HIFI-FORUM » Reparatur & Wartung » Elektronik (Stereo&Surround) » akai am-95 überlastet | |
akai am-95 überlastet+A -A |
sylt110
#1 erstellt: 13. Sep 2009, 10:39 | |
hallo also zum ersten problem die anziegen von meinem akai verstärker blinken was kann das sein? 2. wenn ich eine der drei sicherungen raushole hört er auf zu blinken und die ls brennen durch was kann das seine ich bedanke mich im voraus für die antworten sylt110 |
tri-comp
#2 erstellt: 13. Sep 2009, 22:23 | |
Hi, The AM-95 has a protection-circuit that cuts-out the speakers when the output-amplifier is defective (Shorted transistors etc.). This circuit also drives a pulse-generator that makes the Power-LEDs flash in case of fault. So, You need to take this very nice amplifier to someone professional who knows how to repair it. Stop pulling fuses or replacing them. You will just make things worse. I can help with a manual/schematics BUT... you should be very sure you are up to start repairs. This amp is very special and powerfull (2x180W DIN/4 Ohm) and deserves to be treated with respect. If you are REALLY in luck the fault will be in the protection-circuit itself. It's build around IC1/HA12002. ALL electrolytic capacitors in the circuit could be a problem. Even if the fault is found to be elsewhere I would still replace these capacitors. They are: C4B (Unknown value), C5(4.7uF/25V), C6(10uF/16V), C7(330uF/16V) mfg, /tri-comp |
sylt110
#3 erstellt: 14. Sep 2009, 14:13 | |
hallo thank you, however, problem I still have. with us there is nobody shop or elektroniker. I must only look because this should run to hallowen again. nevertheless, thank you mfg sylt110 |
Reparatur Akai AM 93 / 95 & Servicemanual chrisracing am 16.03.2011 – Letzte Antwort am 03.06.2011 – 2 Beiträge |
Akai AM 95 fachmännisch reinigen lassen Herbie55 am 06.04.2017 – Letzte Antwort am 09.04.2017 – 2 Beiträge |
AKAI AM-37 Potentiometer wechseln Mandelbrot am 25.10.2020 – Letzte Antwort am 25.10.2020 – 6 Beiträge |
AKAI AM-67 "Wackelkontakt" bobofsideshow am 10.11.2015 – Letzte Antwort am 11.11.2015 – 2 Beiträge |
Service Manual --> Akai AM-93 Akai_Reference_Master am 05.03.2005 – Letzte Antwort am 16.03.2011 – 5 Beiträge |
AKAI CD-55 swempa am 10.04.2009 – Letzte Antwort am 02.06.2009 – 2 Beiträge |
AKAI AM M939 Schutzschaltung drachirs am 06.11.2016 – Letzte Antwort am 21.11.2016 – 14 Beiträge |
Akai -am 47 landlaus am 11.08.2016 – Letzte Antwort am 13.08.2016 – 5 Beiträge |
Probleme bei Akai AM 75 angrybert am 18.12.2015 – Letzte Antwort am 20.12.2015 – 4 Beiträge |
Akai AM-37 // 2 "Probleme" Cole_Phelps am 21.12.2012 – Letzte Antwort am 02.01.2013 – 8 Beiträge |
- PV Anlage stört auf UKW
- Verstärker rauscht
- Registrierte Mitglieder927.068 ( Heute: 5 )
- Neuestes MitgliedHattsieg_
- Gesamtzahl an Themen1.554.700
- Gesamtzahl an Beiträgen21.620.015
