Gehe zu Seite: |vorherige| Erste ... 300 .. 400 .. 500 .. 600 .. 630 . 640 . 650 . 660 . 665 666 667 668 669 670 671 672 673 674 . 680 . 690 . 700 . 710 .. Letzte |nächste|
Es lebe der Studio-Monitor!
gbm31
#33643 erstellt: 10. Mrz 2020, 16:05
Meinst du klanglich? Weil LP-8 -> 2-Weger ist offensichtlich, oder?
Ein stevenswall macht auf reddit und gearsluts da richtig Wind wegen dem Rauschen,
Some speakers hardly hiss. Most active speakers I've tried hiss enough that it's annoying.
Personal experience from most hiss to least:
Kali Audio IN-8 (I can hear it from 2 meters in a living room even with the fridge running in the next room), JBL LSR308, Mackie HR824, Genelec 1030, Elac Navis (basically silent).
-Source did not make an audible difference.
-Gounded vs. ungrounded plugs didn't make a difference.
-Same circuit vs separate didn't make a difference.
-Unplugging all inputs did not make a difference.
-Shorting inputs did not make a difference.
-Power conditioning did not make a difference.
-You may not hear hiss from the same speakers.
-You also probably don't annoy everyone by plugging your ears during the movies.
-You probably also don't think some showers are too loud, or wear earplugs sometimes while showering.
-I'm picky.
-Fully balanced studio setup that was not making hiss out of an HS8 did not make a difference.
-Turning down the studio monitor or leaving it at half and maximizing volume via the source did not make a difference**
-This is self noise due to lack of a decent output filter or less noisy amp. Because it's self noise, most any suggestion to eliminate hiss isn't going to make a difference.
Wäre blöd wenn der bloss übertreibt. Andererseits komm ich mir blöd vor wenn ich 25kg Lautsprecher unnötig von Thomann und Co. zu mir und zurück transportieren lasse.
Hier das Statement von Kali dazu.
[Beitrag von gbm31 am 10. Mrz 2020, 16:15 bearbeitet]
thewas
#33644 erstellt: 10. Mrz 2020, 16:44
gbm31 (Beitrag #33641) schrieb:
@ thewas:
es gibt Stimmen die den Kalis deutliches Zischen/Rauschen nachsagen. Aktive machen das sowieso, aber ist es so deutlich? Die JBLs sind da auch nicht gerade leise btw...
Ja, sie rauschen, wie die meisten günstigen Class-D Monitore, mich persönlich stört es nicht da ich sie zum Musikhören benutze und nicht zum Ruhe genießen und zudem ich sie ungefähr bei 2 Meter Hörabstand benutze. Für jemanden den das "Leerlaufrauschen" stört und sie als PC Lautsprecher nutzen möchte (dafür sind sie eigentlich auch zu groß) sind sie dann nichts. Um das Rauschen möglichst niedrig zu halten sollte man sie symmetrisch anschließen und hinten den Pegelregler auf die mittige Rasterung einstellen.
***MCFly*** (Beitrag #33642) schrieb:
Wenn schon alle thewas ausquetschen:
Worin besteht der Unterschied zwischen den Kali Audio IN-8 und den Kali Audio LP-8 LS?
3-Wege vs. 2-Wege, Coax vs. nicht Coax und 400€ vs. 300€ Stückpreis (nach meiner Meinung haben die IN-8 das bessere P/L Verhältnis).
PS: Dieser stevenswall versteift sich auch im ASR Forum auf seine eigenen teilweise unsinnigen (damit meine ich nicht das Rauschen, das ist schon sinnvoll) "Obsessionen" die ihm oft von anderen um die Ohren gehauen werden, aber er macht munter weiter....
[Beitrag von thewas am 10. Mrz 2020, 16:46 bearbeitet]
coreasweckl
#33645 erstellt: 10. Mrz 2020, 16:59
Ich denke auch, daß diese Rauschdiskussion völlig übertrieben wird.
Bei der absoluten Mehrheit des Programmmaterials hört das keine Sau mehr..und wen das im Leerlauf stört, kauft sich halt was Anderes. .😁😁
Heule
#33646 erstellt: 10. Mrz 2020, 17:09
Da das Rauschen von aktiven Monitoren je nach Modell und Firma unterschiedlich ist,
kann man dies nicht pauschalisieren! Je nach Musikgeschmack und Hörentfernung
kann es stören oder eben nicht.
Da hilft nur daheim am eigenen Hörplatz bei seiner Musik ausprobieren.
LG Oliver
der_kottan
#33647 erstellt: 10. Mrz 2020, 17:10
Von dem Rauschproblem habe ich auch schon gelesen. Natürlich kein Wort darüber im oben erwähnten Test.
LP 8 ist ein 2 Wegerich.
MarsianC#
#33648 erstellt: 10. Mrz 2020, 18:08
Einmal eine offene KH120.
Einmal JBL 705P ala Amir.
Die extreme Auslöschung bei 750 Hz verstehe ich noch immer nicht, das muss doch lösbar sein?
thewas
#33649 erstellt: 10. Mrz 2020, 18:24
Die Auslöschung ist das Ergebnis ne Portresonanz die auch im S&R Test zu sehen ist und natürlich hätte man die besser lösen können https://www.soundand...feldmonitor-im-test/
Was mich jedoch mehr wundert ist der Mittenbuckel um 1kHz der bei S&R nicht gemessen wurde.
MarsianC#
#33650 erstellt: 10. Mrz 2020, 18:32
Die Entstehung ist mir klar, die Entscheidung das so in den Handel zu bringen nicht.
Warum der Bass wieder nicht passt und der komische Buckel auf einmal da ist darfst du wieder Amir anhängen Eventuell liegts an den 55 °F (12,8 °C)?
Als ich das erste Mal meine damaligen B&W 685 gehört habe waren diese um die 10 °C (eine Nacht im Auto) kalt und klangen wirklich, wirklich falsch.
PS: Danach waren diese deutlich besser, aber nie das was ich wollte.
[Beitrag von MarsianC# am 10. Mrz 2020, 18:39 bearbeitet]
DaleWintry
#33651 erstellt: 11. Mrz 2020, 11:22
Hi
Ich hatte diese Tage bei RCF angefragt, ob man keine Messungen der Ayra Pro Serie als Download anbieten könnte. Tatsächlich hat man diese jetzt in den Specsheets, zu finden unter Downloads, ergänzt.
Servus
bizkid3
#33652 erstellt: 11. Mrz 2020, 14:10
APS hat die Klasik (1000 Euro / Paar) überarbeitet:
http://www.aps-company.com/klasik-2020-en/
We designed and created monitor that:
- sounds even more natural,
- has a clearer and more transparent midrange,
- plays bass with more control and precision,
- has a more practical adjustments of bass depth,
- plays the sound material with less non-linear distortion,
- allows for higher sound levels of SPLmax,
- is equipped with an optical LED override indicator of the power tip "clipping",
- whole acoustic band has more dynamics.
We have achieved the above mentioned advantages through:
- optimization of mid-bass speaker operation in a larger enclosure volume, both in terms of diaphragm excursion as well as currents and electromagnetic fields associated with the speaker coil,
- introduction of controlled acoustic loss, which results in recreating the advantages of a closed enclosure, while maintaining the advantages of a bass-reflex enclosure,
- complete redesign of the bass-reflex port,
- new solutions for bass equalization,
- stiffening of the speaker enclosure and mechanical construction of the electronics,
- increase by 33% the power of the tweeter and mid-bass circuit amplifiers, while optimising amplifiers for a larger volume of enclosure and optimised bass equalization,
- introduction of a practical position of the bass depth switch for the implementer, with simultaneous signalling of the "clipping" effect placed on the front under the logo graphics,
- a number of improvements and changes to the electronics in terms of electrical, mechanical and acoustic design, as well as in terms of repeatability and reliability.
gbm31
#33653 erstellt: 11. Mrz 2020, 14:34
Ich berichte... Sollten bis zum Wochenende bei mir sein.
thewas
#33654 erstellt: 11. Mrz 2020, 15:16
Danke, die Messungen sehen gut aus, die Frage ist mit welcher Glättung ob sie wie oft in der Audio Branche etwas geschönt sind, hoffentlich holt sie jemand von hier oder S&R misst sie auch mal.
SonyKassette
#33655 erstellt: 11. Mrz 2020, 15:31
Hallo zusammen,
ich habe bereits ein Großteil des Threads mitverfolgt, eine Frage die noch nicht beatwortet ist;
Warum sagen viele Toningeneure selber, das sie zum Musik Genießen immer einen normalen Hifi LS bevorzugen würden und lieber keinen Monitor nehmen würden?
Aus meiner Sicht kann ja ein Monitor am "optimalsten" reproduzieren. Ich habe vor ein paar Jahren die alten Geithain RL900 gehört. Das waren bisher die besten LS überhaupt, die würde ich mir sofort zu Hause hinstellen. Deswegen verstehe ich nicht, wie man lieber mit verfälschenden Boxen hört.
Kann mich mal bitte jemand aufklären?
thewas
#33656 erstellt: 11. Mrz 2020, 16:52
Neue? JBL Monitor Serie mit teilweise VU Meter auf deren Front
https://jblpro.com/zh/product_families/nano-k-series
Tobiii2
#33657 erstellt: 11. Mrz 2020, 17:08
Gibt's da Umfragen oder wie? Repräsentativ wird's nicht sein
Aber, mal davon abgesehen, was genau ist denn "Musik geniessen"? Vielleicht etwas ganz anderes als Du es Dir gerade vorstellst. Wer den ganzen Tag Musik hört bzw. berufsbedingt dauerbeschallt wird, der will privat vielleicht nur noch etwas Musik zur Untermalung hören, so dass es bestenfalls im ganzen Raum annehmbar klingt, dafür sind Monitore nicht unbedingt die erste Wahl.
SonyKassette
#33658 erstellt: 11. Mrz 2020, 17:22
https://www.youtube.com/watch?v=JcbHJg5aFgQ
Kann gut sein, wenn ich Musik höre, mache ich meistens nichts nebenbai oder lese vielleicht etwas. Aber ich bin sowieso eher der analytische Hörertyp. Da gab es mal folgende Situation:
Es gibt hier einen Plattenladen, der alle seine Platten vorher probehört, die hört man dann als Besucher zwangsweise mit. Von eineigen Platten weiß ich das die Standboxen über die das ganze läuft wirklich richtig gut klingen. Irgendwann kam ich mal im Plattenladen und habe gefragt, ob die gerade YouTube anheben, weil man Kompressionsartefakte hören konnte. Die Verkäuferin sagte das gerade Schrottify (Spotify) liefe und wunderte sich, das ich sofort den Unterschied in der Audioqualität bemerke.
Wenn ich also Musik höre, möchte ich möglichst alles, was es in der Aufnahme zu hören gibt hören. Und ich möchte auch keine Schönfärber-Boxen. Ganz ehrlich, wenn mir eine Aufnehme zu schlecht ist, höre ich sie nicht an.
[Beitrag von SonyKassette am 11. Mrz 2020, 17:24 bearbeitet]
chro
#33659 erstellt: 11. Mrz 2020, 18:18
Na ganz so pauschalisieren kann man das auch nicht. Höre viel Spotify, und ja es gibt einen Unterschied zu CD, Platte oder guten Dateien. Aber der Unterschied ist zumindest im Premium Account nicht allzu groß.
Und ich höre wesentlich lieber mit einem Monitor mit sehr guter Abstrahlung als mit einem schönfärber LS.
Klar man hat dann manche Aufnahmen die so schlecht sind, das man sie einfach nicht mehr hören kann. Aber umso mehr gewinnen richtig gute Aufnahmen. Da hat sich mein Musikgeschmack über die Jahre auch wegen der Qualität echt angepasst.
Edit: Und die Mär das Youtube überwiegend schlechte QUalität hat ist völlig falsch.
Beispiel Jimmy Sax "no man, no cry"
[Beitrag von chro am 11. Mrz 2020, 18:21 bearbeitet]
mabuse04
#33661 erstellt: 11. Mrz 2020, 19:01
Vielleicht ist das auch einfach nur missverständlich? Denn als ich mal im damaligen Audio-Studio mit einem 56-Kanal SSL Pult saß und zwei Urei 815 Abhören vor mir hatte und der Raum um die quasi drumherum gebaut war - also akustisch ziemlich perfekt, da dachte ich mir, das schaffst du nie zu Hause und habe mir ein paar günstige polnische LS gekauft, ein wenig Dämmwolle reingepackt. Das hat mir für zu Hause gereicht.
Wenn du also kein Heimstudio hast, sondern aufwändig akustisch optimierte Räume, dann kannst du das zu Hause nur schwer erreichen. Dazu kommt noch, dass wenn du den ganzen Tag damit arbeitest, reicht dir eigentlich normales Equipment für zu Hause aus.
Viele Grüße m
Dadof3
Moderator
#33662 erstellt: 11. Mrz 2020, 20:48
Das ist kein Toningenieur. Erwartest du etwa, dass ein Hersteller von Verstärkern für passive Lautsprecher in einem Video die Botschaft verbreitet, dass aktive Studiomonitore doch eigentlich viel besser seien?
PS Audio ist meiner Meinung nach ein ziemlich dubioser Anbieter. Die würden wohl so ziemlich alles behaupten, was dem Geschäft förderlich ist.
Ein Kommentator unter dem Video, der nach eigenen Angaben wirklich Toningenieur ist, sieht das übrigens auch komplett anders:
As a recording and mastering engineer for most of my life, I can't listen to 'consumer speakers', because everything sounds crappy. I am used to listening to speakers that let you hear everything , if it's good it sounds good, if it is less than perfect, it sounds like nothing... I don't want a speaker to 'colour' the sound and make all sound material sound more or less the same.
And yes, I have studio monitors in my living room!
Sollte es aber wirklich eine verbreitete Ansicht unter Toningenieuren sein (was ich nicht unbedingt glaube), dann vermutlich nur, weil man nach einem Tag im Studio mit konzentriertem analytischen Hinhören sich einfach mal mit etwas weicherem und gefälligerem berieseln lassen will.
Ich denke, ein Tester des Guide Michelin freut sich auch am Wochende eher auf Pizza oder Bratkartoffeln als auf gratiniertes Spargelparfait an einer Orangen-Kokosmousse.
[Beitrag von Dadof3 am 11. Mrz 2020, 21:21 bearbeitet]
iaterne
#33663 erstellt: 11. Mrz 2020, 21:00
Hier noch mal eine freundliche Frage nach eurer Meinung
iaterne (Beitrag #33640) schrieb:
kurze Frage an die Profis zum Output Level & Input Gain
Nutze die Neumann 0300 sowie kh120/kh80 für ein 5.1 Setup mit einem Denon AVR, ggf. noch DSP dazwischen (AM 2.0 / MiniDSP DRRC-88a BM)
Für meine geplante Neueinmessung hier nochmal eine Verständnisfrage. Was sind die optimalen Einstellungen für Output Level und Input Gain?
Was sind die Konsequenzen der relevanten Einstellungen (zB Rauschen)?
Aktuell gehe ich davon aus, beides auf Max an allen Monitoren ist am sinnvollsten für die letztlich am AVR erfolgende Lautstärke-Regelung etc., liege ich damit richtig?
In der BDA der 120er steht starte mit beiden Reglern auf Minimum und dreh, bis am Hörplatz der gewünschte Pegel erreicht wird...
Da gibt es ja aber diverse Varianten (zB Input min, ouput max, jeweils mittig etc.) und das Basissignal (AVR-Pegeleinstellung auf wieviel) ist mir dabei auch nicht klar. Mal sehen, ob ihr Licht ins Dunkel bringt ;-)
mabuse04
#33664 erstellt: 11. Mrz 2020, 21:14
Ich will es mal versuchen und bitte korrigiert mich da gerne. Danke.
Erstmal eine Annahme: Du hast den Denon AVR, benutzt aber das eingebaute Audyssey nicht, sondern Dirac im MiniDSP. Korrekt?
Du verwendest aber vom Schalldruck her, sehr unterschiedliche Lautsprecher: KH 80, 120 und 0300. Ich persönlich würde die auf 0 dB einstellen, habe ich bei meinen auch so gemacht, auch sehr unterschiedlich und Dirac den Rest machen lassen.
Alternativ kannst du auch ein Schallpegelmessgerät nehmen und den Pegel von allen auf ungefähr 75 bis 80 dB bei 0 dB Einstellung am Denon und rosa Rauschen einpegeln. Ich würde nicht alle auf Max stellen.
Dann lässt du einen Einmessvorgang mit Dirac durchlaufen und wirst dann sehen, ob es noch stärkere Pegelunterschiede gibt. Die kannst du dann noch manuell regeln. Meistens ist aber Dirac in der Lage, das einzustellen.
Dann sind noch die Abstände und eventuelle Delay-Zeiten zu beachten. Bei Surround ist nicht nur der Pegel wichtig aber auch das, sollte eigentlich Dirac machen und können.
Hoffe es hilft und viele Grüße m
EDIT Mod.: Zitat gekürzt.
[Beitrag von Hüb' am 12. Mrz 2020, 10:56 bearbeitet]
Dadof3
Moderator
#33665 erstellt: 11. Mrz 2020, 21:16
Nein. Du solltest den/die Regler nur so weit aufdrehen, wie es für das Erreichen der maximal von dir gewünschten lautstärke erforderlich ist. Das sorgt für den optimalen Signalrauschabstand.
iaterne
#33666 erstellt: 11. Mrz 2020, 21:41
Ok, das kann ich machen, aber welche Steuerung ist denn nun am sinnvollsten und warum. Primär mit dem Input, primär mit dem Output oder Hälfte Hälfte soweit das geht?
Ob ich dann das interne Audyssey oder extern MiniDSP mit Dirac nutze dürfte ja bezüglich der obigen Frage eigentlich keinen wesentlichen Unterschied machen.
[Beitrag von iaterne am 11. Mrz 2020, 21:42 bearbeitet]
mabuse04
#33667 erstellt: 11. Mrz 2020, 23:18
Oopps... zwischen Audyssey und Dirac liegen Welten. Ich hatte beide und jetzt nur noch Dirac. Audyssey hatte ich das Pro-Kit.
Kannst du meiner Ansicht nach vergessen. Wenn du nichts anderes hast, besser als nichts aber Dirac ist meilenweit besser, gerade vom Ergebnis.
Ich hatte dir doch geschrieben wie es geht. Die Lautsprecher sollen alle gleich laut sein. Um die 75 dB.
Verwendest du Dirac werden am Anfang alle Lautsprecher eingepegelt. Ist einer zu leise oder zu laut, kannst du das manuell am LS nachregeln. Merkst du ganz schnell. Da Dirac unabhängig von deinem Denon funktioniert, stellt der alles ein. Wenn alles unsymmetrisch oder symmetrisch ist gibt es keinen 6 dB Unterschied. Es gibt einen Pegelunterschied zwischen XLR und Cinch.
Das war es auch schon. Statt Dirac kannst du einen Pegelmesser nehmen und alle bei - 0 dB am Denon - auf 75 dB einpegeln. Wichtig ist, was am Ende rauskommt und das ist der Pegel der Lautsprecher und möglichst alle gleich.
Du musst das an den LS selber erst mal einstellen, da der Regelbereich im Audyssey oder Dirac max +/- 10 dB oder so ähnlich beträgt. Ansonsten ist das, was Dadof3 geschrieben hat auch völlig korrekt. Der Signalrauschabstand dürfte bei Anschlag Maximal nicht mehr der Allerbeste sein. Die wurden mit 0 dB designt, alles außerhalb ist ein Sonderfall und sollte man nur verwenden, wenn es nicht anders geht.
Bei Dirac sieht das so aus:
Dirac Pegel
Allerdings, bei meinem Dirac. Datasat verwendet eine Spezialversion.
Audyssey macht das automatisch im Denon.
Ich hoffe, es hilft dir weiter.
Viele Grüße m
PS: Denk bitte daran ein kalibriertes Mikrofon - wahrscheinlich UMIK-1 - zu verwenden. Kann man auch nachträglich noch kalibrieren lassen.
PS2: Input Gain auf 0 dB, Output eigentlich auch auf 0 dB. Dirac und auch Audyssey messen am Anfang erstmal Pegel. Bei Audyssey sagt es dir aber nicht wenn was falsch ist und versucht das zu korrigieren. Der Output sollte so sein, dass du 75 dB erreichen kannst. Das siehst du nur durch eine Messung in beiden Fällen - A und D...
[Beitrag von mabuse04 am 11. Mrz 2020, 23:31 bearbeitet]
puffreis
#33668 erstellt: 13. Mrz 2020, 07:35
Sehr aufschlussreicher Test, vor allem mit dem Hinweis auf die Wichtigkeit der Harman-Kurve!
https://www.audiosci...peaker-review.12021/
thewas
#33669 erstellt: 13. Mrz 2020, 07:46
Armin gefielen sie aber in seinem Mono Hörtest wieder mal nicht (so wie alle nicht-Harman Lautsprecher) im Vergleich zu der Revel M16 mit ihrem Bassbuckel.
hmt
#33670 erstellt: 13. Mrz 2020, 10:45
Ja, ich kann es aber ein wenig verstehen. Leicht angehobene obere Mitten gehen mir persönlich auch ziemlich auf die Nerven (was insbesondere bei Kopfhörern leider sehr oft vorkommt). Das haben meine Neumänner zum Glück überhaupt nicht.
thewas
#33671 erstellt: 13. Mrz 2020, 11:07
Obere Mitten gehen mir auch auf den nerven und das haben z.B. meine LS50 (die ich auch dementspechend entzerre) aber die R3 hat im Vergleich zu der M16 sogar eher zurückgenommene Mitten:
PIR R3 vs M16
(Estimated in room-response von beiden)
puffreis
#33672 erstellt: 13. Mrz 2020, 11:12
Mir gefällt so ein Furzbass auch nicht, aber ohne Sub wäre ein R3 auch nicht das Wahre.
Warum nicht gleich geschlossen. Auf das bißchen bei 40 Hz kann man auch verzichten.
thewas
#33673 erstellt: 13. Mrz 2020, 11:16
Ich kann in meinem neuen bassschluckenden Hörraum eh kaum Lautsprecher ohne EQing im Bassbereich genießen, Bassreflex erhöht halt die Pegelgrenzen. Natürlich ist es viel besser mit gut platzierten und eingemessenen Subs, dann spielt der BR der Satelliten auch keine Rolle mehr.
Ahbehzäh
#33674 erstellt: 13. Mrz 2020, 12:14
Hi
bei RCF angefragt, ... Specsheets, Downloads, ergänzt.
Topp, danke!
Ahbehzäh
#33675 erstellt: 13. Mrz 2020, 12:53
Klingt nach dem guten alten Fließwiderstand - spannend wäre das resultierende Abstrahlverhalten: ergibt sich ein Kardioid im Bass?
gbm31
#33676 erstellt: 13. Mrz 2020, 22:47
Die Kali IN-8 sind heute gekommen.
Bin erst spät zum Aufstellen gekommen, also erstmal nur leise Erfahrungen gesammelt. Den Tip mit dem etwas offener Einwinkeln hab ich befolgt.
- Bass leicht zurückhaltender als die JBL 308P, nicht so wuchtig, scheint aber ... ehrlicher?
- Ja sie rauschen! Bei mir mit RCA -> XLR Kabeln angeschlossen leicht mehr und heller als die JBL. Werd irgendwann austesten ob das balanced besser wird (SPL Volume und DAC-100 sind ja da)
- 3 Wege merke sogar ich wenn der 8-Zöller mit Bass beschäftigt ist und dabei auch ordentlich Mitten produzieren soll, das machen die JBL nicht ganz so locker.
Das Mikro zum Messen ist leider noch nicht gekommen. Reich ich nach.
Ob das 100% Aufpreis rechtfertigt höre ich mir noch eine Weile an...
[Beitrag von gbm31 am 13. Mrz 2020, 22:51 bearbeitet]
hmt
#33677 erstellt: 14. Mrz 2020, 10:35
Habt ihr euch mal JTR Lautsprecher angeschaut?
http://jtrspeakers.com/home-audio.html
Es gibt im Pro Bereich von denen auch aktive LS.
Riesige Waveguides (bis 500Hz Bündelung) und ein coaxialer Kompressionstreiber. Nett.
thewas
#33678 erstellt: 14. Mrz 2020, 10:41
When die Messungen stimmen sollten ziemlich anständige aktive beit abstrahlende und preiswerte aktive DSP 3-Wegeriche.
https://swanspeakers.com/product/hi-fi-stereo-active-speakers-h6/
[Beitrag von thewas am 14. Mrz 2020, 10:42 bearbeitet]
chro
#33679 erstellt: 14. Mrz 2020, 10:59
sehen nett aus die Swans Lautsprecher. Sehe ich das richtig das die für 800$ das paar auch relativ "Preis-Leistungs günstig sind"
thewas
#33680 erstellt: 14. Mrz 2020, 11:00
Hoffentlich bestellt jemand mal ein Paar.
puffreis
#33681 erstellt: 15. Mrz 2020, 11:22
https://www.audiosci...peaker-review.12053/
Hier wird die Raumentzerrung entdeckt
thewas
#33682 erstellt: 15. Mrz 2020, 11:27
Jup
gbm31
#33683 erstellt: 15. Mrz 2020, 17:53
Ich höre jetzt wieder über die JBL.
Beim ausführlichen Testen der Kali heute ist aufgefallen, dass bei einem Monitor ab 100Hz aufwärts der Mitteltöner fleißig resoniert bzw durch Vibration irgendwo berührt, was zu einem sehr hässlichen Störton führt.
Mal sehen wie schnell Ersatz da ist und ob das dann besser ist.
[Beitrag von gbm31 am 15. Mrz 2020, 17:56 bearbeitet]
MarsianC#
#33684 erstellt: 16. Mrz 2020, 14:40
Messungen einer HEDD Type 05 auf Non Solo Audiofili inklusive Innereien.
AH.
#33685 erstellt: 16. Mrz 2020, 17:22
Hallo thewas,
nicht obere Mitten gehen Dir auf die Nerven, sondern eher Deine Tonaufnahmen.
Es gibt den "dumpfen Sound I", z.B. steigendes Bündelungsmaß ab 2 kHz (zu großer Mitteltöner gegen die Wellenlänge),
Es gibt den "dumpfen Sound II": Gegen die Wellenlänge zu großer Hochtöner wie ETON ER 4.
Und es gibt den "fetten Sound": Freifeldentzerrter Lautsprecher trotz "Bafflestep", Grundtonanhebung.
Vielleicht erinnert man sich noch an den "Frequenzgang" von "HGP Nightingale super tech" in der Presse. Schwacher Grundton und Höhenanhebung (dieser Teil des "Taunus-Sounds" ist eben wahr wegen des zu großen 25 mm Hochtöners). Außerhalb des Hallradius (ca. 1,2 m in Zimmern) gehört, klingt die überraschend gut
Der verbreitetste Hochtöner, die 25 mm - Kalotte hat ab ca. 6,6 kHz (Durchmesser gleich halbe Wellenlänge, 10 kHz = 3,4 cm Wellenlänge, 1 kHz = 34 cm Wellenlänge -> Dreisatz nutzen) deutliche Dispersionsprobleme. Eine Freifeld-Höhenanhebung kompensiert das.
Ich empfehle aus langjähriger Erfahrung lineare Betriebsschallpegelkurven. Zu meiner Überraschung klang "AutoQ" am Hörplatz mit dem Behringer 8024 am besten - Klang am besten ;). Der Lautsprecher hat ein frequenzlineares Bündelungsmaß zwischen ca. 100 Hz und 10 kHz.:
Ich habe vor Jahren einmal geschrieben: "Man muß regelmäßig in Konzerte ohne ELA-Anlage gehen, um Lautsprecher zu bewerten". Ich hatte ein Abo in der Hamburger Musikhalle -> linear klingt am besten
Wie "Lautsprechermusik" (Pop, Rock) klingt, weiß niemand.
Ich empfehle, in ein Sinfoniekonzert zu gehen eine "Klassik-Tonaufnahme" zu kaufen und zu experimentieren:
https://www.jpc.de/j...ie-Nr-7/hnum/1567654
liebe Grüße
Andreas
[Beitrag von AH. am 16. Mrz 2020, 17:35 bearbeitet]
thewas
#33686 erstellt: 16. Mrz 2020, 17:59
Oh, ist schon wieder Groundhog Day?
Zu deinen linearen Betriebschallkurven kann ich nur nur http://www.aes.org/e-lib/download.cfm/17839.pdf?ID=17839 und http://www.hifi-foru...m_id=33&thread=21456 empfehlen, wobei ich weiß jetzt schon das Ergebnis.
Schön aber dass du wieder online bist
Beste Grüße
Theo
sealpin
#33687 erstellt: 16. Mrz 2020, 18:06
passt nur indirekt in den Monitor Thread, aber ich habe mal zum Spass zwei Play:5 in Stereo bei mir im Wohnzimmer gemessen. Aufgestellt wurden die auf den Stands, auf denen sonst die KH310 stehen:
SONOS Play:5
(Messabstand 2,8m, REW, 75dB Pegel, 20-20000 Sweep, var. smoothing)
Ist jetzt nicht so schlecht finde ich...
Die Play:5 sind aber eher Hallsaucenwerfer und die Bühenabbildung ist - nun sagen wir mal - recht diffus und weit...kann gefallen, aber für mich eher zur Hintergrundberieselung geeignet.
Was beim Testen auffällt, das Treuplay macht einen recht brauchbaren Job.
sorry für Offtopic, aber manchmal macht es Spass, mal links und rechts über den Tellerrand zu schauen
thewas
#33688 erstellt: 16. Mrz 2020, 23:25
Das ist imho kein Offtopic und Messungen sind eh immer sehr interessant , schon erstaunlich wie solche Einmesssysteme in vielen kompakten und günstigen WLAN Lautsprechern Einzug gehalten haben, manch der neueren sogar komplett automatisch und kontinuierlich durch ihre eigenen Mikrofone.
puffreis
#33689 erstellt: 17. Mrz 2020, 09:18
Und jetzt bitte das Klirrverhalten
sealpin
#33690 erstellt: 17. Mrz 2020, 09:22
du bist gemein
Fosti
#33691 erstellt: 17. Mrz 2020, 10:14
AH. (Beitrag #33685) schrieb:
Diese LS funktionieren wirklich gut. Ich war mal bei Andreas und habe sie gehört. Allerdings ist das fast 2 Jahrzehnte her und heute würde mehr gehen. DIe LS haben fixe elektrische Filterfrequenzen und die resultierenden akustischen sind mangels Vorentzerrung fraglich. Es kommt nur zu einer "über alles" Entzerrung zum Schluss mit der DEQ-Ultracurve. Schade, das Andreas sich neuen DSPs verschließt.
thewas
#33692 erstellt: 17. Mrz 2020, 10:44
Das Gute zudem ist da sie ziemlich breit abstrahlen und Andreas im Nahfeld hört so dass das eigentliche Ziel linearer anechoischer Achsfrequenzgang auch einen relativ flachen Frequenzgang an seinem Hörplatz bedeutet und somit er mit seiner Korrektur zu einem linearen Hörplatzfrequenzgang den Achsfrequenzgang nicht zu stark verzerrt wie bei den meisten anderen Lautsprechern und Hörabständen.
[Beitrag von thewas am 17. Mrz 2020, 12:53 bearbeitet]
Fosti
#33693 erstellt: 17. Mrz 2020, 12:08
thewas (Beitrag #33692) schrieb:
...... und somit er mit seiner Korrektur zu einem linearen Hörplatzfrequenzgang den Achsfrequenzgang nicht zu stark verzerrt wie bei den meisten anderen Lautsprechern und Hörabständen.
Jepp, weiter weg vom LS passt das Argument von AH halt nicht mehr. Da gibt es nach aktuellen Forschungen von u.a. Toole und Olive andere zu bevorzugendende Betriebsschallpegelkurven, wie ja oft genug erwähnt wurde.
Hörstoff
#33694 erstellt: 17. Mrz 2020, 18:46
Ganz meine Meinung.
Wenn es nicht nervt, sondern der Klang maximal transparent ist (bei Klassik), ist alles bestens.
Auch wenn einige durch den Raum verursachte Irregularitäten im Kopf langfristig problemfrei "umgerechnet" werden können, ist noch alles ok.
Schlecht ist es, wenn Mitten oder Höhen "nerven" - meiner Meinung nach ziemlich untrügliche Anzeichen für schlechte Lautsprecher. Die Amplitude absenken bis es passt ist dann wohl eher keine optimale Lösung.
[Beitrag von Hörstoff am 17. Mrz 2020, 18:48 bearbeitet]
Studio Monitor...
Audi_Coupe am 10.05.2003  –  Letzte Antwort am 10.05.2003  –  3 Beiträge
Infinity Reference Studio Monitor
gba1 am 18.08.2007  –  Letzte Antwort am 19.08.2007  –  3 Beiträge
Monitor Audio Studio Serie
Naevis am 03.03.2004  –  Letzte Antwort am 04.03.2004  –  7 Beiträge
Studio Monitor aktiv HELP
Fact am 24.08.2007  –  Letzte Antwort am 25.08.2007  –  2 Beiträge
Hilfe ein Studio Monitor!
pruedi0 am 19.01.2010  –  Letzte Antwort am 20.01.2010  –  5 Beiträge
PC --> Aktiv Studio Monitor
buexxxi am 18.04.2020  –  Letzte Antwort am 22.04.2020  –  28 Beiträge
Infinity Studio Monitor 255. Wertvoll??
Der_Wobler am 04.07.2004  –  Letzte Antwort am 04.07.2004  –  7 Beiträge
Infinity SM Studio Monitor Serie?
Dj-BBoy am 27.10.2004  –  Letzte Antwort am 27.10.2004  –  11 Beiträge
ACOUSTIC Studio Monitor 3312 +KAUFBERATUNG
Nevermind017 am 24.10.2004  –  Letzte Antwort am 24.08.2008  –  7 Beiträge
BSS studio monitor M-250
chaos3 am 04.11.2008  –  Letzte Antwort am 05.11.2008  –  4 Beiträge
  • Registrierte Mitglieder928.589 ( Heute: 6 )
  • Neuestes MitgliedTorlen
  • Gesamtzahl an Themen1.558.557
  • Gesamtzahl an Beiträgen21.705.137
