HIFI-FORUM » Reparatur & Wartung » Hifi-Klassiker » Accuphase e-204 [english] | |
Accuphase e-204 [english]+A -A |
purrpurrpurr
10:01
erstellt: 13. Aug 2018, |
Accuphase E-204 I believe the relay switch on my E-204 has died. A while ago it stopped working for a week (no relay click as it powered on, assume it was the relay). It worked again for a while again, but is back to not working (power up, red button lights up but no relay click, nothing does anything Before the (probably) relay issue, I had crackle from the volume pot. (and one of the EQs), never got round to fixing it. Sometimes the volume pot would result in lower volume from one channel than the other. Twisting it fast would fix it. I have heard that no standard part is made that is compatible with the old relay switch and you have to modify things. My questions: A) How much might it be worth to some one interested in repairing it? (I live near Frankfurt am Main and am only interested in some one who can collect it) B) How much might it cost (at least / certainly not more than) to have a shop repair it (assuming relay and volume pot replacement) If A is low and B is high I will probably do some research and change the relay and clean the volume pot myself. If anyone has info at hand about how to deal with the relay change then it would be welcome! Note: I have never used it with a turntable in the 14-15 years I have owned it, so I don't know anything about the state of those inputs. |
Poetry2me
20:24
Poetry2me
20:39
Poetry2me
20:50
Or is your problem at the outputs of power amp channels? |
purrpurrpurr
02:33
erstellt: 19. Aug 2018, |
![]() That's the one! Haven't had much time recently but looks like I'll be soldering (assuming it needs soldering) soon! Thank you very much! [Beitrag von purrpurrpurr am 19. Aug 2018, 02:38 bearbeitet] |
Poetry2me
10:48
I just realize that my Hitachi HA-6800 MOSFET amp had a very similar loudspeaker relay, only that contacts were of type NO (normally open) and for Accuphase E-204 the contacts are of type changeover (or transfer). The difference may only be that one pair of pins is removed in the NO type. ![]() This is what my "drop-in" replacement required me to do, reusing the solder-points as far as possible. You can see the holes I drilled. ![]() - Johannes |
ITT schaub lorenz 6000 no sound verstringeld am 10.06.2016 – Letzte Antwort am 10.06.2016 – 2 Beiträge |
Accuphase P600 problema digital display yena60 am 13.11.2021 – Letzte Antwort am 19.03.2024 – 4 Beiträge |
Akai gx 630 defekt Antonello4923 am 21.10.2021 – Letzte Antwort am 28.10.2021 – 4 Beiträge |
RFT PA 2030 hongvan am 27.01.2017 – Letzte Antwort am 28.01.2017 – 6 Beiträge |
Grundig v5000 buzzing sound from headphones help zoso-yu am 22.04.2018 – Letzte Antwort am 15.05.2018 – 17 Beiträge |
Akai GX 653D blowing fuse capstan motor stops Woadl am 04.07.2013 – Letzte Antwort am 19.09.2013 – 24 Beiträge |
Grundig SXV6000 dead left channel lubomir.germany am 13.09.2014 – Letzte Antwort am 14.09.2014 – 2 Beiträge |
TOSHIBA GT20D201 IGBT for Sherwood TEMA A-1 power amp ktiner am 13.08.2021 – Letzte Antwort am 02.05.2022 – 9 Beiträge |
Korn & Macway SP-100 * Renewal of electrolytic capacitors HOTaljaard am 24.08.2024 – Letzte Antwort am 23.09.2024 – 2 Beiträge |
Technics sh 8066 defekt Antonello4923 am 10.04.2020 – Letzte Antwort am 11.04.2020 – 10 Beiträge |
2018
- WD40 als Kontaktspray?
- "Tapedeck-Reparatur" Thread
- Registrierte Mitglieder928.997 ( Heute: 6 )
- Neuestes MitgliedUmkalino
- Gesamtzahl an Themen1.559.462
- Gesamtzahl an Beiträgen21.727.152
