faszinierender Weise stehts auch so in der Anleitung. |
Passwort_ändern
18:23
#113
Ah danke, funktioniert (auch mit SDHC) Ich wusste, dass es irgendwo einen Thread zu dem Thema gibt, daher habe ich nicht gross in der BDA gesucht. Dachte für die 50er ist es genauso. |
groovetronic
16:21
#114
erstellt: 01. Nov 2012, |
Bei meinem TX-L47ETX54 funktioniert´s leider nicht! ![]() Nach der PIN-Eingabe sagt er, dass ich den TV ausschalten soll! [Beitrag von groovetronic am 01. Nov 2012, 16:24 bearbeitet] |
bowieh
16:27
#115
Was konkret ? DVB-S Sender Liste exportieren und bearbeiten sollte auch beim TX-L47ETX54 funktionieren. Nachtrag: Na dann liegts an dir. Auch du solltest die Anleitung lesen, bei deinem Modell geht es übers Menü. [Beitrag von bowieh am 01. Nov 2012, 16:28 bearbeitet] |
groovetronic
16:44
#116
Hallo bowieh, erstmal danke für deine Antwort. Natürlich hab ich die Anleitung gelesen. Deswegen möchte ich dich auch noch auf meinen erstellten Thread hinweisen: ![]() |
bowieh
16:53
#117
Dann nimm eine andere Karte, an der dürfte es liegen. |
groovetronic
17:03
#118
Nach einigem Suchen habe ich doch tatsächlich noch ne SD-Karte gefunden. Sandisk 2 GB....funzt tatsächlich! Hätte ich eigentlich gleich draufkommen können...aber manchmal braucht man halt nen Denkanstoß! DANKE!!! |
max12374
19:43
#119
erstellt: 04. Jan 2013, |
Hallo Welle72, hab einen Panasonic 55DT50 und verzweifel mit der Sendeliste wie funktioniert das mit der SD Karte und den Computer ? Kanst du mir helfen.... |
norman68
19:55
#120
Du hast den Thread gelesen? Es ist Minimum zwei mal genau erklärt was du wie machen mußt. |
max12374
20:36
#121
hallo norman 68, hab die Sd karte in den Fernsehr gesteckt hab den Ordner eingerichtet und pin 4850 hab ich auch gefunden bekomme aber nichts im Rechner geöffnet ![]() |
bowieh
21:21
#122
Extra für dich:
max12374
14:20
#123
erstellt: 06. Jan 2013, |
danke danke...das hab ich geschaft und dann weiter senderliste auf sd card exportieren???? |
norman68
14:32
#124
Du verstehst was in der Anleitung geschrieben steht? |
dpante1s
00:42
#125
erstellt: 03. Feb 2013, |
Hallo, ich habe bei Amazon gelesen, dass ein Käufer des DVB-S-HDD-Recorders Panasonic DMR-BST720 es geschafft hat, mithilfe von dem PC_Editor die Senderliste auf SD-Card zu ziehen, über das Tool zu editieren und es wieder zurückzuspielen... Ich habe das Vorgänger-Modell Panasonic DMR-BST700 und wollte dies auch versuchen, bekomme aber nicht die Senderliste auf die SD-Card Habe es auch über Amazon versucht, ihn zu befragen wie er das genau hinbekommen hat... Aber noch keine Antwort... Vielleicht kann mir einer hier weiterhelfen... Wenn ich die SD-Card mit der Text-Datei 'hotel.pwd' einlege, kommt nicht automatisch ein besonderer Bildschirm oder ähnliches... Wie kann ich es hinbekommen, daß ich nun die Senderliste des DVB-Recorders auf die SD-Card überspiele? Was muss ich im Menü des DVB-S-Recorders anwählen? Danke im Voraus. [Beitrag von dpante1s am 03. Feb 2013, 00:43 bearbeitet] |
bowieh
00:49
#126
Bei den TV gibt es nur 2 Möglichkeiten zum Export: Automatisch mit hotel.pwd oder übers Menü
Da hast du einen riesen Vorteil gegenüber den Nichtbesitzern des Gerätes: Du hast die Anleitung zum Gerät. Wenn es eine Funktion zum Export gibt, steht es, so wie bei den TV, dort drinnen. |
dpante1s
00:12
#127
erstellt: 04. Feb 2013, |
Habe mir jetzt mal die Anleitung vom DMR-BST720 runtergeladen, also dem Nachfolger meines DMR-BST700.. Und dort steht in drin, daß dieser die Senderliste auf SD-Karte speichern kann, um diese mit anderen Receivern auszutauschen, was bei meinem noch nicht drin steht... Also Hoffnung direkt mal geköpft... |
Buttoni
13:07
#128
erstellt: 06. Feb 2013, |
Hallo zusammen, hoffe mir kann jemand helfen. Habe alles entpackt und sowohl das Programm als auch den Ordner Hotel.pwd auf einen USB Stick gespeichert. Auf dem TV erscheint allerdings nur die Meldung " Cannot read SD Card" "Pls. check SD Card. " Funktioniert das Programm nur mit einer SD Karte und wenn ja weche maximale Speichergröße darf diese haben? Danke vorab! Gruß Buttoni |
Buttoni
14:09
#129
Mit SD Card funktionierts. Versucht macht klug. ![]() |
Buttoni
00:15
#130
erstellt: 09. Feb 2013, |
Sind bei jemandem auch einige Sender beim hin und her kopieren verschwunden? |
norman68
12:18
#131
nein bei mir nicht |
*Blueberry*
12:22
#132
erstellt: 13. Apr 2013, |
Ich hätte auch gerne den Link für dieses Programm geschickt bekommen. Hab das gleiche Problem mit meinem Panasonic TV ![]() Danke schon mal im Vorraus. |
phoenix0870
15:08
#133
![]() Entgegen anders lautender Posts funktioniert der Link dort einwandfrei. Bitte auf der Seite an der richtigen Stelle klicken! (Zuerst direkt unter dem ersten Bild und auf der nächsten Seite dann die zweite Zeile) MfG Phoenix [Beitrag von phoenix0870 am 13. Apr 2013, 15:10 bearbeitet] |
*Blueberry*
17:08
#134
Also ich muss sagen, dass das bei mir einwandfrei funktioniert hat. Ich musste zwar erst Java noch mal runterladen und neu installieren, aber danach konnte ich die Listen ganz einfach verändern. Um die Liste auf die SD Karte zu bekommen, einfach nur bei 'andere Einstellungen' auf 'Senderliste austauschen' gehen und danach auf 'Senderliste exportieren' Wenn man die Liste dann auf den Fernseher übertragen möchte, wieder dahin, allerdings auf 'Senderliste importieren' gehen! Alles ganz easy ![]() |
-ZiZu-
16:34
#135
erstellt: 20. Okt 2013, |
Hey, super Info hab das Tool erfolgreich an meinem GT50 getestet als nächstes kommt dann der V10 dran ![]() Gruß ZiZu |
Revelll
20:31
#136
erstellt: 05. Dez 2013, |
Senderlisten erfolgreich bearbeitet TV Panasonic GTW60 Funktioniert ohne Probleme USB Stick (Leer) übers Setup----->Andere Einstellungen---->Senderlisten austauschen ![]() |
gitarre1944
17:40
#137
erstellt: 03. Apr 2014, |
norman68
05:52
#138
erstellt: 09. Apr 2014, |
Wieso lädst du es dir nicht einfach selber runder? Link ist ja in Posting Nr.26 zu Finden. |
Hody
11:30
#139
erstellt: 02. Jul 2016, |
Geht das nicht für DVB-C`? Danke |
Panasonic VTW60 Senderliste für DVB-C sortieren, bearbeiten möglich? dukebtd am 25.01.2014 – Letzte Antwort am 01.02.2014 – 23 Beiträge |
DVB-S Senderliste auf TX-P46G15E Lance0 am 24.12.2009 – Letzte Antwort am 25.12.2009 – 2 Beiträge |
46 GT 30 Senderliste am PC bearbeiten Neelix70 am 15.04.2011 – Letzte Antwort am 25.12.2011 – 7 Beiträge |
Senderliste für Astra19.2 GT30 fluffibaer am 13.04.2012 – Letzte Antwort am 14.04.2012 – 3 Beiträge |
Favoriten Senderliste (VT20) mito007 am 01.01.2011 – Letzte Antwort am 31.10.2011 – 5 Beiträge |
P42GW20 Senderliste xploit87 am 28.01.2012 – Letzte Antwort am 30.01.2012 – 9 Beiträge |
GW20 USB Aufnahmen bearbeiten ? scheka1337 am 09.04.2010 – Letzte Antwort am 23.01.2011 – 5 Beiträge |
TX-P50VT20EA zerwürfelt Senderliste mito007 am 12.12.2012 – Letzte Antwort am 13.12.2012 – 4 Beiträge |
DVB-S TX-P42GW10 wqht am 31.05.2009 – Letzte Antwort am 31.05.2009 – 2 Beiträge |
GW 10 Senderliste sortieren Siemm am 29.01.2010 – Letzte Antwort am 13.02.2010 – 5 Beiträge |
- Teletext Problem
- Teletext Problem
- Registrierte Mitglieder929.043 ( Heute: 4 )
- Neuestes MitgliedManfred_Haferanke_
- Gesamtzahl an Themen1.559.548
- Gesamtzahl an Beiträgen21.729.023
