HIFI-FORUM » Do it yourself » Lautsprecher » visaton B200+Monacor RBT 95 | |
visaton B200+Monacor RBT 95+A -A |
paolocusini
14:37
erstellt: 17. Aug 2006, |
Hallo to everybody im Paolo from Italy. Im looking to the Solo 100 project with the new ribbon tweeter from Monacor RBT 95.Someone can help me to design the crossover. Thank you very much |
geist4711
18:39
hi, when im knowing right, than will the ribbon firstly com to market in a fiev month, so nobody nows in time, if it works god with an other speaker or in the solo100. but somebody here in the forum is waiting with much interesst of the coming-out... from the datas, what i haf seen, it coud be an good speaker, will see, what the reality say, when its 'free for saling'.. hope you'll understand my posting, my english isn't so god. mfg robert [Beitrag von geist4711 am 17. Aug 2006, 18:42 bearbeitet] |
paolocusini
20:13
thank you Robert.What do you think about another tweeter for the SOLO 100 project? |
geist4711
22:20
hi, i mean, that the B200 normaly dont need an HT -it works fine only with his 'sperrkreis(don't know the englisch word). i had, befor al longer time, the solo50 here in my room, for testing(had the chance to get a probing-pear for some days, for to cross-hearing with my bl-horns with BG20 -on a tube-amp and i found it was good anoth(okay the bl-horns whree mutch better sounding on an tube-amp -the solos are made for transitor-amp and i coud hear that, when i take an transistor-amp -but 'horn is horn' and the bl's was it eval whatfor an amp had give the power) when i woud take an HT for the solo's, i whoud test an 'good old' konus-ht, or the ring-radiator(by using the visaton-programm), because they have an near-the-same abstrahlverhalten(dont know the word) as th BB's mfg robert |
kboe
23:38
hello paolo! i think it is not a very wise solution to combine the b200 with a tweeter. it is designed to run without one and it does so more or less. ( I personally do miss a tweeter with all the b200 setups I have heard so far ) BUT: if you want to use a tweeter anyway, there is no need to go for the quite expensive b200. a less expensive bass-mid unit would then do a job as good as the b200. for exemple the bg20 would be in my choice for this case ( it is far cheaper and does have TSPs quite suitable for a bass-reflex cabinet, which the b200 does not have either ) regards kboe [Beitrag von kboe am 17. Aug 2006, 23:39 bearbeitet] |
Niwo!
00:55
erstellt: 18. Aug 2006, |
hello paolo I agree to geist and kboe. The B200 is designed to work without HT. If you think you need one it had to be of best quality. The RBT95 would also be my first choice for a low cost solution, or the Visaton TL16H if money dosn`t matter. ![]() I agree to kboe that you dont need a b200 if you use a HT. Then BG20 would be the better choice. You can see a solution with one or two BG20 on the thread: ![]() and here with a new designed horn-box: ![]() This "Mohai" works with a Visaton DHT9 tweeter. A solution with the Monacor PA95 is in progress. ![]() As soon as the RBT95 arrives I will try to make a test with it also. Greetings Wolfgang |
Niwo!
15:52
Hello Paolo I have added some information about the Mohai in english language in the threads here: ![]() and here: ![]() greetings Wolfgang |
paolocusini
21:03
Thanks a lot to all of you. My idea was help Solo 100 Down whit a subwoofer and up with a tweeter. I have got allready the sub,a Zyklop project build with the same look of Solo 100. Im an absolute beginner in diy,english and german. I follow your projects on the forum. Thanks one more time and i think this is the best forum on the net |
kboe
23:31
hello paolo again for an absolute beginner, you are willing to spend quite a lot of additional mony ontop of the b200. i would start up with this and then add sub and woofer only if i miss something...... regards kboe |
Monacor RBT-95 Jonny_der_Depp am 22.05.2008 – Letzte Antwort am 20.02.2011 – 32 Beiträge |
Erfahrungen mit Monacor RBT-95 /SQ Fischmeister78 am 26.11.2007 – Letzte Antwort am 15.10.2011 – 16 Beiträge |
Visaton B200 mickyderhund am 05.10.2006 – Letzte Antwort am 23.08.2015 – 11 Beiträge |
MONACOR - Typ : RBT-80 Steiner* am 22.09.2008 – Letzte Antwort am 09.08.2015 – 49 Beiträge |
monacor rbt 1000 LEMMMY am 25.05.2013 – Letzte Antwort am 27.05.2013 – 3 Beiträge |
Visaton B200 im Horn? Papasierra am 16.02.2008 – Letzte Antwort am 18.02.2008 – 16 Beiträge |
Regalbox mit RBT-95 und SPH-60X (Monacor) chrishoffi am 14.12.2010 – Letzte Antwort am 16.12.2010 – 15 Beiträge |
Goldiger Monitor: Monacor RBT-95 und Swans M5N? clp99 am 21.12.2015 – Letzte Antwort am 23.12.2015 – 9 Beiträge |
Monacor Breitbänder (SP-200X) + Magnetostat (RBT-95) in geschlossener Box ortech am 09.11.2014 – Letzte Antwort am 16.02.2016 – 10 Beiträge |
Fostex 206e oder Visaton B200? alexhh am 24.10.2004 – Letzte Antwort am 09.11.2004 – 36 Beiträge |
2006
- Registrierte Mitglieder928.932 ( Heute: 3 )
- Neuestes Mitgliednwolfe
- Gesamtzahl an Themen1.559.318
- Gesamtzahl an Beiträgen21.723.537
