HIFI-FORUM » Do it yourself » Lautsprecher » Subwoofer » RCM Detonation DT 80 | |
RCM Detonation DT 80+A -A |
gunnet
23:21
erstellt: 13. Jul 2006, |
Hello, I came across here because I wanted to know a thing about Detonation DT 80 active module for sub. I feel sorry and I excuse with everyone because I'm writing in english. But I didn't know where to ask about rcm amplifier. I have the DT 80, and when it's on I hear a light hum. It doesn't come from the speaker, but from the amplifier itself. Is it normal? thank you very much. [Beitrag von gunnet am 13. Jul 2006, 23:28 bearbeitet] |
Radiologe
02:07
erstellt: 14. Jul 2006, |
Hello, hum is not normal.Please check Cable from Amp to DT80. If it does not work,how is the connection to DT80?High input(Speaker) or Low Input(Line)? At your own Risk,you can test and isolate the Ground from Power Cable with Tape. MfG Markus |
ls4
09:15
it's ok that you are writing english. It is possible that the power source is the source of your light hum. transformers can course a light hum in some situation. It is possible that nothing will happen and your device will work safe and steady. But it is also possible that your detonation is defect. In order to be sure you should send it to rcm. please excuse my bad english greetz Tim |
gunnet
14:41
I'm using high level input and output. But I think it's the same with low level. The hum, wich is light and you can't hear when the music is on, there is also when the source is off. I'll try to change the power cable maybe it's faulty... and then I will contact the seller for replacement... |
sakly
11:43
erstellt: 15. Jul 2006, |
In this fact it is almost for certain that the hum is coming straightly from your transformer. In some amps the transformers are not adequate mounted or it has some loosely windings, so you can hear the hum caused by the line voltage. |
gunnet
18:02
erstellt: 02. Aug 2006, |
is it in someway dangerous? you know I want to sleep secure.... |
sakly
21:16
No, it isn't dangerous at all. |
RCM Detonation DT 150 da_basti am 14.07.2008 – Letzte Antwort am 17.07.2008 – 4 Beiträge |
RCM Detonation DT-300 DT300 Schaltplan gesucht Hardy_k am 14.06.2008 – Letzte Antwort am 04.09.2008 – 4 Beiträge |
Subwoofer Tangband W8 670Q + RCM Detonation Dt 80 creapetime am 26.01.2014 – Letzte Antwort am 29.01.2014 – 9 Beiträge |
Mivoc Am80 oder RCM Detonation DT-50 als Aktivmodul? Tobi123789 am 04.04.2014 – Letzte Antwort am 09.04.2014 – 6 Beiträge |
Filterart bei RCM Detonation Subwoofermodulen? Vadi am 17.02.2006 – Letzte Antwort am 17.02.2006 – 6 Beiträge |
Detonation DT-80, Crossover bei High Level? askel am 15.02.2013 – Letzte Antwort am 29.10.2013 – 4 Beiträge |
Detonation 80 Eredar am 19.03.2008 – Letzte Antwort am 19.03.2008 – 3 Beiträge |
DIY Subwoofer aus ?Magnat MW AL 300 CP 4155 DX? & ?RCM Detonation DT 300? *KlingKlang* am 26.07.2016 – Letzte Antwort am 30.07.2016 – 9 Beiträge |
Hypex DS 4.0 oder Detonation DT 300 ? schmappel am 24.02.2011 – Letzte Antwort am 01.03.2011 – 27 Beiträge |
Detonation DT 150 und Yamaha R-S700 check0 am 01.08.2015 – Letzte Antwort am 04.08.2015 – 6 Beiträge |
Top Produkte in Subwoofer
- Registrierte Mitglieder929.116 ( Heute: 9 )
- Neuestes MitgliedWT1851
- Gesamtzahl an Themen1.559.721
- Gesamtzahl an Beiträgen21.733.248
