HIFI-FORUM » Fernseher & Beamer » LCD-Fernseher » Samsung » ES7090 mkv abspielen | |
ES7090 mkv abspielen+A -A |
rbTV
15:56
erstellt: 05. Sep 2012, |
Hallo, habe folgendes Problem: Erste Datei: Format : Matroska Format version : Version 2 File size : 1.31 GiB Duration : 42mn 2s Overall bit rate : 4 471 Kbps Encoded date : UTC 2012-08-22 18:09:28 Writing application : mkvmerge v4.0.0 ('The Stars were mine') gebaut am Jun 6 2010 16:18:42 Writing library : libebml v1.0.0 + libmatroska v1.0.0 Video: Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.1 Format settings, CABAC : Yes Format settings, ReFrames : 5 frames Codec ID : V_MPEG4/ISO/AVC Duration : 42mn 2s Bit rate : 3 806 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate : 25.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.165 Stream size : 1.12 GiB (85%) Writing library : x264 core 125 r2208 d9d2288 Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 Language : German Audio: Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Codec ID : A_AC3 Duration : 42mn 2s Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 57.7 MiB (4%) Language : German Diese Datei kann ich problemlos flüssig abspielen. Die zweite Datei: Format : Matroska Format version : Version 2 File size : 1.89 GiB Duration : 41mn 57s Overall bit rate : 6 451 Kbps Encoded date : UTC 2012-08-29 19:17:15 Writing application : mkvmerge v4.0.0 ('The Stars were mine') gebaut am Jun 6 2010 16:18:42 Writing library : libebml v1.0.0 + libmatroska v1.0.0 Video: Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 5 frames Codec ID : V_MPEG4/ISO/AVC Duration : 41mn 57s Bit rate : 5 633 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate : 25.000 fps Original frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.244 Stream size : 1.68 GiB (89%) Writing library : x264 core 125 r2208 d9d2288 Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=5633 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00 Language : German Audio: Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Codec ID : A_AC3 Duration : 41mn 57s Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 57.6 MiB (3%) Language : German Kann ich nicht problemlos abspielen. Dieses Video hat Ruckler, Bild Aussetzer und Ton stockt. Hat einer eine Idee woran das liegt? |
ArmyOfMe
09:06
erstellt: 06. Sep 2012, |
Ohne mich mit dem ganzen Technik-Gedöns auseinanderzusetzen, tippe ich ganz stark hierauf:
vs.
DLNA Ethernet Video- Format? stroti22 am 20.10.2010 – Letzte Antwort am 20.10.2010 – 3 Beiträge |
Samsung LE40C530 Video-Format für USB Mediaplayer Pumbi am 09.05.2019 – Letzte Antwort am 10.05.2019 – 5 Beiträge |
Samsung Le40B650 MediaPlayer 2.0 Saya28 am 01.08.2009 – Letzte Antwort am 06.03.2010 – 11 Beiträge |
Format wird nicht erkannt #TVneu# am 03.02.2012 – Letzte Antwort am 03.02.2012 – 2 Beiträge |
LE37C650 - falsches Format bei dnla high55555 am 01.06.2010 – Letzte Antwort am 02.06.2010 – 5 Beiträge |
USB Format F 8090 bernd41844 am 17.11.2013 – Letzte Antwort am 17.11.2013 – 2 Beiträge |
Format und Bildschirmmodus Niffchen am 08.01.2008 – Letzte Antwort am 10.01.2008 – 5 Beiträge |
A656 erkennt nicht das Format seestern2000 am 02.10.2008 – Letzte Antwort am 25.10.2008 – 23 Beiträge |
Hd in XFS Format formatiert michi110 am 02.09.2013 – Letzte Antwort am 03.09.2013 – 3 Beiträge |
Samsung HU8590 - 4k Format nicht unterstützt ch-glacier am 15.12.2015 – Letzte Antwort am 18.12.2015 – 13 Beiträge |
2012
Top Produkte in Samsung
- Registrierte Mitglieder929.116 ( Heute: 9 )
- Neuestes MitgliedWT1851
- Gesamtzahl an Themen1.559.721
- Gesamtzahl an Beiträgen21.733.244
