Emotiva Basx TA1
elia77
#1 erstellt: 03. Okt 2022, 13:10
Es gibt ja nun den Nachfolger des TA100, den TA1 dort steht in der Bedienungsanleitung zur Einbindung eines Subwoofer:
BasX TA1 4. Summed Subwoofer Output (With Active Low-Pass Filter) This output allows you to connect a powered subwoofer to the TA1 via the 90 Hz active low-pass f ilter portion of the internal bass management crossover.
5. Crossover Outputs (With Active High-Pass Filters) These outputs provide a signal that has been routed through the 90 Hz active high-pass filter portion of the internal active bass management crossover.
6. Main Outputs (Line Level) These are the line level Main Outputs on your TA1. When the Crossover Switch is set to Full Range they provide a full range signal; when the Crossover Switch is set to High Pass they deliver a signal that is passed through the 90 Hz active high-pass filter portion of the internal active bass management crossover.
7. High-Pass / Full Range Crossover Switch THIS SWITCH CONTROLS BOTH THE SIGNAL THAT IS SENT TO THE MAIN LINE LEVEL OUTPUTS AND THE SIGNAL THAT IS SENT TO THE INTERNAL AMPLIFIERS. When this switch is set to Full Range both the Speaker Outputs and the Main Outputs receive a full range stereo signal. When this switch is set to High-Pass both the Speaker Outputs and the Main Outputs receive a signal that has been routed through the active high-pass filter portion of the internal crossover on the TA1. Note: The High-Pass setting is normally used when the speakers connected to the Speaker Outputs on the TA1 are being used with an active subwoofer in a full 2.1 channel system
Nun verstehe ich nicht ganz was es da mit den low und high-pass filtern auf sich hat. Kann ich nun die Lautsprecher so trennen wie bei einem AVR bzw das diese nur bis zb 50hz spielen u dann der sub übernimmt?
Viele Grüße
[Beitrag von elia77 am 03. Okt 2022, 13:42 bearbeitet]
Prim2357
#2 erstellt: 03. Okt 2022, 13:45
90Hz, nicht 50Hz...
und nur bei 90Hz.
Emotiva Basx TA1 brummt
elia77 am 04.02.2023  –  Letzte Antwort am 09.02.2023  –  7 Beiträge
Low Pass Filter Hilfe!!
strikeforce2 am 18.08.2005  –  Letzte Antwort am 18.08.2005  –  3 Beiträge
Pass ade?????
donluto am 21.11.2005  –  Letzte Antwort am 12.07.2022  –  54 Beiträge
Filter subsonic, low, high
Stockwerk am 14.04.2010  –  Letzte Antwort am 17.04.2010  –  7 Beiträge
How to connect a Subwoofer to the preamp. out L/R
T.O.S am 06.12.2022  –  Letzte Antwort am 02.01.2023  –  22 Beiträge
Cinch High-Pass Filter für Subwoofer an Sony TA-F550ES Verstärker
astonmarkus am 25.09.2021  –  Letzte Antwort am 27.09.2021  –  7 Beiträge
Pass XA.5 Class A - Erfahrungen
nuernberger am 04.11.2012  –  Letzte Antwort am 16.10.2013  –  6 Beiträge
Stasis, Pass, Threshold .
hal-9.000 am 05.05.2007  –  Letzte Antwort am 10.05.2007  –  22 Beiträge
Nelson Pass Aleph 0
Fantastic_Mike am 19.03.2004  –  Letzte Antwort am 02.05.2014  –  3 Beiträge
McCrypt PA-8000 vs Dap Palladium Vintage P-500
Adrian_D am 09.10.2005  –  Letzte Antwort am 12.10.2005  –  4 Beiträge
2022
  • Registrierte Mitglieder928.589 ( Heute: 1 )
  • Neuestes MitgliedBaldurSH
  • Gesamtzahl an Themen1.558.541
  • Gesamtzahl an Beiträgen21.704.776
