HIFI-FORUM » Reparatur & Wartung » Hifi-Klassiker » Telefunken TL70 renovieren | |
Telefunken TL70 renovieren+A -A |
arusha
#1 erstellt: 07. Apr 2015, 10:36 | |
Hello! First of all I have to choose between my noob english, or "google translator" German. I think my english is understandable. (sorry) I have an amazing pair Telefunken TL70 loudspeakers with beautiful sound. But theese speakers are 40+ years old, and I want to refresh the crossovers. The question is: Is it a good idea to replace all capacitors to Jantzen Cross cap 400V? The two 50uF capacitors are ELKO. Cause the new capacitors's lower ERS problem? I would like to hear the original sound of theese speakers. I would be grateful all of your suggestions. |
Rabia_sorda
#2 erstellt: 07. Apr 2015, 12:49 | |
Hello! Think you that capacitors are defekt?What says the capacitor measuring instrument? Well, i think the idea to replace the capacitors to Jantzen Cross cap ( MKT, MKP ) is good.But not for C1.This must definitely a electrolytic capacitor for subwoofers. |
Detsi_Bell
#3 erstellt: 07. Apr 2015, 19:43 | |
Hi arusha!
No! Because:
You may replace the two Elkos with new devices of good quality, they rely on chemical processes and no one ever planned 40 years of lifetime for them. The other Caps may be measured, but life in a home speaker crossover is not very demanding, so they should be nearly like new. Best: Detsi |
arusha
#4 erstellt: 08. Apr 2015, 10:05 | |
Still I couldnt measured, but I think the Elkos lost capacity (some dried fluid on their), and I think c4 to, because the midrange/tweeter change different frequencys. C3 is WIMA MKS 100V, I think it is ok. So I have to measured all capacitors. The ELKOs( C1, C2) must change, C1 for subwoofer a good quality ELKO (jantzen electrolityc?), and C2 for midrange, a good quality foil, for example jantzen cross cap. Other capacitors if they lost capacity, change their. Subwoofer need electrolityc cap, because ESR effect is bigger on low frequencys? And missing ESR causes too much bass? Thank you very much for your reply! |
Detsi_Bell
#5 erstellt: 08. Apr 2015, 17:58 | |
According to the schematic, C4 should be of same type as C3. Can you show some pics? Elkos do have higher ESR than Foil-Caps, but this was already taken into account during the design of the crossover. If you change the types, you can't really expect the original sound. To which degree it will change can't be predicted, but don't think a "better" cap will make a better sound. It can make another sound (with very small changes), thats all. Best: Detsi |
arusha
#6 erstellt: 10. Apr 2015, 08:59 | |
C3, C4 are not same. C3 is red 4uF WIMA MKS 100V, C4 is green I think polipropilen 6,8uF 100v. C1, C2 are the big gray Frolyt Elyt 50uF 20V electrolitic caps. some better resolution pictures: https://www.flickr.c...et-72157633050837761 |
Detsi_Bell
#7 erstellt: 10. Apr 2015, 11:30 | |
Yes, OK, they 're not exactly the same, but in this context, namely Elko vs. Foil, they are. I can still not see any need to replace C4. Best: Detsi |
Korn & Macway SP-100 * Renewal of electrolytic capacitors HOTaljaard am 24.08.2024 – Letzte Antwort am 23.09.2024 – 2 Beiträge |
problem with Telefunken CR100 stevenrob am 17.12.2016 – Letzte Antwort am 30.12.2016 – 8 Beiträge |
Saba Telewatt TR 60 Kopfhörer connection Cain_Classics am 30.06.2010 – Letzte Antwort am 30.06.2010 – 2 Beiträge |
MAGNETOPHON 3000 HIFI TELEFUNKEN UMSCHALTER VORBAND/HINTERBAND GIORGIO_MARTINI am 01.08.2020 – Letzte Antwort am 01.08.2020 – 3 Beiträge |
RFT PA 2030 hongvan am 27.01.2017 – Letzte Antwort am 28.01.2017 – 6 Beiträge |
Grundig v5000 buzzing sound from headphones help zoso-yu am 22.04.2018 – Letzte Antwort am 15.05.2018 – 17 Beiträge |
Technics sh 8066 defekt Antonello4923 am 10.04.2020 – Letzte Antwort am 11.04.2020 – 10 Beiträge |
Accuphase e-204 [english] purrpurrpurr am 13.08.2018 – Letzte Antwort am 19.08.2018 – 6 Beiträge |
ITT schaub lorenz 6000 no sound verstringeld am 10.06.2016 – Letzte Antwort am 10.06.2016 – 2 Beiträge |
Akai GX 653D blowing fuse capstan motor stops Woadl am 04.07.2013 – Letzte Antwort am 19.09.2013 – 24 Beiträge |
2015
- WD40 als Kontaktspray?
- "Tapedeck-Reparatur" Thread
- Registrierte Mitglieder927.484 ( Heute: 3 )
- Neuestes MitgliedSansibar1968
- Gesamtzahl an Themen1.555.743
- Gesamtzahl an Beiträgen21.644.633
