Sony TC-K990 ES needs repairing - help needed!
razvan_botezatu
#1 erstellt: 29. Dez 2014, 14:11
Hi everyone,
I need your support with my Sony TC-K990 ES that I bought on E-bay, it needs repair or tuning of the recording controls (bias, recording level etc); it looks like somebody played with the electronics so now the device can play but the recording is totally messed up.
Can you recommend somebody that can do some 'tuning' or refurbisment?
Many thanks in advance!
Razvan
Radiowaves
#2 erstellt: 30. Dez 2014, 01:47
playback of a "foreign" recording sounds ok? Is this the case without Dolby and also with Dolby (if the recordings are made with Dolby)? If yes, playback can be used to try to adjust recording. So the trick is to adjust the recording parameters until recording -> playback sounds ok. This of course needs high quality playback of "foreign" tapes that are conform with the standard.
What is the problem with the recordings made on this machine? To analyze this a little bit better please switch of Dolby NR. Dolby as a compander system needs specified levels on recording and playback, i.e. the tape sensitivity and the recording amp have to be properly adjusted. Then use center-setting for BIAS and the small "Rec.Level" (this is tape sensitivity) nad "normal" Rec EQ.
Then do a recording with a quite standard tape (Maxell XL-II, TDK SA, BASF Chrome extra) and play it back. Is the playback quality ok?
If not: what is wrong? Too less treble, too much treble, very noisy, distorted? Too loud or very silent (compare the level meter during recording and playback)?
Sanyo JCX 2300KU - Help needed
HHornBRE am 09.10.2022  –  Letzte Antwort am 09.10.2022  –  2 Beiträge
Sony TC-KA6ES & TC-C5 spielen nicht
cdamian am 27.10.2008  –  Letzte Antwort am 07.08.2012  –  19 Beiträge
Tapedeck Sony Tc-186SD
René_B. am 06.03.2014  –  Letzte Antwort am 07.03.2014  –  3 Beiträge
Sony TC 755
1lucbesson am 12.09.2011  –  Letzte Antwort am 16.09.2011  –  16 Beiträge
Sony TC K511S leiert
renegatul am 27.11.2012  –  Letzte Antwort am 01.12.2012  –  6 Beiträge
Sony TC-K Modelle
luegdunix am 22.08.2020  –  Letzte Antwort am 23.08.2020  –  4 Beiträge
Sony Tapedeck TC-K88B
aileena am 05.03.2007  –  Letzte Antwort am 06.03.2007  –  6 Beiträge
SONY TC-K715s reparierbar?
am 07.07.2008  –  Letzte Antwort am 08.07.2008  –  4 Beiträge
Sony TC-K808ES
MikeDee am 19.09.2012  –  Letzte Antwort am 02.01.2016  –  14 Beiträge
Reparatur Sony TC-WR670
lukaslsm am 20.03.2014  –  Letzte Antwort am 26.03.2014  –  2 Beiträge
2014
  • Registrierte Mitglieder929.116 ( Heute: 9 )
  • Neuestes MitgliedWT1851
  • Gesamtzahl an Themen1.559.725
  • Gesamtzahl an Beiträgen21.733.390
