HIFI-FORUM » Fernseher & Beamer » LCD-Fernseher » Sony » Led blinkt 6x, wiederholt sich. | |
Led blinkt 6x, wiederholt sich.+A -A |
of-tv
20:06
erstellt: 17. Feb 2020, |
Hallo, Ich habe hier ein Sony Led tv,KDL-75W855. Nach dem Einschalten, kommt kurz Sony Logo,dann geht weg und Led blinkt 6x und wiederholt sıch.keın Ton. S/N 6010684 P/N 18695300 Was kann defekt sein? Es ist um 3 Jahrealt. Vielen Dank. Of-TV |
xutl
20:30
Aus dem Netz ![]() Zeitbedarf für die Suche <60sec. ![]() hm das schaut nicht gut aus... Ich glaube da Hilft nur der techniker oder Austausch. Red led light blinks flashes, red light error code troubleshooting Chart, TV shutsdown Always try power reset, unplug powercord for 5 mins then factory reset tv & update with usb drive from sony site- ![]() 0 no red standby light-check powercord or bad main logic board or power board, check standby volts 1 red blink not used 2 red flashes is bad power board, solution replace power board 3 red flashes is bad main logic or power board, check for standby volts if ok replace main logic board 4 red blinks- can be LD board or main logic board, check inverter board wires for arcing to ground 5 red flashes- bad lcd panel connection or internal lcd short- squeeze bezel to locate bad connection 6 red flashes- ############################## 7 red flashes- main board over heating, can be short on power board or main logic board 8 red flashes- main board sp prot, try power reset, update with usb, or replace main logic board 9 blinks- check fan error, * if TV has fans 10 blinks- digital board or tuner board * some Sony TVs may not have this board 11 red flashes- bad main board, bad IC, replace main logic board 12 red light flashes is tcon error bad T-con board or bad LCD panel, replace tcon board usually 13 red flashing is backlight balance error bad lcd panel or inverter boards (common) or bal board on kdl-52v4100 only, replace inverter board usually then main logic board 14 red flashes HFR- bad TCON or Bad LCD panel, replace tcon board. unplug tcon board if tv stays on without tcon board replace tcon board. share this post to anyone in need. get parts at Shopjimmy or Rivervalley electronics. |
Ralf65
05:44
erstellt: 18. Feb 2020, |
wichtig für eine Beurteilung ist immer die Farbe der blinkenden LED, eine Übersicht gibt es ![]() Rot ist immer eine Signalisierung für einen Fehler (Defekt) [Beitrag von Ralf65 am 18. Feb 2020, 05:45 bearbeitet] |
Spencer2k6
08:58
@ of-tv: Ich habe dir eine private Nachricht geschickt. Bitte teste das mal. [Beitrag von Spencer2k6 am 18. Feb 2020, 08:59 bearbeitet] |
Dermoviemaker
12:05
erstellt: 26. Feb 2020, |
Vermutlich ein panell Schaden. wenn du Pech hast, gibt es kein panell mehr. In den meisten Fällen, werden wir panell nur 3 Jahre gebaut, dann kommen schon die neuen Modelle. war bei meinem auch so. Nach 3 1/2 Jahren 75 Zoll Schrott. habe ein riesiges Fass aufgemacht bei Sony, haben sich nur entschuldigt, mehr nicht. Daher fuer mich ganz klar, keine Sonys mehr. Am besten bei mm oder Saturn kaufen mit 5jahres zusatzgarantie, dann hast du wenigsten fuer 5 Jahre gewissheit, bzw. Bekommst einen neuen. |
Fehler sony kdl 37ex402 - LED blinkt 6x sven503 am 19.05.2014 – Letzte Antwort am 19.05.2014 – 2 Beiträge |
Fehler 46HX925 - LED blinkt 4 mal matty12 am 12.12.2011 – Letzte Antwort am 21.12.2011 – 14 Beiträge |
Sony LED blinkt 6 mal rot metinakdemir am 21.08.2020 – Letzte Antwort am 25.08.2020 – 5 Beiträge |
KDL46-HX757 blinkt rot Guido73 am 03.05.2013 – Letzte Antwort am 19.05.2013 – 3 Beiträge |
Rote LED blinkt 2x bei Sony KDL-55EX715 ac328 am 03.12.2018 – Letzte Antwort am 27.12.2018 – 6 Beiträge |
Sony KDL-32L4000 kBkT grüne LED blinkt 18mal dann rot uelzchen am 14.07.2010 – Letzte Antwort am 15.07.2010 – 2 Beiträge |
KDL-55W805C - LED blinkt 6 mal rot - Totalschaden le_grec am 16.10.2018 – Letzte Antwort am 07.11.2020 – 9 Beiträge |
Sony Bravia KD55XD8577 6x rotes Blinken - Bootlogo kurz sichtbar Kokzreh am 22.11.2024 – Letzte Antwort am 24.11.2024 – 3 Beiträge |
KDL-75W855C blinkt 6 mal rot Das_Keks am 12.01.2022 – Letzte Antwort am 15.03.2023 – 8 Beiträge |
KDL-32WD575 blinkt 4 x rot. matthes1973 am 07.06.2020 – Letzte Antwort am 08.06.2020 – 12 Beiträge |
2020
- XH90 / XH92 Settings Thread
- Registrierte Mitglieder928.761 ( Heute: 5 )
- Neuestes MitgliedGisa/
- Gesamtzahl an Themen1.558.920
- Gesamtzahl an Beiträgen21.713.745
