Rauschen und piepsen schon bei geringer Lautstärke Yamaha AX-592
benzenbanz
#1 erstellt: 19. Jun 2010, 14:21
Moin moin ,
ich habe von einem Kollegen einen gebrauchten AX-592 bekommen und musste leider feststellen dass der schon bei geringer Lautstärke so -40db schon rauscht und ganz hoch piepst.
Ich hatte vorher einen AX-550 rs bei dem war das nicht der Fall.
Dazu kommt das das piepsen von Kanal zu Kanal unterschiedlich stark ist,pc rauscht stärker wie Tuner.
Bitte um hilfe!!!
tri-comp
#2 erstellt: 20. Jun 2010, 10:52
I believe we have no wizards or magicians here on the forum but it would require one to positively tell you what's wrong
Of course we could analyze the situation and come up with a couple of qualified guesses.
The amplifier is close to 20 years old. That suggest wear on components like the Speaker Protection Relay, Electrolytic capacitors, Mechanical switches, Bad solderings developing around Power-Transistors used as series-regulators in Power-supply circuits. The relay can be tested by gently tapping it when the fault occurs. If the howling changes in volume or disappears the Relay is at fault. Bad solderings can be found by visually inspecting the printed circuit board.
Mechanical switches may be corroded. (PURE DIRECT, CD DIRECT AMP, INPUT Source Switching)
Do you experience the fault in both channels?
If so, the problem is in a place common to both channels. This still suggests the Relay but also the Power-Supply (Electrolytic Cap's)
Disconnect the PRE-OUT/MAIN-IN plugs at the rear. Connect a CD-player with adjustable output (..and turn the output DOWN!) to the MAIN-IN. Does the problem still exist when you gently turn-up the volume on the CD-player? If Yes, the Output-amp's are defective. (Relay, Cap's) and if No, the Pre-Amp circuits are defective.
When you connect a CD-player to the correct rear-input labelled CD and press the front-panel CD DIRECT AMP button does the problem still show. If yes, all pre-amp circuits including Input-switching and Tone-controls are OK and the fault is in the Output amp's or Power-supply.
The above are general rules and not without exceptions. For example when giving a signal to the MAIN-IN it actually passes a buffer-amplifier IC in this amplifier-construction. This buffer may ALSO be the source of problems.
What I'm saying is, that in my country it takes 4 years to educate yourself to be an electronics technician. Probably you learn a trick or two during that time that can't easily be given to someone without much experience in repairs of electronics. You should have the tools (Osci, DMM, LF-Generator), knowledge of circuits and possibly also the service-manual.
If you PM me with your e-mail address I can help with info on how to get the manual.
Tools and knowledge is up to you
mfg,
/tri-comp
[Beitrag von tri-comp am 20. Jun 2010, 11:01 bearbeitet]
benzenbanz
#3 erstellt: 21. Jun 2010, 21:52
sry my english is horrible
audiophilanthrop
#4 erstellt: 21. Jun 2010, 23:35
Kein Thema, schreib einfach auf deutsch - das kann er nämlich ziemlich gut lesen, nur mit dem Schreiben hapert's. Bei dir wird's vermutlich genau umgekehrt sein, dann paßt das wieder.
Hast du schon versucht, den Fehler wie beschrieben einzugrenzen? Erfolgte der Tausch AX-550 gegen AX-592 1:1, ohne jegliche andere Veränderungen? Offene Eingänge zählen übrigens nicht, es sollte schon ein Gerät dranhängen (und das sollte nicht der Rechner sein, um eine Masseschleife auszuschließen).
[Beitrag von audiophilanthrop am 21. Jun 2010, 23:36 bearbeitet]
benzenbanz
#5 erstellt: 22. Jun 2010, 13:13
ja ich habe einfach nur die verstärker getauscht einziger unterschied die fernbedienung sonst war alles gleich auch mit einem eingeschleiften EQ.
Nein ich habe die probleme nicht versuchen können auszuschließen weil ich nicht verstehe was er meint ich habe auch keinen Cd-Spieler .???
EMail: b.banz@gmx.de
audiophilanthrop
#6 erstellt: 28. Jun 2010, 00:36
Also:
Pfeift's auf beiden Kanälen?
Bei dem Gerät hast du eine ganze Reihe von Möglichkeiten, den Fehler einzugrenzen.
Als erstes entferne bitte alles außer Lautsprechern und genau einer Signalquelle vom Verstärker, um Masseschleifen auszuschließen.
Bewege bei ausgeschaltetem Gerät den Schalter Impedance Selector auf der Rückseite hin und her, nur zur Sicherheit. Endposition 4 Ohm.
Dann teste folgendes:
1. Signalquelle an Eingang TUNER oder AUX
a) PURE DIRECT aus
b) PURE DIRECT an
2. Signalquelle an Eingang CD
a) PURE DIRECT & CD DIRECT aus
b) PURE DIRECT an
c) CD DIRECT an
Wenn das Pfeifen nur bei aktiver Klangregelung auftritt, kann man eine in der Lautstärke einstellbare Quelle auch testweise am MAIN IN anschließen (dann Einstellung 2a)).
Wie tri-comp allerdings darauf kommt, das Gerät habe fast 20 Jahre auf dem Buckel, ist mir unklar. Den gab es von vielleicht '97 bis 2000.
[Beitrag von audiophilanthrop am 28. Jun 2010, 00:36 bearbeitet]
tri-comp
#7 erstellt: 28. Jun 2010, 06:34
I looked in the service-manual, parts-list, page 45, where it says 1992.
Unfortunately it seems to be wrong. This is the page with a list of carbon-resistors size and corresponding Yamaha partno's. The list itself was generated in 1992, it is NOT the year of manufacture for the AX-592.
The manual I have was modified, probably by some Internet-dealer of service-manuals who removed the original Yamaha front-page, so I can't say exactly how old the amp. is.
I do have the full and original manual for AX-492, of the same series (AX-492, AX-592, AX-892) and the front-page says 1997.7 (July, 1997).
Sorry about the confusion.
mfg,
/tri-comp
Yamaha AX-592 kein Ton
Ireth am 23.02.2015  –  Letzte Antwort am 27.02.2015  –  4 Beiträge
Yamaha AX-592 Lautstärke Poti reagiert nicht mehr über Fernbedienung
arachnophil am 06.03.2011  –  Letzte Antwort am 17.07.2021  –  5 Beiträge
Zweiter Kanal erst nach Überhöhen des Lautsterkereglers? - Yamaha AX-592
JarodRussell am 18.12.2011  –  Letzte Antwort am 05.03.2012  –  3 Beiträge
Yamaha AX-750 Lautstärke leise
Rafterstar am 13.01.2015  –  Letzte Antwort am 14.01.2015  –  17 Beiträge
Problemmit Yamaha AX 496 Lautstärke
hans4445 am 11.04.2015  –  Letzte Antwort am 12.04.2015  –  11 Beiträge
AX-730 Rauschen und Signalausfall
Pukesh am 29.03.2015  –  Letzte Antwort am 30.03.2015  –  8 Beiträge
Yamaha AX-450 / Rauschen und Knarzen
Exilfranke am 09.06.2013  –  Letzte Antwort am 09.06.2013  –  4 Beiträge
Alesis RA500 hat aussetzer bei geringer Lautstärke
namenik am 07.03.2010  –  Letzte Antwort am 18.03.2010  –  4 Beiträge
Seitendifferenz bei geringer Lautstärke normal? (NAD 326)
concise am 14.05.2010  –  Letzte Antwort am 21.05.2010  –  6 Beiträge
Verzerrtes bzw klirrendes Signal bei geringer Lautstärke
snuffdown am 02.11.2015  –  Letzte Antwort am 05.11.2015  –  2 Beiträge
  • Registrierte Mitglieder929.029 ( Heute: 14 )
  • Neuestes MitgliedAmadeus1756
  • Gesamtzahl an Themen1.559.541
  • Gesamtzahl an Beiträgen21.728.863
