HIFI-FORUM » Do it yourself » Lautsprecher » welchen Bass in La Scala Nachbau | |
welchen Bass in La Scala Nachbau+A -A |
caRRoxwatch
00:08
erstellt: 21. Feb 2013, |||
Hi, werde mir das La Scala Bassgehäuse bauen....... als Mitten ein Kleines Sato Horn mit K-55-V Treiber als Hochton den FOSTEX FT65H Befeuert wird dann mit einer SUN AUDIO (Uchida) F2a11 ca. 6watt In Frage kommen 4 Modelle von EMINENCE: BETA 15A Resonant Frequency (fs) 53Hz DC Resistance (Re) 5.75 Coil Inductance (Le) 0.67mH Mechanical Q (Qms) 8.14 Electromagnetic Q (Qes) 0.52 Total Q (Qts) 0.49 Compliance Equivalent Volume (Vas) 60.1 liters / 2.1 cu. ft. Peak Diaphragm Displacement Volume (Vd) 102cc Mechanical Compliance of Suspension (Cms) 0.36mm/N BL Product (BL) 9.6 T-M Diaphragm Mass inc. Airload (Mms) 25 grams Efficiency Bandwidth Product (EBP) 103 Maximum Linear Excursion (Xmax) 3.0mm Surface Area of Cone (Sd) 344.9cm2 Maximum Mechanical Limit (Xlim) 8.6mm Kappa 15A Resonant Frequency (fs) 33Hz DC Resistance (Re) 5.22 Coil Inductance (Le) 1.05mH Mechanical Q (Qms) 8.90 Electromagnetic Q (Qes) 0.33 Total Q (Qts) 0.32 Compliance Equivalent Volume (Vas) 321.3 liters / 11.35 cu. ft. Peak Diaphragm Displacement Volume (Vd) 343cc Mechanical Compliance of Suspension (Cms) 0.31mm/N BL Product (BL) 15.7 T-M Diaphragm Mass inc. Airload (Mms) 76 grams Efficiency Bandwidth Product (EBP) 98 Maximum Linear Excursion (Xmax) 4.0mm Surface Area of Cone (Sd) 856.3 cm2 Maximum Mechanical Limit (Xlim) 11.6mm Kappa 15LFA Resonant Frequency (fs) 39Hz DC Resistance (Re) 5.4 Coil Inductance (Le) 1.27mH Mechanical Q (Qms) 6.08 Electromagnetic Q (Qes) 0.41 Total Q (Qts) 0.38 Compliance Equivalent Volume (Vas) 159.0 liters / 5.6 cu. ft. Peak Diaphragm Displacement Volume (Vd) 471cc Mechanical Compliance of Suspension (Cms) 0.15mm/N BL Product (BL) 18.6 T-M Diaphragm Mass inc. Airload (Mms) 105 grams Efficiency Bandwidth Product (EBP) 95 Maximum Linear Excursion (Xmax) 5.5mm Surface Area of Cone (Sd) 856.3 cm2 Maximum Mechanical Limit (Xlim) 10.4mm Delta 15 LFA Resonant Frequency (fs) 41Hz DC Resistance (Re) 6.3 Coil Inductance (Le) 1.49mH Mechanical Q (Qms) 6.65 Electromagnetic Q (Qes) 0.64 Total Q (Qts) 0.58 Compliance Equivalent Volume (Vas) 186.1 liters / 6.6 cu. ft. Peak Diaphragm Displacement Volume 411cc Mechanical Compliance of Suspension 0.19mm/N BL Product (BL) 14.5 T-M Diaphragm Mass inc. Airload (Mms) 64 grams Efficiency Bandwidth Product (EBP) 64 Maximum Linear Excursion (Xmax) 4.8mm Surface Area of Cone (Sd) 856.3 cm2 Maximum Mechanical Limit (Xlim) 16.5mm vieleicht hat ja hier schon jemand Erfahrungen gemacht............ Schalldruckstarke Grüße, Carlos [Beitrag von caRRoxwatch am 21. Feb 2013, 00:09 bearbeitet] |
PokerXXL
20:27
erstellt: 22. Feb 2013, |||
Moin Carlos Ich habe zwar keine praktischen Erfahrungen mit dem La Scala,aber vielleicht hilft dir dieser Thread etwas bei deiner Suche. ![]() Greets aus dem Valley Stefan |
Sqwan
20:51
So weit ich weiß, ist der Kappa kein Sub sondern eher nen Mitteltöner. Sollte noch mal jemand verifizieren. Vom rest hab ich garkeine Ahnung ... |
caRRoxwatch
22:59
hab das glück gehabt noch ein Paar originale Klipsch K-33 zu ergattern ![]() ab März gehts dann los............. |
PokerXXL
00:32
erstellt: 23. Feb 2013, |||
Moin,moin @ Carlos Umso besser ![]() ![]() Ein kleiner Bericht wäre imho später schön,irgendwie ist hier im HF die Luft dünn gesät was die La Scala betrifft. ![]() ![]() @ Sqwan Die La Scala ist ja eigentlich auch nicht als Sub entwickelt,sondern war ursprünglich,man korrigiere wenn ich mich irren sollte ,ein Speaker für Wahlkampfreden seinerzeit (natürlich mit dem entsprechenden MT und HT-Teil obendrauf) Allerdings gibt es zumindestens für die Nachbauer mit dem originalen Treiber eine erprobte .Tiefentuningmaßnahme. ![]() Greets aus dem Valley Stefan |
mroemer1
00:48
Genau so ist es.
Wenn wundert das wirklich? Die La Scala ist verhältnismäßig teuer, sie bietet nahezu keinen Tiefbass und ist dazu noch recht groß und klanglich muß mann sie mögen mit ihrer Abstimung. Die ganze Heritageserie von Klipsch wird wohl nur noch recht mäßig verkauft und wenn geht mal eine Cornwall über den Ladentisch, dann hier und da eine Heresy, selten eine La Scala oder gar das K-Horn. Aber hier geht es ja um einen Nachbau, ich weiß nicht welche Treiber der damalige ACR La Scala Nachbau verbaut hatte und ob da evtl. etwas passen könnte. [Beitrag von mroemer1 am 23. Feb 2013, 00:52 bearbeitet] |
PokerXXL
01:55
Moin mroemer1 Stimmt klein ist sie nicht unbedingt,aber imho durchaus für den Kickbaßbereich aufwärts bis ca 350-400Hz eine Überlegung wert,wenn man nur wenig Leistung zur Verfügung hat. Und lt. dommiii sogar ein echtes Horn im Gegensatz zu dem, dem WAF geschuldeten kleineren Mischformen die den Markt beherrschen. Es gibt halt nur wenige ,die nicht in irgendeiner Art und Weise einem gewissen Einrichtungszwang (Mode,Lebenspartnerinnen,Design oder ählichem) unterliegen und gleichzeitig große Hornfans sind. ![]() ![]() Carlos hat anscheinend ein paar K33 also die originalen Treiber von Klipsch ergattern können. Damit könnte er ja auf jeden Fall den Mod machen und bei Nicht-Gefallen wird die Verbindung zwischen der La Scala und dem als Sockel getarnten Mod wieder geschlossen.. ![]() Greets aus dem Valley Stefan |
Sqwan
14:32
Ich möchte hier noch mal Bassgehäuse betonen, weshalb ich noch mal drauf hin gewiesen habe, dass der Treiber kein Basstreiber ist. Unabhängig jetzt mal vom gehäuse das ich nicht kannte. Hab ich wieder was gelernt ![]() |
Klipsch La Scala Nachbau Klangkurve~ am 08.05.2013 – Letzte Antwort am 11.05.2013 – 32 Beiträge |
Welchen Treiber für Klipsch La Scala Horn? wotan24 am 19.12.2005 – Letzte Antwort am 23.01.2009 – 13 Beiträge |
Vergleich Klipsch la Scala & Visaton Monitor Bas8888 am 11.03.2008 – Letzte Antwort am 17.03.2008 – 9 Beiträge |
Klipsch La Scala - Welche Tops und welcher Woofer ? Lawyer am 20.06.2007 – Letzte Antwort am 20.06.2007 – 2 Beiträge |
Klipsch La Scala Eigenbau - wird nie was HILFE!!! zomar am 14.11.2007 – Letzte Antwort am 16.11.2007 – 31 Beiträge |
Kantata Nachbau Jens6777 am 28.01.2013 – Letzte Antwort am 28.01.2013 – 2 Beiträge |
BB-Nachbau simba67 am 26.11.2008 – Letzte Antwort am 28.11.2008 – 13 Beiträge |
Lautsprecher Nachbau apfmh am 28.01.2018 – Letzte Antwort am 28.01.2018 – 8 Beiträge |
Teufel Nachbau boxenmartl am 05.12.2004 – Letzte Antwort am 05.12.2004 – 2 Beiträge |
Kort Nachbau wOuLd am 23.07.2018 – Letzte Antwort am 11.10.2021 – 26 Beiträge |
2013
Top Produkte in Lautsprecher
- Registrierte Mitglieder926.951 ( Heute: 3 )
- Neuestes MitgliedAn_inspiration_for_t...
- Gesamtzahl an Themen1.554.368
- Gesamtzahl an Beiträgen21.611.766
